Question about Maytag MSD2756G Side by Side Refrigerator
Freezer side is hot outside
The side of the freezer is hot(outside), also the rubber on the doors are very hot, what can be the problem?
  • 1 more comment
  • ccook73346 Nov 13, 2008
    We had this refrigerator for 8 years and never had this problem, I can't believe there is nothing wrong with it. It's so hot you can burn yourself if you touch it. any more advice out there?
    Problem Solver:
  • 9 Answers
There is no problem at all. The outside of the freezer is hot because it is rejecting heat from the inside of freezer compartment to the outside surroundings, this is a normal refrigeration cycle. As for the seals being hot, this may be to prevent the door from freezing shut. i know that commercial and industrial freezers have heated seals for this reason.
Posted on Nov 13, 2008
Old whirlpool upright freezer. door left slightly ajar.light on inside. Rubber around door warm. won't seal.some things starting to thaw.shut door.should I do anything else
Seal needs to be replaced around door. Make sure magnetic strip is tight against sides of refrigerator, even if you have to cut the outside so it lays flat against the sides.
May 03, 2015 | Whirlpool Freezers
Why does the rubber sealer on refridgerator door and freezer door get hot
Inside the frame is a warm bit of pipework, or sometimes a mullion heater, that stops the seal freezing to the frame.
Aug 21, 2014 | LG LSC26905TT Side by Side Refrigerator
Condensation on outside of freezer door.
maybe your freezer door slight a bit open or have a gap causing the cooled air from the inside mixed with the hot air outside.
Feb 24, 2014 | GE Monogram Side by Side Refrigerator
Door hot
Totally normal. The condenser sends hot gas through the frame to stop the freezer door freezing to the frame. Check to see if you have a fan behind the condenser grill and make sure its running and clean
May 04, 2017 | Maytag MSD2756G Side by Side Refrigerator
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
The outside of the freezer door is cold, and the surrounding floor is cold - even in the hallway outside the room the freezer is in. Can't find any obvious leaks around the door seal. The sides of the...
the # should be inside, the temp in side the freezer needs to be checked. does the thing ever shut off, if not it may need a cold control
Jun 28, 2009 | Freezers
Refrigerator door is very hot
That should be warm not hot. It is a thermal break between the inside temperature and the humidity outside. It prevents moisture from condensing on frame of the door. Check for another problem such as is you freezer and refrigerator cool enough. On most modern models there is an energy saver switch which will limit the energy used by the heaters. Turn the energy saver switch on.
May 23, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
1,898 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
