Question about Whirlpool GEW9250 Electric Dryer
Dryer will not start
Whirlpool Duet dryer. Control panel lights and when the start button is pushed a light goes on that says "sensing" on the status board????
Cleaned the heat sensor on the lint filter and also the discharge chute. Any ideas???
  • Anonymous Nov 15, 2008
    I have the same problem.  Did you ever solve it?
  • Anonymous Nov 16, 2008
    dryer has power drive moter will not start
    Master:
  • 623 Answers
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
Posted on Nov 13, 2008
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Whirlpool duet dryer
Oct 22, 2013 | Dryers
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Whirlpool Duet Dryer GEW9250 which has all panel lights light but when you push the start button it beeps once and the sensing light is on and it doesn't start. I changed the Thermal fuse...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 19, 2011 | Dryers
Cannot be started and the status light "control
Take a good look on the control panel on the right ..It has a button that says press for 3 seconds for to lock ..Im not sure on your model ...but all models have a control locking button ..It may be the start cycle one ..If it is ..you have to press he button for 3 seconds and will unlock the controls ..
This happens when you try to make it start the cycle and hold the button on ..too long ..
Aug 15, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Whirlpool duet 9250 electric dryer taht is about 5 years old. When you go to start a load the status light shows "sensing" after you push the start button (which clicks when you push it) and then...
Hi
Thanks for using FixYa. It seems to be an issue with the belt. Please check this video on how to replace the belt in dryer. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 18, 2010 | Whirlpool GEW9250 Electric Dryer
Gas duet. Mod: GGW9250PWO Ser: MR3604435. Front panel under Status: "Control Locked" light is lit..nothing else works, including Control On button. Dead. Can the dryer be reset??
is the other lights DIM(partially lit)?
If so it could be one of the following.
1.) Intermittent ribbon cables between the control board and the Interface board (one with the buttons) Reseat all four cables.
2.) faulty control board.
3.) faulty Input board.
Nov 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool dryer model- ygew 9250 pwo will not power up when I control on button. If I push the power on button and the pause button at the same time some times it will start and run and sometimes I may...
When this problem occurs are the small lights on very dim? If so I would turn off the power and remove the top off the dryer. Then re-seat the 4 ribbon cables on the display board. Alot of people replace the front panel or control boards when the problem really is the ribbon cables. If the LED's are not lit dim then you may need to replace one of the two boards.
Jul 24, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer (2yrs old) Light buld died and dryer won't start. We changed bought a new light bulb but the dryer still doesn't start. The computerized buttons still litght up though.
Sometimes when a bulb goes out or is replaced the unit can short out.
Try holding your end of cycle signal button for 5 seconds, watch the light, if you control lock it, it will light but will not run because control lock is a safety feature.
Also try pushing door in and starting it, might be bad latch
May 02, 2008 | Dryers
Whirlpool Dryer wont start
Possible door s/w or thermal fuse. If its blowing thermal fuses with a clean and avg vent run check the relay, cycle unit with no heat fuction if the heat still comes on replace the relay board. Call your local servicer.
Mar 16, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
241 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
