Question about HP w19 19" LCD Monitor
Black striped down left hand side of display
Hi there
I use an HP Pavilion zd8123ea laptop for making music.
I recently purchased an HP w19 19" TFT display to act as a second display, which I was using to extend my desktop. I plugged it in and everything was fine. I then stupidly pressed the Auto button, which started Auto Config, and then the image on the TFT shifted 1/3 to the right. Now I have 1/3 of the screen totally black and unused, on the left, and then the other 2/3 of the screen show the extension of my desktop. The extension of my desktop is missing the final 1/3 (on the right), which has been shifted off-screen and is now nowhere to be seen!
I have tried messing around with Desktop settings in Control Panel, and been through the menu system on the TFT but I can't get the screen to go back to the way it was. Does anyone have any ideas how I can sort this out?! I am running Windows XP Home.
I have tried further trouvbleshooting, details are as follows:
Laptop -> TFT display
if I extend my desktop onto the second display, I get blackness down the first 1/4 of the screen and the rest is my laptop desktop
If I attach as follows:
Laptop -> LCD TV
I can get the whole of the laptop display to show on the LCD TV - therefore there is not a problem with the laptop VGA output
PC -> TFT display
the setup works fine, I can see the whole of the PC display
Therefore I can only deduce that there is a problem with the settings between the laptop and the TFT display.
I have checked the display properties on the laptop but cannot get the TFT display to show the entire extended desktop when connected to the laptop (i.e. there is always a black section on the first 1/4, left hand side.
Any help would be much appreciated, thank you!
  • 1 more comment
  • dannyyoung Nov 13, 2008
    Hi Skotkolr,
    Yes there is a button marked "Auto" on the display, which I pressed, I think this is auto configure.
    When I go into the menu on the monitor, there is no setting for the size of the screen. There is an option to move the screen position horizontally and vertically, and if I move it all the way across to the left, there is still a 1" black gap.
    I have also tried resetting the monitor (Menu -> Reset) but that doesn't get rid of the black stripe.
    I am convinced it is a problem with the settings between the laptop and the display, as when I use my laptop with my LCD TV (to watch movies etc.) the display is fine.
    Is there anything else I can try, I am almost at the end of my tether!
    Thanks
    Hi Skotkolr, further info - I started the laptop in safe mode and the w19 display was fine, no black mark down the left hand side. It looked exactly the same as the laptop display (it wasn't acting as an extended desktop because I don't believe it can in safe mode). When I restarted the laptop, the problem came back, so it must be something to do with the settings between the laptop and the display, do you have any further ideas?
    Thanks
    Incidentally on the main page for the w19 monitor there is a link here -http://www.fixya.com/support/t779425-hpw... - which seems to point to the same problem, and apparently has 15 solutions - how can you the solutions? Every time I click on them it tries to make me an expert, which I am not - I just want a solution!
  • 558 Answers
OK try setting the laptop display setting to a lower resolution like 1024x768 or lower auto configure may work if you change some of the following
TV settings can mess with the display as well look in the display advanced setting for a tab that might relate to your issues ie displays or monitors
Posted on Nov 13, 2008
  • 558 Answers
Hi Danny, you haven't been very clear I will assume you pushed the auto configure on the monitor,
I would go into the menu on the monitor and reset the size of the screen if it has a setting for that 1024x768 should fix the problem
let me know what you find as I have never worked with a hp W19 monitor, if nothing else set the monitor to defaults again in the menu and that may get you back to having normal screens.
L8r
  • 558 Answers
Another issue is that the monitor you are using is a wide screen so the resolutions will be a little odd like 1440 x 768 etc try different ones like that and re do the auto configure
HP Pavilion G series Laptop Speakers are making weird noises,please help.
you stop the speakers and add vlc media player it works nicely.
Sep 27, 2012 | HP Pavilion G4-1213nr 14" Inch...
I have an hp pavilion dv7 entertainment laptop and recently it started to stop booting, what its doing now is when i press the power button the screen stays black and all the lights come on and for some...
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
Sep 21, 2010 | HP Pavilion ze2000 Notebook
HP w19 display is messed up in many ways!
I am wondering if the monitor is close to some other electrical device like a TV. Try hitting the degausing button if it has one. This is like a monitor reset button and removes stray magnetic forces from the monitor.
most monitors do have them amongst their array of buttons or on the rear might also be a pinhole, but be carful incase you touch a live wire
Jun 23, 2009 | HP W19b LCD Monitor
I have a hp pavilion dv9000. and i need the screw for it.
Check out page 86 for the display schematics. Page 120 outlines the dis-assembly. Page 154 actually describes the screws of which you speak. You may be able to purchase them locally.
http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
Jun 06, 2009 | HP Pavilion dv9000t Notebook
Display has 2 inch black stripe running vertically down screen
I have an IBM think pad that developed a 2 inch black strip on the left side of my dispaly. I tried restoring to a previous setting, I updated video drivers, I reset display properties. None of the above worked and am now thinking of formatting and reinstalling windows as a last hope unless someone has any other ideas.
Dec 26, 2008 | Toshiba Satellite P105-S6104 Notebook
HP Pavilion dv4000 touchpad problem
Im having the same problem. It didnt start until i had to turn my lap top upside down and such trying to get the battery to work, taking it in and out and so forth.
I push down on the left hand side by the touch pad and it works fine. If i dont press down, my typing will not show, music will not play, the whole pc freezes even the time on it.
Oct 21, 2008 | HP Pavilion dv4000 Notebook
Display problem
my screeen is black there is sound but no picture
Jun 10, 2008 | HP Pavilion dv1000 Notebook
3 Stripes on 1 side of the screen
Ask these guys http://lcdrepair.net
Sep 30, 2007 | HP Pavilion zd7020US Notebook
HP w19 19" LCD Monitor Logo
429 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
