Question about JVC DR-MH30S DVD Recorder
Flashing Loading sign on start up
Hi i purchased a DR MH30SE which has worked for me superbly up until now. It initially started with a problem ejecting a DVD and has now progres to a constant loading message and does not respond to any of the reset functions. Its a fantastic piece of equipment and i would like to keep using it. It was bought in Germany so i'm not sure if the warranty over here is the same. I have searched the web and apparently there is a mod for it. Does that mean its a known fault!? Can anyone help. I have taken the system out and tried to reinstall it days later and the loading msg keeps coming up. i have tried to leave it on but after 9 hrs i got fed up of looking at the blue flashing lights HELP Please!!!
  • mto2003 Dec 16, 2007
    I have got the same problem
  • teampenk Feb 29, 2008
    DVD plays for a while then loading flashes on constantly until I switch off at mains and back on again then it goes on standby.
    New Friend:
Try warming it up with a hair dryer or something. If that helps, it could indicate power supply problems. Like capacitors.
Posted on Nov 16, 2014
I have the US model and had the problem off and on since I bought it. A few weeks ago it finally would not submit to any of my tries at resetting it. I sent it back to JVC and they told me the hard drive crashed and that was the cause. They'll install a new hard drive for $400+ - more than I paid for it.
Posted on May 25, 2007
It is a known fault and therefore the manufacturer should do something about it, although if not in the country purchased, does complicate things, but there is nothing to stop you contacting JVC Germany. Find the name and address of the Chief Executive and explain the problem. If purchased in this country trading standards should help you obtaining repair from the retailer you purchased it from. If you can prove an inherent fault,the seller has some responsibility for up to 6 years. do some research on the net, try here for starters, http://cippico.com/bbs/viewforum.php?f=4&sid=5b6e889fbced7a4e6905f66517c74b3f good luck! Keith
Posted on Apr 06, 2007
I HAVE THE SAME PROBLEM HOW DO I FIX THIS ??? george.hennessey@ntlworld.com
Posted on Jan 12, 2007
SOURCE:
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Says "dr", will not start
The error clearly indicates bad door switch. Very simple to fix, have to take top off and loosen switch from front panel. Remove and replace.
Part #131763245 and suggested retail price $50.
Thank you
Jun 14, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
Nov 13, 2009 | JVC DR-MH30S DVD Recorder
Just purchased a 2 yrold Kenmore French Dr/Freezer on the bottom frig How long until it starts making ice. I've had it plugged in for 28 hours now. It's hardly cold inside. AHH! Help please.
From initial start-up you should be at operating temperature in 24-48 hours depending on the ambient temperature. Both controls should be on the mid setting. Make sure the condenser fan underneath is operating and the coils should be very warm. If not there may be a problem in the sealed system.
Eric
Oct 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Canon DR-3080 CII scans only half or right side of document
Try all formats, Color, Grey & Black & white. If you have problem it could be the scan module. Check for loose contacts, but this is rare in a working machine.
S. Mohan
Oct 02, 2009 | Canon Office Equipment & Supplies
Resident Evil 4 game for ps2 won't start at begining
hahahahahha upgrade to xbox 360 you ******* *********
Sep 20, 2009 | Capcom Resident Evil 4
Unit shows 'loading' continuously
This player is equipped to do a self power on test to all pain parts of the player to assertain everything is ok. The blue light will keep flasing until it completes its task and then the blue light will stop flashing and you you can start reusing it.....................sodeep
Jul 30, 2009 | JVC DR-MH30 DVD Recorder
JVC DR-MX1S
This machine has a lot of problems. One thing that often works is to turn it off and unplug it for a couple of minutes. Then plug it in again. Then it will say "loading" for quite a while. Leave it alone until it turns itself on. Then it should be okay. If the couple of minutes doesn't work, sometimes unplugged overnight (same method) works, but then you have to reset everything.
Feb 02, 2008 | JVC DR-MX1S DVD Recorder/VCR
JVC DR-MH30S LOADING
Had this JVC recorder for a couple of years, It has always take ages to
boot up and start working now its stuck on "Loading" on the display.
Anyone no of a reset seqence that will restart the machine
Nov 20, 2007 | JVC DR-MH30S DVD Recorder
JVC DR-MH30S DVD Recorder Logo
440 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
