New speakers to an old (1960s) record player
New speakers old record player how to connect?Old speaker wires into the player.
Two rows of soldiered connections each connection on the top row connects directly to its opposite number on the bottom row.
Left to right top
1 Blue 2. White 3.Red 4.Green 5.Black
Left to right bottom
1.R speaker. 2.White. 3.Red. 4.L speaker. 5.This connects with internal wire and external wire that runs out of the set with the speaker wires.
email eromkcalb@btinternet.com
  • 2 days ago
  • - 1 day left to answer.
Additional Details
I would like to feed this to modern speakers each with a black and a red wire
  • 2 more comments
  • eromkcalb
    eromkcalb Nov 13, 2008
    This is what I have
  • eromkcalb
    This is all new to me so simplicity is a must
    The new speakers each have 2 wires black and red i need to know what to connect to thease wires to get them speaking.
  • eromkcalb
    Each new speaker has a black and a red wire what do i connect to thease to make them speak
  • robwan
    robwan May 11, 2010
    Hi, has the turntable got a preamp inside it because if it hasn't it would need to be connected to a preamp first so that the signal is boosted so the speakers can be driven. In regards to the turntable its difficult to evaluate without seeing a picture of the connections and the setup, usually if its just a record deck the player would have a hot and a cold and a ground so that it can be connected to an amp. If you can send me pictures of the connections then I can find a slolution for you.
  • 4,234 Answers
It is difficult to say with 100% confidence because the pictures are out of focus, but it looks like you have just a regular turntable. The wire connections you show are the bridge between the tonearm and the external RCA style cables. The extra wire (#5) is the ground wire. You should be able to connect this to any receiver that has a phono input.
For confirmation, can you update this with the model number of the turntable? That will allow me to confirm what I have stated above.
Thanks,
Dan
Posted on Nov 13, 2008
I have sony radio model no STK-KM22 it display flashing protector messege and I cant play any thing ,how I can solve thi ploblem?
Unplug for 30 seconds unplug speaker cords.twist all wire ends together tightly for each set of wires.one little wire not twisted tightly with the rest can short out throwing receiver into surgery protection mode.plug receiver back in or reconnect it.test each wire set to see if external speaker wire issue.wire sets are twisted good you will know as each speaker will come back on.twistem tight soldier them or use liquid tape to keep connection working properly.use surge protector to protect unit receiver.
Apr 09, 2017 | Sony Audio Players & Recorders
Hi i have a rowe ami r90 where could i get two new large speakers, thanks
You should be able to use any 10" 8 ohm speakers in the R90, try rowejukeboxparts.com for new or get the old ones reconed.
May 19, 2015 | Audio Players & Recorders
I have a panasonic 803us 8-track player. Bought new speakers for the unit, but none of jacks match up. I would like to adapted the new speakers before buying another set of speakers. Can anybody help me...
Why not leave the original jacks in place, cut the wires near the old speakers and new speakers and just replace the speakers, using 2 scotch lock connectors to connect the 2 wires to each speaker. (Keep polarity consistent for each speaker). Of course you should test one speaker first to make sure they will work with your unit, before you cut any of the remaining wires.You can always connect the originals back as long as there is a bit of slack in the wire.
Jun 24, 2014 | Audio Players & Recorders
I have an old Chevy and I'm trying to hook up my Kenwood kdc-138 stereo. I have the red wire connect to the red ignition wire and black wire to ground. I have the yellow wire hokoed up to the ignition...
The fact that your speakers have only one wire, indicates that they are the old negative ground type. You will have to buy new speakers, or try and connect the negative wires of your speaker wires from the radio to the car body (chassis) and try that. Normally you will get a bit of static when you start your engine
May 31, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
What type of speaker cable do I need?
there are 1/8 inch jacks, and quick connect jacks also.
Feb 26, 2009 | Audio Players & Recorders
6x9 hook up
yes conect the wire to the new speakers and it has to work
Feb 17, 2009 | Blaupunkt PCxt652 Coaxial Car Speaker
Sony-DG820 Subwoofer
The powered subwoofer should be connected to the black subwoofer output near the bottom of the receiver in just about the center. A subwoofer uses line level signals and has its own amplifier, Good chance that you wiped out a channel. Put the wiring back the way it was, and IF the channel was not directly connected to the speaker terminals, MAYBE, JUST MAYBE it will still work.
Chances are slim...
Apr 27, 2017 | Sony STR-DG820 Receiver
Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
May 30, 2008 | Panasonic SC-AK600 CD Shelf System
Car stereo installation speakers
Your old unit was a common ground unit meaning all speaker grounds as well a radio ground were the same. The new unit should NOT be connected to this wire configuration. Newer units change the potential difference of the speaker power meaning that the - wire of the unit may have negative 24v on it so IT CANNOT BE REFERENCED TO EARTH OR CHASSIS GROUND.
I would recommend rewiring the speakers to the radio for best reliability and sound quality.
Dec 31, 2007 | Jl Audio 12W3 Car Subwoofer
1,146 people viewed this question
 Grubhead
Grubhead
