Question about Home
Poor flow I have good flow in 4 of the 6 jets, how do I fix the 2 with no or very low flow?
It could be 1 of the following problems 1) pipe length from pump should be same lengths
2)dirt stuck in pipes - pipes should be flushed out
3)pipe might have a kink in it
Posted on Nov 13, 2008
1997 Yamaha Royal Star XVZ 1300 A poor throttle response
Hi, Boss96 and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Pinholes or torn diaphragm.
6. Accelerator pump leaking or no output.
7. Plugged bowl vent or overflow.
8. Fuel level in bowl too low.
9. Restricted fuel supply passages.
10. Plugged jets or passages.
11. Worn or damaged needle or needle jet.
12. The choke valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Total Motorcycle Forums
help poor throttle response hesitation Road Star Warrior Forum Yamaha Star...
Testing Motorcycle Throttle Position Sensor Checking Ohms with multimeter
http://www.werder.ee/Manual/XVZ1300.pdf
https://www.partsfish.com/page/oem-parts-for-yamaha
YAMAHA XVZ1300A Owner Manual
Mar 22, 2018 | 1997 Yamaha Royal Star XVZ 1300 A
03 Nissan Altima showing codes P0304,P0102,P0154,P0113 what are they and how do i repair the problems.
Hi Chris.
p0304 = Number 4 Cylinder Misfire Detected
Faulty spark plug 4
Clogged or faulty fuel injector 4
Faulty ignition coil 4
Fuel injector 4 harness is open or shorted
Fuel injector 4 circuit poor electrical connection
Ignition coil 4 harness is open or shorted
Ignition coil 4 circuit poor electrical connection
Insufficient cylinder 4 compression
Incorrect fuel pressure
Intake air leak
The P0304 code means that the cylinder 4 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 4.
p0102 = Mass or Volume Air Flow Circuit Low Input
Faulty mass air flow sensor
Intake air leaks
Dirty mass air flow sensor
Dirty mass air filter
Mass air flow sensor harness is open or shorted
Mass air flow sensor circuit poor electrical connection
Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner.
Reset code and drive vehicle.
If the code comes back, it may be necessary to replaced the mass air flow sensor.
p0154 = O2 Sensor Circuit No Activity Detected Sensor 1 Bank 2
Faulty Front Heated Oxygen Sensor Bank 2
Front Heated Oxygen Sensor Bank 2 harness is open or shorted
Front Heated Oxygen Sensor Bank 2 circuit poor electrical connection
Inappropriate fuel pressure
Faulty fuel injectors
Intake air leaks may be faulty
Exhaust gas leaks
Replacing the Front Heated Oxygen Sensor Bank 2 usually takes care of the problem.
p0113 = Intake Air Temperature Sensor Circuit High
Faulty Intake Air Temperature (IAT) sensor
Dirty air filter
Intake Air Temperature (IAT) sensor harness is open or shorted
Intake Air Temperature (IAT) sensor circuit poor electrical connection
The Intake Air Temperature (IAT) sensor is built into mass air flow sensor or in some vehicles mounted to the air filter duct housing. The sensor detects intake air temperature and transmits a signal to the Engine Control Module (ECM).The temperature sensing unit uses a thermistor which is sensitive to the change in temperature. Electrical resistance of the thermistor decreases in response to the temperature rise. The Intake Air Temperature signal is used as an input for various systems in the vehicle.
Hope this helps
FYT
http://www.autocodes.com/make/nissan
Mar 26, 2017 | Nissan Cars & Trucks
When applying the throttle my scooter surges. When I give it gas quickly it slowly declines when I give it gas slowly it gains speed slowly but never gets past 23mph
Hi Lynn, for hard starting the usual suspects are:
1. Enrichner system plugged, not properly functioning or improperly operated.
2. Fuel overflow.
3. Restricted fuel supply.
4. Plugged slow jet or passages.
5. Inlet system air leak.
For poor acceleration the usual suspects are:
1. Throttle cables misaligned or misrouted (may also affect idle speed).
3. Inlet system air leak.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
12. Enrichner valve not seated or leaking.
Good luck and have a nice day.
Jul 19, 2015 | GAS Motorcycles
Yamaha r1 poor performance on choke
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/103-02-03-r1-mechanical-help/63782-choke-problem-please-help.html
Throttle Position Sensor Issues Are you Experiencing Poor Idle Mileage or...
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Aug 09, 2014 | 2005 Yamaha YZF-R1
Poor pulling and pickup
12. The enricher valve not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Free Bajaj Motorcycle Service Manuals for download
Apr 23, 2014 | Bajaj Wind 125 Motorcycles
Honda shadow 500
Hi Darryl, and the usual suspects are:
Honda Motorcycle Service Repair Workshop Manuals
Dec 25, 2013 | Motorcycles
Aprilia rx 50 poor running
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichner valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper fuel level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
DOWNLOAD 2010 Aprilia Rx 50
Jan 14, 2013 | 2010 Aprilia RX 50
1994 Honda VF 750 C Magna poor accelleration
poor low RPM acceleration help
Very Poor Acceleration GL1500 Information Questions goldwingdocs com
Magna VF750C Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VF750C Owner Manual
Dec 29, 2012 | 1994 Honda VF 750 C Magna
2000 Yamaha YZ 80 poor idling
Hi, Shaundavies6 and the usual suspects are:
2. Air fuel mixture screws not properly adjusted.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yz 80 2001 model Carburetor tunning Trouble
Life On 2 Wheels
Yamaha YZ80 service manual repair 2001 YZ 80 YZ80LW Download Manuals... $8 cheap
Oct 24, 2010 | Yamaha Motorcycles
Flo word on panel nothing else works
'Flo' means that there's insufficient flow of water through the heater, or non at all.
1) Check the water level - top up if low.
2) Ensure that all jets are open and flow water - if they don't you may have a pump issue.
3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
Regards,
Ian.
http://hottub.synthasite.com
Mar 06, 2010 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Home Logo
148 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
