Question about InFocus LP650 Projector Lamp
Two horizontal black bands across the lower 1/3 of the display.
The unit is a INFOCUS LP650. The height of each band is about 10% of the screen height. I have reseated the mother board and checked the display connector.
Also looked for bad solder joints .
Any help would be greatly appreciated.
Jim
  • RRB1305 May 06, 2009
    Jim,
    I have a similar problem with a Infocus 7205.
    Its one horizontal (grey/black) thick line/band through the image.
    I got this projector as a gift from a family member, they had the same problem, but when the projector was moved it seemed to have fixed itself. But now the problem is back!
    I too was thinking it could be a loose connection / bad soldering - and am planning to open the projector up soon.
    Was wondering if you have had any luck with a solution as yet??
    R
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
The light tunnel needs to be adjusted or replaced
Posted on May 05, 2010
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
Displays only narrow horizontal band of light on screen do you have any ideas
What you haveis most likely a horizontal collapse, You will have to take the unit in and have it repaired, go to a trusted techie though, Its most likely just a "cold solder joint," few minutes to fix if that is it and if the tech will admit that it is something so simple.
If you take your hand and hit the side of the projector does the line react at all? If it flashes even slightly then you are on the right track
Unfortunately a cold solder joint can sometimes be difficult to locate and due to the intigration you can no longer just check the horizontal control sect of the board....You may try asking the tech If he/she believes it "may" be a cold solder joint......good luck
May 22, 2009 | InFocus IN36 Projector
InFocus LP650 will not come on
That color is not listed because it is either Green or Red. There is no Blue, if you are getting Blue, you have something that is extremely unusual.
Feb 16, 2008 | InFocus LP650 Projector Lamp
Banding on LCD TV
you need a new motherboard
Dec 09, 2007 | Televison & Video
Horizontal banding on Dell monitor
Hello, My name is Richard and I am part of Dell's Online Community Outreach group. Looking at you monitors issue; it would be most advantageous that you contact our technical support. Your monitor seems to be a fairly now model and is probably still under warranty. Call 1-800-WWW-DELL and provided the technician the PPID number on the back of the monitor. The Dell rep will be able to determine your warranty options. Regards, Richard B Online Community Outreach
Jun 21, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
InFocus LP650 Projector Lamp Logo
159 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
