Question about Mercury P4VM800M7 Motherboard
When start the computer then move the fan for few seconds then stop the computer what is the ploblem in it
  • yaseen5787 Nov 13, 2008
    solve my problem
  • Anonymous Nov 15, 2008
    dfzh
    Genius:
  • 1,250 Answers
REPLACE POWER SUPPLY THEN CHECK
Posted on Nov 16, 2008
Kenmore 106.54584400 fridge warm, air baffle No open in normal ops. in test mode opens and closes but evap fan does not run. fan motor runs during normal ops. thermistors good in test mode.
I would meter test the evap fan it may have gone out cuz if it was ur defrost timer or cold control you would have no motor condenser fan working either? and no cold control damper working in test mode?
is the fan impeeded or just not moving?
May 21, 2015 | Kenmore Refrigerators
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
Cooling fans in op until engine is shut down . At idle, in traffic, temp gets high, hen wmoving, temp goes back to normal. When I shut down the engine the fans start to run as they are supposed to when the...
Check out clarks-garage.com he has a complete troubleshooting guide for your cooling system along with a schematic. In short, check the low speed resistor on the firewall. Should be around one ohm.
Oct 10, 2009 | 1985 Porsche 944
How to lubricate toshiba p100 fan
Your laptop is testing the fan at start up. The fans cannot be lubricated.
Jan 31, 2009 | Toshiba Computers & Internet
Truck turning off
Im really sorry to tell you this, but it is an ongoing ploblem with this truck.You will never be able to fix this ploblem.The only thing that is wrong with it is a four letter word that starts with the letter F and ends with D (HEHE).Your second ploblem with it shutting off while your driving is stange.Could be anything.Clogged fuel filter,bad gas,fuel pump,plugs and wires,cap and rotor,coil,clogged air filter (you can take it out and see how it runs witout it to see if thats the problem),or it could be the dreaded electical system or even the timing.Good luck. :-P
Jan 22, 2009 | 1995 Ford F150 Styleside Regular Cab
Computer will not switchon,light just flashes.fan works o.k.
you do not say if windows or mac. Either way, boot up, open cd/dvd drive, put in ops system disk, power off, when started, re install or repair your ops installation. Donside here is you may have to wipe drive as it seems as if some virus/trojan has got hold of your registry start up sequence. Safe bet, reinstsall ops system, goodluck.
Jul 18, 2008 | Computers & Internet
Watch
Hold down the mode button and it should start blinking on the seconds. If not the mode, then the adjust button, but hold if down for a few seconds. Then if it was the mode button probibly the adjust changes the time, if the adjust , then the mode button should adjust the time. I don't know if it just adjust the seconds and then you have to move to hours and then min and so forth, but if you do just try the st/stp button. Tell me if this works, it should but if not I'm here to help. Good Luck!!!!
Jul 09, 2008 | Watches
Control panel lights blink and beep, freezer fan cycles
The column between the doors being warm usually indicates that the compressor is running properly but the condenser fan at the bottom rear that cools the condenser and compressor is not running. Remove the cover from the back of the machine and verify this fan is running. It could have stuck from sitting for a period of time or something has gotten stuck in the blade during the move.
I am interested in what the fan inside the freezer is doing. You say 3-4 second pattern, is it running a few seconds then off a few seconds?
Please post back with the exact model number from the decal inside the fridge and I will look it up and see what I can come up with.
Nov 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Mercury P4VM800M7 Motherboard Logo
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
