Question about Zanussi Washing Machines
Drum will not turn on 1450 jet systen excel - Zanussi Washing Machines
    Scholar:
  • 97 Answers
Hiya
this could be a number of faults, so here are some troubleshooting tips
1, set the machine off on spin, do you hear a whirring sound as well as the drain pump?
if you do then it's probably the drive belt that has snapped or came off the motor.
2, set the machine off on spin, does only the drain pump make a noise?
if it does then there's a good chance its the motor brushes are worn down and need replaced, to check you will need to tilt the machine back and the motor will be right in front of you, using a 5.5mm socket remove the two holding screws from the brushes (usually black plastic rectangles on either side of motor) and the wire, the carbon inside the plastic cover should ideally be 10mm +
REMEMBER TO UNPLUG FROM THE MAINS FIRST.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Nov 14, 2008
Engine is not starting very well. After much cranking and almost starting, it runs, just. If throttle is moved up or down it stalls. What else can I do ?
not enough detail as to make and model but if it is a carby engine then the main jets and idler jets are blocked
the rubber components from the tank to carby break down internally and small pieces of rubber get to the carby
water and corrosion are also other problems associated with this fault
all out boards exhaust out the prop and by running the engine in a drum , then the oil in the drum is the oil and smoke collected by the water in the drum
While this is an excellent way of running a motor , remember that the oil mixture is being recirculated through the water pump in the leg and that will cause problems if you run the engine then leave it unused for a period of time
The rubber of the pump impeller will crack and fail when again used
Take it to a service center and get a proper diagnosis done and a quote
May 13, 2016 | Boating
Tip
Garmin Nuvi 1450 QuickStart Download
Download Garmin Nuvi 1450 Quickstart Manual
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1450 GPS?
Would you like a digital copy of the Garmin Nuvi 1450 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1450 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 Webupdate
Garmin Nuvi 1450 Favorites Backup
Garmin Nuvi 1450 Hard Reset
on May 27, 2010 | Garmin nuvi 1450 GPS Receiver
Tip
Download Garmin Nuvi 1450 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1450 GPS?
Would you like a digital copy of the Garmin Nuvi 1450 Users Guide for easy searching of terms and quick reference?
The Nuvi 1450 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Where does the jet that fell out when I removed the float go
When you removed the float no jet should have fallen out. If you take out the retainer pin for the float you will be removing the bowl float and needle valve. The head of the needle has a shaft that fits onto the tab of the float bowl and fits into the hole where the needle valve seat is.
Jul 31, 2013 | Briggs Stratton IC Horizontal OHV Engine ...
Had no auto matic adjusting lever can I put new brake shoes without replacing adjusting lever on 1994 Hyundia excel rear brake driver side
The rear brake drums are drum brakes on the 94 excel. The Excel uses the front brakes the most, so are you sure you need to replace the rear brakes?
Jan 06, 2011 | 1994 Hyundai Excel
1450 carb will not idle without choke on. cuts
If the bike has been allowed to sit for a while, the fuel may have evaporated in the float bowl. When this happens, the jets get stopped up with the gummy residue that is left behind. You may need to go through the carb and clean the slow jet and the main jet. While you're there, it would be advisable to install a new set of intake gaskets.
Feb 14, 2010 | 2001 Harley Davidson FXDXT Dyna Super...
Franklin BIB-1450 cannot turn on.
Turns out the batteries that I tried were dead. Bought new batteries and installed them. The Franklin BIB-1450 now works. Yay!
Jul 31, 2009 | Franklin BIB-1450
Brother printer Drum problem
Several things to check, the P/U roller is warn down, could be the paper sensor or the paper in the tray is set too tight
Feb 12, 2009 | Brother HL 1450 Laser Printer
Washing Machines Logo
50 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
