Question about Samsung HCM4215W 42" Rear Projection Television
Wavy red lines ,double vision
Samsung sp47w3hfx 47"rear.pro...fixed 2yrs ago ,problem back,can i fix myself,if i get part,convergence unit?
  • rufnec66 Feb 04, 2009
    wavy red line and double vision. The ics as described are numbered stk392-040
  • 4,234 Answers
This is a convergence problem and if you can solder, you should be able to fix this yourself. First open up the back and locate the convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. Post the markings here and I'll confirm you have the correct ones. Try resoldering the pins on the ICs. If that fails to resolve the problem, you will need to replace them.
Keep me posted,
Dan
Posted on Nov 13, 2008
Double vision lines of red and green
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 12, 2009 | Samsung HC-P4752W 47" Rear Projection...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
My mom has a samsung hc-p4752w and my stepfather heard a pop with a burning smell and after that his tv has a double vision look. so i saw on here how to fix the grid which worked fine except the red...
Convergence IC's are bad......
You can mess around with ordering them, and replacing them, and hunting for the bad resistors on the board and replacing those too, or you can order a new board PN BP94-01266a for around $160, and plug it in. You'll have to readjust the convergence manually afterward. Just did it on my set - works beautifully!
Nov 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
All screen is red
IF THE SCREEN IS ALL RED WITH VIDEO VISIBLE AND RETRACE LINES. ADJUST SCREEN CONTROL IN THE FRONT FOR THE RED TUBE ONLY. TURN CONTROL COUNTER CLOCKWISE. IF THAT DOESNT DO IT THE TUBE CAN BE REJUVINATED.
Nov 19, 2008 | Samsung HCL4715W 47" Rear Projection...
Double vission on a HDTV Panasonic
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Nov 15, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Samsung HCP4752W double vision
*Screen Looks 3-D
*Colors wont align
Oct 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Double vision
Its a repair you can do yourself for under 40.00 if you can solder . You need to replace both convergence ICs they are both STK392-110. You can get replacement ICs at the following link with free instalation instructions with pictures. TV shops generally charge between 400 and 600.00 for this repair which takes about an hour.
Heres the link
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Jvc av56wp74 rear projection tv
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 18, 2008 | JVC AV-56WP74 56" Rear Projection...
BLUE DOUBLE VISION
It sounds like you may have a loose solder connection either in the convergence circuit or the pincushion correction circuit. If you can't visually locate it, you may need a service manual and test equipment to track it down. I doubt that changing parts will be the cure if it is an intermittent problem.
Dec 16, 2006 | Samsung HCN473W 47" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
170 people viewed this question
Henry  Thomas
Henry Thomas
