Question about Hitachi Cine Master PJ-TX200 Multimedia Projector
Hitachi Illumina PJ TX200 solid red power and lamp light
Hi, i hope you can help. Last night the bulb on my PJ finally gave up and when it went out i heard a click from the unit. Now, when i switch it on it get a solid red lamp and power light and no indication that the fans are turning. I am told that this problem will not be fixed by replacing the bulb. any ideas or comments ?
thanks in advance
rob
5 Suggested Answers
Marrie
  • 563 Answers
SOURCE: PJ-TX200 hitachi projector
Hi George86969
Try checking if all the fans are working when you swich on the unit. Normally a static red temp. light is a faulty fan that will have to be replaced.
Posted on May 20, 2008
SOURCE: Hitachi CP-X960 Shutting Down
Where can you find one?
Posted on Sep 12, 2008
  • 39 Answers
SOURCE: Lamp
I have the CP-X275W that did the same thing. The ballast was bad and I fixed it with a $5 switching regulator. The CP-X327 has the identical ballast.
Details:
The High Intensity Discharge Metal Halide lamp suddenly failed to light up. A new lamp was installed and would not light up either. The fan ran and the lamp LED flashed after a few minutes. Voltage to the ballast module was 368VDC. The ballast did not pulse.
Ballast# PS-226-LS-210 was bad. Hitachi Part# HA01101 has been discontinued and the new part number is HA01102. It was $210USD at Vance Baldwin or $221USD at Part Solver.
The FET series (TR1,5,6,7,8,) seemed good: (drain-source resistance=5Kohm). Bought an identical projector on Ebay to do comparative multimeter measurements. Found resistance differences in IC01 (STRG6153). Swapped good part to bad projector, and it worked. This is a 5-pin Sanken brand switching regulator, US$5 at www.electronix.com. They have the STRTG6153, which is compatible, and may be better. The bad one removed from the circuit measures 15Kohm on pin 3 to pin 5 and the same 15Kohm when the probes are reversed. The good one measures 18Mohm and infinite when the probes are reversed.
If you would like me to fix it for you and clean all your optics, I can do it for $150USD plus $25 return shipping. Contact Chris at chris_goulet@yahoo.ca.
If you have a new lamp for sale I would buy one for $100USD.
Good luck.
Posted on Feb 05, 2009
vortash
  • 431 Answers
SOURCE: Lamp light is solid orange/red; No Image on screen when pj on
Sounds like bulb to me best way to check is take it to a service centere and they will use a replacement or test bulb to find out for you , it may not be your bulb it may be your ballast circuit . ... regards Vortash
Posted on May 10, 2009
SOURCE: Lamp
lamp duration
Posted on Jun 12, 2010
Light, then Dark
ok! maybe you have defective capacitors! or lost contact at high voltage section!
Oct 05, 2007 | Hitachi Cine Master PJ-TX200 Multimedia...
Replace inside bulb of projector lamp for Hitachi
check the site below
http://www.aboutprojectors.com/pdf/hitachi-pj-tx200-manual.pdf
thats the manual
Jan 09, 2011 | Hitachi Cine Master PJ-TX200 Multimedia...
Hitachi ED-S3170 Projector problem
If the bulb is under warranty then take it back.
Jan 26, 2010 | Hitachi ED-S3170 Multimedia Projector
High lamp temp
Dismount dustfilter, carefully vacuum clean filter and filter aperture, then replacing filter and finally reset filter time in menu.
Dec 24, 2009 | Hitachi Cine Master PJ-TX200 Multimedia...
May 10, 2009 | Optoma HD72 Multimedia Projector
Hi George86969
May 17, 2008 | Hitachi Cine Master PJ-TX200 Multimedia...
The Protectiopn circut is working
Hi there
Did you check that your lamp hours were actually reset ?
Mar 27, 2008 | Mitsubishi XL1XU Multimedia Projector
Hitachi Cine Master PJ-TX200 Multimedia Projector Logo
828 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
