Question about HP Photosmart C5180 All-In-One InkJet Printer
Expire dates on ink cartridge
Can you send those pictures on How to get to the battery to fix my expire message problem
glehner@ccpacking.com
Thank you very much
(HP Photosmart 8250)
  • 1 more comment
  • glehner Nov 18, 2008
    Have no battery problem. Problem is that, as it was explain, removing the battery to get rid of the expired message from ink cartridge (that still have ink in it)
    Well, may be my english is not good ! On your web site someone say that we have to remove the battery from the board inside the printer (remove cover and then 3 screws on the board to reach battery) to clear the printer memory to reset the printer for removing the message for changibg ink cartride due to the chip on the ink cartridge. It says he can supply pictures on how to do it.
    Thank
    Georges
  • danarn Feb 04, 2009
    My HP Photosmart 8250 sat unused for awhile, then when I tried to print, it said the cartridges were expired. I've read about a battery to remove...where would I find that on this printer?
    Thanks!
    Dana
I've found a site that has the photos for disassembly!
http://hpphotosmart8250.blogspot.com/
Regards,
Louis
Posted on Mar 02, 2009
  • buck1107 Mar 18, 2014
    Update: I did this - removed the battery for a minute, and then returned it to its clip. The printer worked like new. In order to keep from having to take the whole thing apart in the future, de-soldered the battery clip from the circuit board, soldered wires where the clip had gone, and this allowed me to put the battery (in its clip) just under the raise-able hood. Now, if I need to replace the battery, I just raise the hood, and voila!
    Problem Solver:
  • 6 Answers
Which battery expire. chip charger or other. pl clear.
Posted on Nov 18, 2008
  • Jayendra Patel
    Jayendra Patel Nov 18, 2008
    you must clear which battery you have problem i can help you what u have problem with printer
  • Jayendra Patel
    pl send me which battery u get problem. i can solve that problem.
Printer will not print saying that the printer is out of ink. Test shows empty cartridges. Took the cartridges to store, they checked and said they were full, doing a test page to confirm. Is there some...
try clean the gold contacts that touches the printer and the catridge.I remember some of the pins tells the printer the leftover ink in the catridge.
the other thing is, hp ink will 'expire'. there is a fixed date stored in the chip of the catridge. if the date is expired, you cant use the ink regardless its full or empty.
Sep 22, 2011 | HP Officejet 5610 All-In-One InkJet...
I bought a black ink for my hp photosmart c5 180 and the when i turn on the printer it says the ink has expired. Can i still use it or will i damage my printer. Thanks regards Anita
Hello
according to HP
Each ink cartridge has an expiration date. The purpose of expiration is to protect the printing system and to ensure ink quality. When you receive an ink cartridge(s) are expired message, remove and replace the expired ink cartridge, and then close the message. You can also continue printing without replacing the ink cartridge, by following the instructions on the HP All-in-One or the ink cartridge expiration message on your computer screen. HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Device service or repairs required as a result of using expired ink will not be covered under warranty.
You can get more detail from here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00819032&dlc=en&product=1153481
Hope this helps, if so do rate the solution
Dec 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
The ink cartridges keep expiring and they are nearly all full .my machine is a hp photo smart 3310 all in one.How do i by pass the expiry dates on cartridges
Each ink cartridge has an expiration date to protect the printing system and ensure good ink quality. The cartridge expire date appears on line 53 of the self test report.Printing can continue without replacing the ink cartridge. Follow the instructions that appear on the HP product or on the computer. However, HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Service or repairs required as a result of using expired ink are not covered under warranty
As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button .
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 16, 2010 | Office Equipment & Supplies
Run out ink error warning message
are using a refilled cartridge?
if yes, install an actual brand new one.
are you using an official cartridge that you've had laying around for a while?
the cartridges expire so check if your cartridge has expired and replaced accordingly.
Mar 29, 2010 | HP Photosmart C7280 Laser Printer
The red light has come on to replace the ink cartridg, i only use black ink then i tried to reset and the red light is still on and it will not print. the colour cartridges are about 3 years old???????...
Check status monitor? See difference of chip reach ink out and not recognized. Reset chip that ink level reach ink out. Also check chip connector at ink tank and at chip itself. Plug ink tank securely. Check status monitor again. If still not resolved, try to use anither chip.
Aug 18, 2009 | Epson Stylus C86 InkJet Printer
HP Officejet 9110 empty or expired cartridge error
You were a bit vague in your report as to what the exact error is that you are plagued with. Perhaps you have more than one. The 9100’s ink cartridges are “smart cartridges.” They each have a chip in them that reports various cartridge statuses directly to the printer. Diagnosing the problem correctly requires the identification of the particular error message. You can find a list of the error messages and what they mean here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=376170&prodTypeId=18972&prodSeriesId=376170&objectID=c00067620
I think that you are experiencing an “INK CARTRIDGE EXPIRED” error. This error is not related to the ‘volume’ of the ink within the cartridge(s) but rather to the actual expiration ‘date(s)’ on the cartridge(s). The expiration date is encoded on the chip that resides on the cartridge. The actual expiration date appears to relate to the date two years after the date that is stamped on the cartridge label. I can’t change the expiration date on the chip—at least not easily or inexpensively—but I have discovered a way around it.
The date on the cartridge corresponds to the date on the printer itself. You just need to send the printer back in time to a period before the expiration date and you should be able to print again. A time machine is probably out of the question. Instead, reset the date on the printer to reflect a suitable date.
This could conceivably have some negative consequences that I haven’t experienced yet. I’ve only just discovered this ‘hack’. Though I haven’t tested it, the newly assigned, incorrect date will probably appear on any subsequently received fax transmissions. I can also conceive of networking issues if your printer is networked. Some network related instructions require that all network nodes (all devices on the network—computers, printers, etc.) report a time (and date) within just a few minutes of each other to communicate. You’ll just have to try it in your network and see if everything functions properly or within acceptable limits.
To change the date on the 9100 printer, you’ll need to access the ‘Maintenance’ menu. Just below the LCD panel on the front of the printer there are a series of buttons as follows:
[Return], [Up] & [Down], [Accept], [Left], and [Right]. They each have their own unique symbol, but I’m sure you can understand my descriptions. Press and hold BOTH, the [Up] and the [Down] buttons at the same time while you press and release the [Accept] button—then release the other two buttons. If you weren’t taken directly to the ‘Maintenance’ menu (# 10), then use the [Up] or [Down] arrow button to navigate to it and then choose the [Accept] button to select it. Similarly select the ‘Set date and time’ option, and follow the prompts to make the necessary changes using the appropriate buttons.
Once you have changed the date and time you may have to turn the printer off and then back on again before the printer will recognize the cartridge(s). In my case, the printer went through an extensive print head alignment.
Jan 27, 2009 | HP Officejet 9110 All-In-One InkJet...
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
8250 HP INK EXPIRED MESSAGE
I had same problem, and i solved it.
I opened my hp 8250 and removed it`s battery. It is located on left side of the printer, on the main board. You need to remove plastic covers , and then remove 3 screws holding board. You can move board just enough to get damn battery out of there. Now it works perfect!
I can send you some piccs if you need help.
Regards
Sasa
Sep 12, 2008 | HP - HP Photosmart 8250 printer
Hp officejet 7110 battery and cmos location
The battery is located behind the left front cover. Open the printer, grasp the left front cover from inside the printer and pull to open. Look inside the printer to left and you will see it.
It is enough to remove for a minute to reset the expiration.
But I'm afraid after that the printer may not keep the date and time when turn off.
Jun 19, 2007 | HP OfficeJet 7110 All-In-One Thermal...
Printer
Top Solution thanks - Take that HP!
Slight amendment as battery is hard to remove:
The battery is accessed by opening top then can be seen on extreme left at front. No need to take it out, slip a strip of plastic like an old credit card under the clip on top of battery to insulate it. Then do a soft reset (# and 6 and power down) with the battery insulated. Power up - Power down, remove insulator power up. Eureka!
Jan 24, 2007 | HP Officejet 7130 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
1,502 people viewed this question
Seeker5211
Seeker5211
