Question about HP LaserJet 1320n Printer
Not printing The printer does not respond to the printing command
  • 734 Answers
Hi,Try the following sites to short out your problem…..
http://uw713doc.sco.com/en/PR_admin/prntT.NoPrint.html
http://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_5.htm
http://www.smartcomputing.com/editorial/article.asp?article=articles/archive/r1101/04r01/04r01.asp&guid=
Thanks
Posted on Dec 04, 2008
I Have A Epson PLQ-20 passbook Printer and it is connected through USB cable. after successful setup when i give print command to the printer it is not responding and nothing happened.
Sep 20, 2011 | Epson Passbook PLQ-20 Matrix Printer
Printer does not respond to "Copy" command
Press and hold the Setup button, and then press Options (or Copy Options ).
It will bypass the alignment.
Apr 09, 2010 | HP PSC 2175 All-In-One InkJet Printer
Driver
if the copier is not responding to print commands then you need to verify that the ip address listed in the print driver is the same as the one on the copier and that the copier's ip subnet and gateway are apropriate for your network...
Dec 29, 2009 | Sharp AR-5320 Black and White Copier
My A920 has stopped responding to my print command
go into the control panel into the printers icon. Make sure your a920 printer is set as the default printer.
Jan 25, 2009 | Dell A920 InkJet Printer
My canon mp210 is not responding to printing requests. we have replaced both colour cartridges. note: printer will photocopy a page, but again, it will not respond to request to print a word document, for...
Is there any blinking of light when the print command given. Any error message at printer display or Computer Screen ?
There is some problem in printing options. Please check and make default setting in the Printer properties. Go to Control Panel --> Select the printer --> Open printer window --> properties --> make them defauls --
During print command check whether the spooling in printer window goes completely or not (if it stop in middle )
Let me know in brief to solve this problem before going to reinstall printer drivers and do not vote till you recieve a good solution for this problem.
Nov 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Printer Not responding
pls see if your printer is offline or online first, by double clicking your printer icon, if it is you can go to printer properties and select an print test page if it does print then you should be able to print on all kinds of application or any platform.
Aug 27, 2008 | Canon PIXMA MP150 All-In-One InkJet...
All in One Printer/Scanner/Copier will not respond to print command.
Pls make sure that your computer recognizes your Printer, if it doesn't it would never respond to any print command you sent
check to see (if the computer recognizes)
1- go to start then select printer
2- select your desired printer - right click
3- go to properties
4- select print PRINT TEST PAGE
5- check the message on your paper
if it doesnt then you might have installed a wrong driver
Jul 14, 2008 | Office Equipment & Supplies
Will not respond to print command
download the newest software from web and install it. if its not helping, check connections, if your printer has a display and menu key, you can print aut configuration and demo sheets, to see that the printer itself works. if not the last option is firmware upgrade.
Jan 31, 2008 | Konica Minolta magicolor 2400 Laser...
HP LaserJet 1320n Printer Logo
80 people viewed this question
Ben Johnson
