Question about Samsung S850 Digital Camera
I dropped my camera while i was taking a picture and the lens got stuck and would'nt go in, but pictures token were still very clear.then i tried turning the lens but the pictures i took got very blurry.
  • Anonymous Mar 08, 2009
    My camera won't zoom and pull back correctly. It makes a clicking sound and if I want to take a picture I have to change the place of both batteries.
  • 98 Answers
In this case you must changed the zoomunit, it's not so expensive but i ask on monday Samsung for the cost of a optical zoomunit.
Posted on Apr 05, 2009
    Champion:
  • 225 Answers
Try to pull the lens back into the right socket. If that won't work, a new camera lens part is needed.
Posted on Nov 13, 2008
I can turn the camera on to look at pictures, but when I try to take a picture the lens is stuck and does not extend all the way. If I slide it over to view pictures, the lens extends fully and then...
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the camera may have a problem that requires professional repair.
Dec 30, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
My camera is showing blurred pictures when taking pictures help
Try reseting all menus to default, then try again to test.
Make sure the lens is clean.
Do the menus appear clear?
Has the camera ever been dropped or had any other damage? This could get the lens out of focus, and would need repair.
Does blurring happen when zooming or when taking a picture of any kind?
Sep 09, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
Review windows is black, pictures are black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jun 12, 2009 | Cameras
Lens is stuck open - will not close. still takes pictures
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 24, 2008 | Samsung NV10 Digital Camera
Can't take pictures.
try zooming in on a object and see it it get clearer. the problem is your zoom lens motor is stuck or malfunctioning. This is a very common problem with digital cameras. sometimes you can take compressed air and blow around the lens and clear the blockage or lightly tap the camera lens down with it off to free up the focus gear. if it does now work it then needs tobe serviced or repaired. I had the same model last week for the same problem. That lens had tobe replaced. but try that first and see if it helps.
Apr 04, 2008 | Olympus FE-190 Digital Camera
Lens error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens is stuck
Hello Gruntny, in order to repair this Camera you will have to replace the OPTICS UNIT (ED13A). Please contact your nearest Sony Service. Best regards, Arpad
Dec 21, 2006 | Sony Cyber-shot DSC-W50 Digital Camera
I dropped my camera and now the pictures are funny...
What you describe is the symptom of a stuck shutter. The shutter is inside the lens and must close in order for the image sensor to properly record the image. Yours is stuck open, and that is why you see the lines across your images. When a stuck shutter results from an impact it usually requires full disassembly and manual re-setting of the delicate shutter blades. This problem would require professional repair. Unfortunately damage from an impact is not covered by your factory warranty. You can find good repair services on the internet who can service your camera. David Millier Advance Camera Repair
Dec 17, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Zoom and shutter not functioning
that is a symptom of being dropped and stuck in a mode.
it requires total dissemble of the camera to fix or replace the lens. your lucky it takes pictures at all. most cameras refuse if the lens is stuck.
Jul 28, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Samsung S850 Digital Camera Logo
168 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
