Question about Kenmore 72175 Air Conditioner
Display changed from F to C
My Kenmore 72175 window air conditioner display changed from displaying fahrenheit to centigrade. This happened while running on my generator. How can I change it back to fahrenheit?
Thanks
Rod
  • 8 more comments
  • rodratliff Nov 13, 2008
    Unplugging it did not change it back to fahrenheit.
    Still displaying centigrade.
    I cannot find the remote.
    I read the manual... It says nothing about changing from C to F.
    This is a window air conditioner, not a refrigerator.
    I do not see any pinholes and I have not taken it apart to look for a jumper. I have tried every button combination, both before and after posting this request for help.
    This answer does not qualify as a solution. Apparently no one knows how to change it back to fahrenheit display.
    I have the manual and can set the temperature. The air conditioner works just fine... it just displays the temp setpoint in celsuis.
    There is no start button but the one labeled on/off did not change anything.
    I have the manual and can set the temperature. The air conditioner works just fine... it just displays the temp setpoint in celsuis insted of fahrenheit.
  • 728 Answers
Try reconnecting it to the generator and do what you did the time it changed from Fahrenheit to Celsius and see if there is any change. If not, try leaving it unplugged over night to allow it to reset the features back to the way they were when you bought it. This should change it back.
Posted on Nov 13, 2008
  • 535 Answers
U have to urgently call a costomer care
    Sergeant:
    Novelist:
  • 196 Answers
  1. Maximize the application by clicking on the temperature icon in the system tray.
  2. Click "Settings" in the upper right-hand corner of the application.
  3. Select "Weather Display Units" from the "Additional Settings" area.
  4. The "Weather Services" control panel will open. Select the "Weather Display Settings" pulldown.
  5. Make the desired selections and click "Update Display Preferences
  • 1 more comment
  • mmechanics Nov 13, 2008
    1. Turn the unit off.
    2. Press and hold the Start Button for 5 seconds, until the current measurement scale (C or F icon) flashes on the display.
    3. Switch the measurement scale between C and F by pressing the Start Button again
    Change Display from Fahrenheit to Celsius
    1F80-24
    Press Set Time & Hold Temp at the same time, display will change to C°. To return to F°, repeat.
    1F80-41
    1F80-51
    1F80-52
    1F80-71
    1F81-51
    1F81-71
    1F82-51
    1F83-51
    30 Seconds after power up press Temp Up & Temp Down at the same time, display will change to C°. To return to F°, repeat.
    1F83-71
    Press Temp Down and System at the same time and hold until it reads in C°. To return to F°, repeat.
    1F84-51
    1F86-444
    1F87-51
    Press Set Time/Set Temp & Hold Temp/ Adv Day at the same time, display will change to C°. To return to F°, repeat.
    1F89-11
    Press Temp Up & Temp Down arrow keys at the same time, display will change to C°. To return to F°, repeat.
    1F80-24
    1F80-41
    1F80-51
    1F80-52
    1F80-71
    1F81-51
    1F81-71
    1F82-51
    1F83-51
    1F83-71
    1F84-51
    1F86-444
    1F87-51
    1F89-11
    Genius:
  • 1,239 Answers
Hi  Check for blown fuses or tripped
    circuit breakers at main entrance
    panel or at separate entrance
    panel; restore circuit.
2. Lower thermostat setting 5°.
    Brigadier General:
  • 6,966 Answers
I doubt if it there would be a button/key to toggle from Fahrenheit to Centigrade or back. However, since these units are designed to be marketed in different regions, it is very possible that there is a hidden hard switch or even a soft switch. Pls try:
  • check if there is a recessed button or pin hole anywhere on the display, if not would be inside on the logic board or even under the display;
  • press the temp up and down buttons simultaneously and hold for a second or more;
  • try the temp up (or down) button pressed continuously for a couple of seconds;
  • press the temp up (or down) button momentarily and then press again two or three times successively.
Incidentally, I would venture a guess that the change was brought about by the not perfect consistency of the AC frequency when used with a generator.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • 507 Answers
To change the temperature readout back to Fahrenheit press the Freezer Temp and Refrigerator Temp buttons at the same time and hold for 5 seconds or more.
    Master:
    Sergeant:
  • 449 Answers
Hi!!
try to disconnect all the power
leave it for few hours and then turn it on
if still the same
restore it default using the remote
read the manual!!! if you have
  • 13,433 Answers
Do you have the remote controller? Try the Set mode buttons and see which one changes it. I looked at the user manual but it didn't saw exactly what todo to change the mode. try a few things don't give up
  • 734 Answers
Not a big problem switch off your unit for 2 minutes and then restart, if it not working then restore the original setting from remote
  • futureloginn
    futureloginn Nov 13, 2008
    Your problem occurs due to generator that is because of sum light fluctuating problem. do you have the owners manual to set the temperature
  • futureloginn
    as i see all the posts, a only way out ask from the service center to repair, because your generator set damaging sum internal ic of your ac.
  • Kenmore Master
  • 19,396 Answers
Try disconnecting power from main for five minutes, this will report settings to factory.
Help I tried to lower the temp for the air conditioner and now it won't turn off because it's set at 20.5. How do i reset it to 68?
I believe it is set to show Centigrade at the moment. 20.5 deg C is actually 68.9 deg F. So no worries as to the temp being wrong.
Now if you are asking how to set the display to Fahrenheit degrees instead, we will need to know the make and model.
Jun 24, 2016 | Heating & Cooling
Tip
How to keep your Kenmore running smooth.
To keep your Kenmore running smooth, make sure that you change the filter every six months for three reasons: because it will make it harder for the machine to pull in air to be blown where you are, it could cause dust to build up in vital machine components making it hard to clean and could cause permanent damage, and so you can breathe in fresh air. Also, when you change the filter, get either some machine oil/grease or some wd-40 and put it on the reachable moving parts of the machine so there will not be grinding.
Hope this helps keep it running smooth!
on Nov 13, 2008 | Kenmore 72175 Air Conditioner
Change remote to centigrade,accidentally knocked to Fahrenheit
Press both up and down buttons for few seconds it will change to centigrade mode.
Sep 02, 2015 | Heating & Cooling
I have a model 25372175200 air conditioner. Could you tell me the btu size of this.
All you have to do is look thru the front air ducts
on any window unit or remove the front cover
All the info is on a label in plain site
Jun 24, 2011 | Kenmore 72175 Air Conditioner
How to change outside temperature guage from F to C
You can switch the temperature mode
between Fahrenheit to Centigrade as follows:
While pressing the OFF button, press the
AUTO button for 3 seconds or more.
The display will change from Fahrenheit
to Centigrade, or from Centigrade to
Fahrenheit.
Feb 04, 2011 | 2011 Hyundai Elantra Touring
When i change the temperature to make it hotter, the screen blinks then goes back to being 30 degrees colder. Is my heater ignoring my request because it never reaches the temperature i want it to. it...
First you have to understand in thermostat there are Fahrenheit & Centigrade degree. If Centigrade between 16 to 30 and if it is Fahrenheit 60 to 86.
If you press the symbol ther> and > (or) ther- and ther+ at a time degree will change.
Now you set your temp +10 degree from your room temp and also keep "heat" mode.
Dec 14, 2010 | Heating & Cooling
Changing temp readout on Midea Air Con Controller from F to C
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
Jul 09, 2010 | Heating & Cooling
Reading the wrong tempeature
Centigrade (celcius) metric temperature .
19C = 66F, 20C = 68F 21C= 70F approx.
25C= 77F, 30C = 86F. There should be a setting to change that to Fahrenheit.
Jul 17, 2009 | Maytag M6Q10F2A Air Conditioner
Question about model #253-355080
I woud suggest putting a pan under the unit with a hole in it that you can attach a hose bib and then attach the hose to it and run the hose to a better location...
Jun 19, 2007 | Kenmore 72175 Air Conditioner
Kenmore 72175 Air Conditioner Logo
484 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
