Question about Lakewood (5500) Oil Filled Radiator Heater
Heater pops the circuit breaker
It works great last year, but now when i turn it on, it breaks the circuit breaker. does anyone know why this is happening?
  • katp56 Nov 16, 2008
    I will check that out. Thanks!
  • 3 Answers
Yesterday I received the new switch assembly with a complete wiring harness from Nelson Appliance. The 3oz metal weight is attached with a much stronger piece of plastic - see picture.
For the installation I only had to slip the automotive connectors back on the heating elements. Now I am back in business with a working heater. Unfortunately I am out of almost $40 for the whole replacement. I wish they had installed the stronger plastic piece that holds the metal weight in the first place.
Posted on Nov 21, 2008
  • 3 Answers
Lakewood 5500 Heater - Here is a picture of the rear side of the open heater thermostat with the two switches for 600 and 990W at the left. The 3oz metal piece is the weight that broke off from the thermostat assembly. It fell down and made a short between the case and the power switch. There is a visible burn mark where the short occurred.
I am convinced that if the heater ever falls over, the metal weight will break off and fall down and probably create a short against the case. It may disconnect the 120V power at the thermostat or cause a high enough current to kick out your breaker in the house.
The attachment of the 3oz metal weight to the back of the thermostat is not strong enough to survive when the heater falls over; it wil break off.
Posted on Nov 17, 2008
  • 3 Answers
I just opened up the control panel on my Lakewood 550 Heater. The switch has a rather heavy weight attached to it with a measley piece of plastic. On mine, the weight broke off at the plastic, and it ended up falling down and making a short between the case and the heater wire connection. There were some burn marks on the metal weight and the case of the switch assembly.
When I checked at the Lakewood Heater web site, they mention two different companies that sell spare parts; Lakewood does not sell any. So I am going for a switch replacement, since I do not want to mickey-mouse glue the weight back together. The only problem is the price for the replacement switch; it costs about half of what a new heater costs. Spare Parts at Nelson Appliance see - http://www.nelsonappliance.com
Posted on Nov 15, 2008
My hot tub trips the GFCI. THe GFCI holds when I disconnect the wires running into the hot tub. I have disconnected EVERYTHING from the circuit board including the heater and the GFCI still trips.
Sounds like wet or bad wiring somewhere but u should do a visual inspection of all the wires & connections first then through process of elimination. Turn off breaker disconnect all wires and connect one wire then turn breaker on & if it dosent pop the. Turn it off and connect one more wire and turn the breaker on & continue until you get the breaker to pop and the last wire or board u just connected is your problem & go from there.
Feb 14, 2016 | Pool & Spa
Hi, I have a nice master B150D that ran flawlessly last season,brought it out this year replaced nozzle,spark plug,new fuel. Fired it up ran for 30 sec. pop's the circuit breaker,reset,runs 20 sec....
if a circuit breaker pops i assume its an RCELD or is it a MCB type
it is some leakage to earth somewhere in the electrics
if it runs and pops the breaker
and you can plug it in and it will sit there
then i assume its something do do with the fan system
or ignitor . driver system
look for sources of leakage to earth
and you could measure the peek current it uses with a multimeter inline
set to AC amps
anyway its defo not a gonner just some bad electrics
Dec 09, 2014 | Heating & Cooling
Can I remove a breaker from panel box cap the wires turn electric back on till I go get a new breaker.
You can but why not get a new breaker first. Once into the panel and you're done.
Nov 28, 2014 | Electric Electrical Supplies
I have a I heater that will not turn on. Last time it worked fine. What should I check ?
first check the outlet its plugged into to be sure there is actually power there, if not check your breaker box, it may have overloaded the circuit and popped the breaker. if all good there, check the unit for a fuse, which may be blown.
Oct 11, 2014 | IHeater 1500 Advanced Infrared Heater...
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
HEATING UNIT IS POPPING THE 220 CIRCUIT BREAKER.
If its a resistance heater (electric heat) chances are you have a shorted out heater element. This is the most common problem with these units. You can disconnect the 220 going to the elements and turn the unit on and see if it still pops a breaker. If it don't then you know its the heater elements their selfs. If it still pops a breaker then look for a wire that go hot and shorted to either the case or another wire.
Take caution when working on 220 volt equipment as you will get shocked. You should never touch anything inside the unit unless you have pulled the power to it (Turned it off via breaker or plug or what ever means it has to connect the unit to the household electric.).
Hope that helps you.
Jan 27, 2011 | AdobeAir Heating & Cooling
I have a Daton Fuel trimmer furnace for my garage.
On the thermostat see if it has a setting for fan on auto and off try turning the fan on then see if it comes on, if it does then it may be your thermostat has failed if it does not turn on then reset the circuit breakers to see if you have a breaker kicked off. If it was wired properly there should be one near the unit and one in the main breaker panel so be sure to reset both. To do this you must force the breaker switches all the way off then all the way on. On some breakers if you do not force it to the off position it will not reset the breaker. If this does not help let me know and I will try to help you some more just replay to the e-mail you get go to the bottom of the page and post add comment
Nov 10, 2009 | Reddy Heater RLP100 Portable Forced Air...
30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
Jan 11, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Oil filled Heater will not turn on and heat.
First thing make sure: · Ensure that your circuit breaker or fuse is working properly. · Be sure the heater is plugged in and that the electrical outlet is working properly. · Check for any obstruction. If you find any obstruction, turn the heater ?OFF?. Unplug the heater and wait a few minutes for it to cool down. Carefully remove the obstruction. Plug the heater in and turn it on again by referring to the OPERATING INSTRUCTIONS. Second, If you're NOT still under warranty you should at least open the heater and look for anything strange like a blown fuse. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace.
Dec 03, 2005 | WeatherWorks CH3001 Oil Filled Radiator...
Lakewood (5500) Oil Filled Radiator Heater Logo
352 people viewed this question
Top Lakewood Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Paul Carew
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
