Question about Sony PCS-1 (PCS1) Video Conference
Sony PCS 11
We are having an issue with a Sony PCS11
All of our systems (LifeSize and Sony PCS11 and PCS1) are having the option to set the audio codec to AAC-LC but not this one. How could we get this option?
FW version is 3.30
Thanks in advance
Harry Farkas
3 Suggested Answers
SOURCE: Can a webcam connect to a SONY PCS1?
1. Windows XP Pro does NOT have a shortcut set up in the Start menu or Program Files, to launch NetMeeting please click Start> Run
2. At the Run Window type conf.exe then click OK
3. Fill out the info
· First and last name
· E-mail address: use you AdFarm Email
· Location (your location)
· Comments leave blank
4. Click Next… Do NOT check the boxes, Select Local Area Network…Keep both check boxes selected… click Next… Click Next again…
5. Make sure speaker volume is set to a comfortable level then click Test you should get sound, adjust accordingly.
6. Your camera should have a microphone attached you will see the Record Volume when you say “Testing 1… 2… 3… Testing”
7. Click Finish… NetMeeting will launch…
8. Enter the appropriate IP for Video Conf under quick connect and call
John S (LVS - Calgary, AB)
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: Sony PCS-1 Video Conference
in order to help you:
- are you behind a firewall?
Sounds a lot like a firewall issue.
You may contact us for free troubleshooting:
Contact
Furthermore this is our detailed PCS-1P page.
Best regards,
Andy
Posted on Feb 19, 2009
Sound does not work. You can see the other people but you cannot hear them
RING YOUR PROVIDER FOR VOICE ACTIVATION,OR TRY SAME BRAND SPEAKERS,THEY AR N,T EXPENSIVE,OK,MATRICK.
Oct 15, 2009 | Sony PCS-1 (PCS1) Video Conference
How can we connect the sony pcs-1 to a pc?
GO TO A SHOP AND GET THE CORRECT LEAD,OK,MATRICK.
Sep 28, 2009 | Sony PCS-1 (PCS1) Video Conference
LAN Error in Sony PCS-1 Video Conference
Sounds like you are either working on a network which must provide you with an IP address automatically (i.e. not permitting static entries), or you are incorrectly configuring the information for your static address.
Is there a requirement to use a static address, or will DHCP work just fine?
Jul 10, 2009 | Sony PCS-1 (PCS1) Video Conference
Which mdel in Polycom is compatible with Sony PCS 1, which is better.
Basically every Polycom is fine - as long as software is a current release!
Dec 16, 2008 | Sony PCS-1 (PCS1) Video Conference
Sony PCS-1 dont remember admin password
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN
Clear setup and FINISH
Bye Zamani Ali
azamani@iooc.co.ir
Nov 24, 2008 | Sony PCS-1 (PCS1) Video Conference
Packet Loss and Video Freezing Up
hi artit,
I had the same problem with heavy packet lost after 10 minutes connection between Singapore and USA. We are using ADSL line and Sony PCS-G50 for video conferencing. After a much trouble-shooting, we identified that the nature of the problem lies with the Internet Service Provider's back-end server. The server has difficulties handling large and constant data packets. This could be due to the reasons that ISP using routers with more hops and small pipes. We immediately changed the ISP to a more reputated one (with better infrastructure) and now, we have a much better quality video.
Mar 10, 2008 | Sony PCS-1 (PCS1) Video Conference
PCS-1
Reset password sony pcs-1
PUSH ENTER button).
select Cancel using the arrow buttons, and press RETURN.
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
check for your lan settings, try to see if there is no nat on one of your network make the nat settings
Jan 11, 2008 | Sony PCS-1 (PCS1) Video Conference
Sony PCS-1 (PCS1) Video Conference Logo
284 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
