Question about Canon Office Equipment & Supplies
When we insert the printer cartridge into our canon mf4600 series fax machine it says 'Toner not Set' We have lost the cd and only have it in a foreign language. Can you help as there is no troubleshooting in the manual
  • 24 Answers
Well, is it a recycled cartridge or a new one? If it is recycledit's possible that the cip if it has one must be replaced! If the cartridge is the original one/it hasn't been changed before you may have a conatact problem with one of the sensors!
Posted on Nov 16, 2008
Change toner
Step 1 Check the top of your Canon fax/copy machine to see if your specific model has a protruding extension piece from the plastic delivery tray. Push the extension piece down if one is present on your model.
Step 2
Grip the bottom edge of the paper delivery tray at the front of the machine. Lift the tray upward to reveal the rectangular, plastic toner cartridge inside the machine.
Related Reading: How to Add Toner to a Canon X25
Step 3
Grab the handle at the top of the current toner cartridge and lift the cartridge upward. Pull the toner out of the machine and set it aside.
Step 4
Set your replacement toner cartridge over the empty space in the fax/copy machine. Ensure that the arrow near the bottom of the cartridge is facing down, and line up the protruding guide piece on the left side of the cartridge with the groove inside the machine. Push the toner downward until it snaps into position.
Step 5
Push the paper delivery tray back down, and lift up the extension piece if your model uses one.
May 06, 2015 | Office Equipment & Supplies
HOW CAN I SOLVE "THE TONER IS NOT SET INSERT THE TONER" ERROR ON MF3220 CANON, I've checked the sensor and cartridge gears.
TAke out the cartridge and unplug it and plug it back in and put the cartridge back in and see if thats the problem for you.
Dec 29, 2012 | Office Equipment & Supplies
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
How to insert a cartridge in canon printer 4320d ?..
Hold the front side of the operation panel with your hands.
Lift the scanning platform (A) until it is locked. (You will hear an audible "click.")
Hold the grip (A) on the right front side of the toner cover.
Take out the new toner cartridge from the protective bag.
Do not open the drum protective shutter (A).
Save the protective bag. You may need it later when you remove the toner cartridge from the machine.
Gently rock the toner cartridge several times to evenly distribute toner inside.
Place the toner cartridge on a flat surface and pull the seal completely out.
If toner is adhered on the removed seal, be careful that your hands or clothes do not get dirty from touching the toner.
Do not pull the seal out at an angle.
Hold the toner cartridge by its handle (A).
  • Do not open the drum protective shutter on the toner cartridge. Print quality may deteriorate if the drum surface is exposed to light or is damaged.
Always hold the toner cartridge by its handle
Insert the toner cartridge so that the protrusion (A) on the right side of the toner cartridge fits into the guide (B) located on the right side of the machine and slide it down parallel to the guide.
Push the toner cartridge to make sure it is properly set in the machine.
Close the toner cover.
Lower the scanning platform.
If you cannot close the toner cover, do not force it to close. Open the cover and make sure the toner cartridge is properly set in the machine.
Be careful not to get your fingers caught.
Dec 04, 2010 | Canon Office Equipment & Supplies
I am getting warning - Toner is not set insert toner. I have replaced the toner and nothing helps. What can I do?????
The best advice will be on the canon support page, look under FAQ, maybe even canon support forums
Jul 14, 2010 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon MX850 Empty Cartridge override
That code is "out of toner". I would try a genuine Canon Toner Cartridge.
Sep 24, 2008 | Canon FaxPhone L75 Plain Paper Laser
Toner cartridge
could be that the cartridge isnt seated correctly so the cover cant close
Feb 16, 2008 | Canon FAX-L350 Plain Paper Laser
91 people viewed this question
old marine
old marine
