I have a laptop and I need the software for TV, VGA, Audio, etc
  • 36 Answers
Are you seeking drivers that are missing or Apps to create these? I've always found it easiest to Google the specific driver or app I'm after then look in the forums or support areas to make sure there is no problem with the downloads!
Posted on Nov 13, 2008
What kind of cord do I need to connect my laptop so Netflix Movies can play on our T.V.?
Hi Candice,
First, without the model of your TV *and* laptop, no one will be able to give more than general information. It is much better to provide too much info than not enough - to get questions answered quickly here. With that said..
The short answer is that you need a cable that will connect to your note book (most likely either Video [yellow], S-Video, VGA, DVI, Display Port or HDMI) and the TV (most likely RF, Video, S-Video, PC / VGA, HDMI or RGB) Only the HDMI cable will provide sound with video. The others will require either an audio connection from the laptop (probably via a 3.5mm stereo headphone output jack) to the TV (most likely standard "RCA" jacks [red & white] - or settling for the laptop speakers or external amplified speakers plugged into the headphone jack.
If you are unable to locate a cable that has the connector supported by the laptop with a connector offered on the TV, it is likely because it is not possible to connect the two (HDMI to video, etc.) with only a cable. Additional hardware (probably expensive if available) will be needed to up or down convert & split audio to make it compatible.
Take a photo of the jacks offered by your laptop and those on your TV to a respected TV / Audio store / department for additional assistance. Some Radio Shack store employees are very good - and some are just plain horrible. Save your receipts in case it doesn't work to your liking.
Keep in mind that a $50 Roku box will stream Netflix (and a whole lot more) to most TV's "right out of the box" - or by buying $10 HDMI cable online to connect an HDTV. Don't spend 20, 30 or more dollars on an HDMI cable unless you want to pay too much!
I hope this helps and good luck!
Oct 22, 2013 | Computers & Internet
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
Would appreciate any advice on connecting cable etc. to connect my Compter and TV to display video/film downloads.s
The easiest connection is converting to VGA and using a standard headphone port-to-audio in. Your video out from the laptop varies by model, which isn't included here.
It will most likely be mini-VGA or mini-DVI
Nov 04, 2012 | Computers & Internet
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
Does my HP dv9449us has HDMI port? Can I connect it with my tv using this cable or what cables do I need? We have LG LCD tv.
Your laptop does not have a HDMI port. You only have VGA, you have to purchase a VGA to VGA cable VGA is video only interface. So you will need it along with the stereo audio cable
http://pctvcables.com/vga-with-audio-pc-to-tv-cables.html
Note that the stereo audio cable shoulb be connected from the headphones jack on your laptop to the headphones jack on you home theater system if you have one or buy this adapter plug the stereo audio cable coming from the laptop into it and connect it to the stereo audio in (red and white audio)of your tv
http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
Aug 18, 2011 | HP Pavilion DV6449US Notebook
Connect to netbook to lcd tv
hi mate what you need to connect your netbook is an vga cable which you can buy at asda or home bargins etc.
2 you wil need to get a audio lead which plugs in to your tv
this audio lead will need to have a red and yellow plug in which goes into your tv the other side is just like an normal black audio plug in like speakers
http://direct.asda.com/ASDA-VGA-Cable/000596699,default,pd.html
Aug 02, 2011 | Acer Aspire One PC Notebook
How can i connect my advent qrc430 to a hd television
There are two options available with this laptop. Unfortunatley you will not be able to produce a High Definition picture, but nether the less it is possible to connect it to a HD TV.
The connections available are;
1x VGA - You will need a VGA Cable (as long as your HD TV has a VGA/PC input) cheapest found on Ebay. There is also a VGA to HDMI cable. Still wont be HD but an alternative to think about.
1x S-Video (TV-Out) - You will need a S-Video Cable (make sure HD TV has this input) also cheapest on Ebay.
Both of these options do not produce audio through them so for this you will need a 3.5mm audio jack to 3.5mm audio jack. Plug one end into your earphone socket on your laptop and the other end into your HD TV PC Audio in socket/Audio in socket. If you have a Cinema/surround system you will need a 3.5mm audio jack to stereo phono, as long as the surround system has an audio input.
LINKS
VGA to HDMI cable: http://cgi.ebay.co.uk/1-8m-VGA-to-HDMI-Cable-Adapter-M-M-For-Laptop-PC-LCD-TV_W0QQitemZ350312945946QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item519047591a
VGA to VGA: http://cgi.ebay.co.uk/5M-VGA-SVGA-15-PIN-CABLE-PC-TO-TFT-MONITOR-LCD-TV-LEAD_W0QQitemZ330370826650QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item4ceba2c19a
S-VIDEO to S-VIDEO: http://cgi.ebay.co.uk/5m-S-Video-Svideo-SVHS-4-pin-Cable-Lead-Male-GOLD-16ft_W0QQitemZ360181396530QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item53dc7bf432
3.5mm AUDIO to 3.5mm AUDIO: http://cgi.ebay.co.uk/1-8M-3-5mm-3-5-Jack-to-Jack-Audio-Cable-Lead-Wire-Gold_W0QQitemZ270522394462QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3efc64275e
3.5mm AUDIO to PHONO: http://cgi.ebay.co.uk/5M-3-5mm-to-2-RCA-Stereo-phono-Audio-Cable-for-iPod-Mp3_W0QQitemZ250574651547QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3a5769c09b
Hope this helps. If it does please leave a thumbs up....Thank you.
Feb 04, 2010 | Computers & Internet
VGA and Audio cables connected to PC but no audio through TV
if your tv has vga input there should be a "line in" input very near it. VGA can only get its audio source through a "line in" connecting to the coaxial audio inputs will apply the music stream to a different video input on your tv. your tv has video 1, video 2, vga, and so on, but the vga cannot show video and then audio from the video/audio coaxial inputs. you will need something like a dual male tipped 3.5mm audio connector.
Good luck and pls rate this post
Mar 16, 2009 | HP Pavilion dv2000t Notebook
Can I connect my dell latitude d360 laptop to my tv?
you need to have the same connections on both my laptop has svideo or vga connector, some have Hdmi which is the newest, but the tv and laptop have to bot have the same connectors, it may be a dvi, or any that I mentioned, then you need a cable for your video, and another for your audio, both the audio and video cables are run to the tv, the only one that has both audio and video is the HDMI which tv's from the last hear or 2 usually do have. Then depending which input the laptop is using which it will tell you where the connection for the tv is, you set it to that input and that turns your tv into a giant monitor
Dec 22, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
