Question about Canon EOS 40D Digital Camera
Inside the room the picture is too dark even it is in full auto mode... or even when i use speed as less than 1/125 ... what should I do to take natural bright pic ?
    Champion:
  • 225 Answers
Use more light in the room.
Posted on Nov 13, 2008
Sometimes pictures are dark even in auto mode, err message is always coming, dark image in the view finder.
Hi dear pmorala
1) check
the lens if to drive the diaphragm actuating lever that opens.
2) also check the aperture lever on the camera body may be broken or bent.
3) look at the Shutter release the mirror and shoot the camera in a low speed (M mode) note if this works correctly or some of the leaves that make up the curtain is loose or out of place.
Everything seems fine ... OK command dial to select the full aperture, shoots the camera at you and see the diaphragm (set M mode and speed sh bellow 1 / 8). Full closed? = Aperture Mechanism defective.
Regards
Mar 16, 2011 | Nikon D90 Digital Camera with 18-105mm...
Canon EOS Rebel T1i won't take a picture when I zoom.
Which mode are you on? When you zoom in, the maximum aperture size decreases to f/5.6 in the kit lens. Sometimes it may be too dark or shutter speed too slow so the camera doesn't shoot. If you're in "P" (program) mode, full auto mode or any of the Basic Modes, the aperture/shutter is auto. In other modes (Av, M, etc) you can turn the dial on the top of the camera to adjust shutter speed to a lower number.
Jan 10, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
Same as posted - picture is way too dark when using flash. Help!
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
Sep 23, 2009 | Canon PowerShot A630 Digital Camera
Blurry pictures
Both of these problems are caused by underexposure. There are several causes for this. If you are set in AUTO MODE check the shutter speed and lens opening in the view finder. If the speed is less than 100 and the shutter is less than 5 and you are not using flash. You will probably get blured and dark pictures.  Practice shooting with your settings outside in sunlight , inside with lamplight, inside with flash and all of the above with motion. Check the exposure after each shot and make adjustments. In a short time you will get very good at setting your camera.
Dec 09, 2008 | Nikon D70s Digital Camera
Pictures too dark
The settings in Auto Mode are factory set. If you want to adjust exposure and shutter speeds then you will have to shoot in Manual Mode (TV=Shutter Priority, AV=Aperture Priority, M=Full Manual)
May 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Dim Photos
Put the camera in to the full auto mode. If the pictures are still dark, it is possible that the apature inside of the lens is not working. There is a micro-motor, gear assembly, iris leaf assembly, and a servo amp circuit that drives the apature. The servo amp is referenced from the uPC according to a routine that uses light and speed evaluation.
In actual fact, anything that has to do with the light measurement, lens apature control, or the main picture processing can make problems.
It is a common problem that people sometimes damage the lense from banging or dropping the camera, or it just fails.
You will most likely have to send the camera to Canon service to have it fixed.
Jerry G.
Oct 01, 2006 | Canon PowerShot G3 Digital Camera
Using Flash
The Flash is useful up to approximately six feet, after which distance the light is less effective. The Flash is good for close subjects in low light. The Flash is not good to use when taking pictures in large rooms with low light or night / evening scenes. When the Flash is used, the shutter speed is automatically faster to compensate for the light from the flash. This means less natural light through the lens. This can cause dark images in large rooms or evening scenes. In this case, TURN OFF THE FLASH and allow the shutter speed to automatically slow down to adjust for natural light. Your images will be more bright. Be careful, slower shutter also means more potential for blur from motion by you or your subjects.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Using Flash
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Using Flash
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Canon EOS 40D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
