Bosch wff2001 button not working - Washing Machines
3 Suggested Answers
  • 3600 Answers
SOURCE: Bosch WFF2001 can I use it cold fill only
Sure it will work but both fill hoses have to be hooked up or you have to buy a hose bib cap to place on the hot side to keep the water from comming out the other side.
Posted on Aug 07, 2009
SOURCE: Bosch WFF2001. Works OK
I had the same problem and I found 2 quarters in the water pump....
Posted on May 02, 2011
Does a wff2001 washing m/c work with only cold water supply
it can but you must connect both water valves to the water supply this is because most machines take just hot water on some programmes those above 60 deg just nip down to your local diy place and buy a "y" splitter screw this on to your cold water supply tap and connect both the hot and cold hoses to it then connect them both to the machine
Mar 03, 2014 | Washing Machines
Bosch WFF2001. Works OK in wash cycle but leaks heavily (from drum seal?) on rinse. Not from door seal. Any ideas?
This video will show you how to change a door seal on this Bosch WFF2001 front loader washing machine
May 02, 2011 | Washing Machines
My WFF2001 Bosch washing machine will not wash above 30 degrees. Previously, I had started a prog and immediately realised it wasn't the correct one. Stupidly, I turned it to the correct delicate wash...
Normally this must not happen but remove the plug and keep aside for the error voltage to subside in the processor controller.
Now after a few hours plug on the washer holding the stop /pause button.
Now check to see if the fault has cleared.
This is a case of errror when the program wa shifted and you can still repeat to unplug the washer overnight/24 hours.
Sep 18, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFF2001 - various problems
Replace the washer is my suggestion.
Jun 25, 2017 | Bosch Washing Machines
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch WF2001 washes only 30 degrees programmes
We had this problem and it turned out in our case that the hot water inlet filter was blocked. The pump wasn't receiving any hot water into the machine so wouldn't start on anything except a cold (30degree) wash.
We turned off the the hot water tap on the plumbing at the back, disconnected the inlet pipe from the machine, then put the end of the pipe in a bucket and turned the water back on, and saw loads of sediment spurted out.
We ran it until we'd filled the bucket, then turned the tap off, emptied the bucket down the drain, then disconnected the hose from the plumbing and cleaned the hose separately (there's a gauze at the plumbing end of the hose so make sure that's clean).
Then get some pliers and where the hose attatches to the machine there's a filter that you can pull out. Clean this out. In our case this was completely blocked with limescale sediment etc.
Reconnect everything, check it's all tightly fastened etc. then turn the tap on the plumbing back on - turn it on to a hot wash, press start ...and in our case it all worked a dream again.
All this info is in the manual if you've got one, but I thought I'd write it out in case you've got this problem and don't have the manual.
Ahhhhh... cleeean washing again! Hope this works for you. Happy go laundry!
Mar 04, 2010 | Bosch Washing Machines
Aug 07, 2009 | Bosch Washing Machines
Instructions on how to use bosch wff 2001 washing machine
hi if you look on the main bosch web site you can find a list of manuels for bosch washing macine witch are free to down load in pdf format hope this helps tim automan.
May 23, 2009 | Bosch Washing Machines
We have inherited a bosch WFF2001 washer> It starts washing but does not rinse or spin. We have left it an hour washing but goes not further.
hi sir  i thinkKeeping the dishwasher's sprayer arms, strainers, and water pump clean will help deter problems before they begin. Here's how to check on these important features.The heating element is used to help dry the dishes. In most dishwashers, the heating element fits around the screen in the bottom of the tub housing; it looks like an electric oven element. The heating element doesn't malfunction often, but it can burn out. If you suspect a faulty element:
thank u..................................please rate
Sep 11, 2008 | Bosch Washing Machines
Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
