Question about Logitech X-230 Computer Speakers
Computer stopped recognizing the speakers
I've had my speakers for 3 months and they've worked fine. Then a week ago they just suddenly completely stopped working. I can't even hear it w/ headphones. I've made sure that volume control settings are fine and that mute is unchecked. When I checked the Sound and Volume Settings on my Control Panel, the speakers listed were the old ones I had before these speakers. I've checked all the connections and tried unplugging the speakers multiple times, but nothing seems to work. Any help would be greatly appreciated.
  • 1 more comment
  • Anonymous Nov 10, 2007
    Having problems with my logitech speakers. They were working fine and then one day it they were not. I put in a new sound card thinking that might work fixed the dead pixels but not the sound. Any suggestions?
  • Anonymous Mar 20, 2009
    for no reason whatsoever, my speakers stopped working. connected different speakers, still nothing. spent hours on google, tried 30 different fixes, nothing. says i need so install multimedia controller. wtf? tried, but apparently not contained in xp. no codecs have fixed it. *blows head off*
  • Maartenvriel Apr 07, 2009
    Well I got almost the same problem, I plugged in my boxes and no sound at all, I updated my audio driver. My headphones do give sound. I got Windows XP and still it won't work
    Genius:
  • 2,985 Answers
Check the sound card system Can your hear through headphones for example?
Posted on Jul 24, 2007
Onn Wireless Mouse has stopped working. What do I do?
Mine would work fine until I turned on my wireless headphones...then the mouse would move a little stop.....move a little....then stop.
I made sure my headphones were on.
I turned off the mouse, moved the mouse reciver to a USB port on the front of my computer (the mouse reciver and the headphone receivers were next to each other on the back of the computer). I turned the mouse back on.
The computer imediately gave me the "installing USB driver" notification.
When it was complete....both played nicely together...no more problems.
Jun 28, 2012 | Computers & Internet
I bought this Acer aspire 7535g laptop off of my mum's friend which was in great condition when I bought it. The sound was perfect. Every driver was up-to-date. However now... 8 months on, the sound...
You can try booting a live linux CD or thumbdrive and see if that gives you sound. That will give you an idea if it's Windows or a hardware problem. If it's a windows problem try uninstalling and reinstalling your drivers. If that doesn't work keep searching around or just try a fresh install of windows.
Aug 27, 2011 | Computers & Internet
I've had my my Logitech speakers for a few months now and they've worked fine up until a few weeks ago. Now if I turn the volume up more than a quarter of the way the sound goes scratchy and...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 04, 2011 | Logitech X-540 Computer Speakers
Relatively new wall furnace suddenly stopped working.
if you are by passing stat at the gas valve and it is still not working,i would assume a bad control valve.
Jan 13, 2010 | Heating & Cooling
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
Laptop CD/DVD Drive
Hi RC2935
Try this and see if it will help you
Here is what you do  Click on start and then go to run type in regedt32 For Vista Click start and search for regedt32 and click on it
Go to the following HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the upper and lower Filter or witch is available close window and restart the PC it will work
This is common on the Acer, HP,Toshiba etc,etc
if you need help let me know
kind regards mervin
Sep 24, 2008 | Computers & Internet
Cruzier 4.0 pendrive is not recognized by my computer
the home computer has a small chip onits mother board called disk controller. its this controller which recognises it.so the software driver is corrupt and needs reinstallation or the hard ware controller is faulty.
Jun 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
You need to reinstall the latest drivers for your present sound device then restart your pc then check it. It will work surely! you should install the drivers that came with your sound devices! thats it!
Dec 07, 2007 | Polk Audio M3 Speaker
Logitech X-230 Computer Speakers Logo
418 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
