Question about Mitsubishi VS-45607 45" Rear Projection Television
'Scratchy' video I just picked this set up for free, and it's all hooked up. When I use the DVD, the picture is awesome. However, on my digital cable line it looks like I'm using a set of rabbit ears. The picture is very static-y.. I've changed the coax cable, and any splitters along the path.. Any suggestions? Thanks.
  • Kevin Andersen Nov 15, 2006
    I think I've sort of solved my own issue. Previously, I had the coax into Ant-A. Just for kicks, I moved it to Ant-B, and the picture is now clear as a bell :)
    Genius:
  • 1,153 Answers
Yes tuner problems, may need to replace.
Posted on Sep 21, 2007
Scratchy audio with movie recording. Reset does no good, nor does changing memory, input devices for cards, other resolution settings. Appears there is an electronic anomaly in the audio input circuit. Any...
Try this...put the camera on a hard surface or a tripod and shoot a video. Does the scratchy audio disappear? If so, the mike may be picking up the sound of your fingers moving on the case.
Feb 16, 2011 | Panasonic Lumix DMC-LZ7 Digital Camera
When viewing a video, the picture goes off for a split second then comes back
Play a new DVD because this type of problem occurs in the scratchy discs,if same problem with new DVD than check and clean optical pick-up,still the same replace pick-up.
Jan 22, 2011 | Sony Televison & Video
I cant find the av jacks to hook up my dvd player
This model doesn't have any A/V jacks. Many low-end RCA models didn't include any special features. They can only pick up signals over the antenna input. What you'll need to connect your DVD player is an RF converter, which takes the audio and video signals from the player and turns them into a channel 3 or 4 TV signal that the set can pick up.
RF converters aren't hard to find. Radio Shack, Sears and Wal-Mart all say they sell them, and you can certainly find them online. Hooking one up is just a matter of connecting the necessary cable to the player and TV, connecting the converter power and setting the output channel. Then put the TV on that channel and you're set. Unfortunately, this will give you lower picture and sound quality than you get from a TV that allows direct A/V inputs, but it's the only option.
Nov 21, 2010 | RCA F25422 25" TV
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
Are you truly free? If so, then answer the
Hello. Your digital TV is all set up to recieve the digital signal that is now the standard signal coming into your home. The old analog signal is history. If you still want to use your VHS/DVD recorder you will have to get a signal conversion box, at your local walmart or radio shack. This will take the new digital signal and convert it so your old analog VHS/DVD can process it properly. Joe
please rate my answer as very helpful....and free. thanks. Joe
Apr 26, 2010 | GoVideo Go Video DVD/VCR Combo
New dvd player does not show color in picture
HELLO
If it's made for the USSR market then it's possible the video is set to SECAM whereas you need NTSC. It may have a PAL or NTSC setting so try that.
Your TV should be set to AUTO to pick up the video (they normally are multi-standard these days). You may have another setting on your TV called "PAL 60".
As I'm not that familiar with NTSC equipment I can only guess (we are on PAL in the UK), but I very much hope I have given you some idea of what to look for and do! (:-)
ALL THE BEST!
Oct 04, 2009 | Televison & Video
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Just hooked up Coax cable; now talking is barely audible
is the center speaker turned up in the reciever speaker settings? each speaker can be adjusted to a level that is higher or lower or all the same as the rest. also is the dolby digital turned on in the reciever settings? and changing the surround sound pre set sounds can also improve the type of audio you are listening to in 6.1 surround sound
Dec 31, 2008 | Sony STR-DE597 Receiver
Video signal drops out
Well, I have a solution and a question. First, why do you have S-Video hooked up from the sat receiver? is it a non- HD unit? Does it have component out? if so use it. Next; your receiver, as awesome as it is,it is 3 model years old and the HDMI firmware that was used in 2005-06 was version 1.1 which unfortunately for all of us was a "failed" format when using DSS,Cable, or FIOS. The problem was passing the DHCP copyright protection format from one source thru another to a third. Sounds complicated, I know, but that's what the issue is. The Good news is; the human eye cannot tell the difference between 720p and 1080p on any TV set 50" or smaller, and that is a fact. and the 2600 would only convert from s-video to 1080i which is equal to 540p. So, to make a long story short and understandable, if you use a good quality component cable to your TV set (Monster, Phoenix Gold, Apatchure, etc) your picture quality will not suffer and there is no reason to be upset at your receiver since it was firmware provided by HDMI not Yamaha and was a problem on every receiver made with 1.1 firmware. So here's what you do Hook up your Sat receiver component (if you have it) S-vid if you have to, and any other sources that are going to pass video thru your receiver either s-vid,component, or standard vid. The only exception would be a blu-ray DVD. I would run HDMI direct to your TV, then run digital coaxial for audio to the DVD Digital audio input of your receiver. You have an awesome receiver that has lots of cool features and a bullet-proof electronics! enjoy it! Hope this helps. If you have any more questions, post a comment and I will help some more.
Jan 07, 2007 | Yamaha RX-V2600 Receiver
Mitsubishi VS-45607 45" Rear Projection Television Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
