My computer keeps asking me to insert the solution center disc. I am sure I got that with one of my printers but I cant locate it. How do I clear this so it stops coming up envery time I turn on my computer???
  • 461 Answers
I believe this is related to an HP printer installation. You need to identify the process and remove it from the startup. This should be removed when you remove the printer software (Control Panel >Add/Remove Programs or Programs and Features in Vista). An alternate method would be to use the MS Configuration Utility (Start>Run msconfig or type msconfig in search for Vista) then select the startup tab and locate the program and uncheck the box to the left. If you are no longer using the HP printer or bundled software I'd recommend uninstalling those first as it appears it is trying to install additional components.
In future posts please include your operating system and any specific details you have available.
Posted on Nov 15, 2008
How do i install
what are you installing??? if it's a printer, shut off computer,connect your cables,turn on power and insert driver disc if asked for,windows xp and 7 will detect your printer and load drivers or ask you to put in istall disc. then just follow onscreen instructions,, reboot computer.. run test page from printer.
Oct 02, 2012 | Office Equipment & Supplies
Can not get the OCR to work
Try to reinstall the OCR scan software by inserting the Lexmark installation disc that came with your printer into the computer hard drive. If you have a firewall enabled, make sure to allow all Lexmark scan and print processes in the program rules or permission.
If you lost the disc, please contact Lexmark Technical Support Center to request one for free.
Sep 28, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
When I scan a file to pdf and save it.....I can't get it to upload
Make sure the Lexmark OCR scan software is installed on your computer. The scan software can be downloaded using only the installation disc that came with your Lexmark printer. Just insert the disc into your computer hard drive and execute the file. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
Jul 25, 2011 | Lexmark X8350 InkJet Printer
When i turn on the computer the black screen with the compaq name comes up then a square box with the words power on password and a symbol of a key and cant get passed that
To clear the Boot password. Open the case and locate the small round disc battery. Next to it will be a small plastic jumper with a board label referring to battery jumper. The jumper sits on three pins and has only two contacts. Lift the jumper and place it over the other pin keeping the center pin connected when put back on. This will short the battery supported ROM memory which is set to ask for a password. Put the jumper back and reboot the computer. It will no longer stop and ask for a Boot password. If it stops and asks for a Windows Password you will need to go to a tech to have the password removed. (This is very simple to do with a Password CD in a couple of minutes)
Apr 14, 2011 | Computers & Internet
Cant play avitar on ps3
I suggest that you install the latest firmware update to resolve the issue. Please click here to download the latest firmware update.
It is recommended to use CD -R disc to create the firmware update disc. I hope you're clear with downloading the update from support page. Once you download and save the file in the folder in the computer, you can double click the file to extract. You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder.
Most of the customers will be making mistake here after .. We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image.
I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software. Open installed nero software from computer. You may locate it under Start Menu programs. Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option) Navigate the extracted .ISO file we saved in the computer. follow the onscreen instructions. Insert the disc when ever Nero asked to insert
Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
Jan 30, 2011 | Sony BDP-S300 Blu-Ray Disc Player
follow these steps
1. Disconect your printer from your pc
2. uninstall your printer driver from your pc
3. insert cd of your printer
4. run setup (with out connecting printer to pc untill setup ask you to)
If i had help you pls vote me
Oct 19, 2010 | HP Officejet 5610 All-In-One InkJet...
Hi ihave some virues on my computer becuse of that i am having trouble going to internat and i want to reboot my system i want my computer to its orginal programs and clear all files my computer
Restore to the earliest date you can find, or insert your operating system disc and re-install. If you do not have the disc you can find the installer on microsoft's website, but you need to make sure you have your Valid License Key: Which is normally located on the side of the tower. ie. Product Key: xxxxx-xxxxx-xxxxx-xxxxx-xxxxx Most commonly 25-characters. If your OS is cracked/bootleged this will not work unless you have your cracked disc.
Hope this helps! if you need any further assistance dont hesitate to ask!, and please don't forget to rate :)
Oct 07, 2010 | Dell Dimension 3100 PC Desktop
Box keeps coming up saying status and asking
insert hp vista printer disc solved problem
Nov 03, 2009 | Acer ASPIRE 5720-4649 Notebook
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service:
Oct 16, 2009 | HP Smart Buy Notebook
41 people viewed this question
