Question about Yamaha RX-V490 Receiver
Can you run 200watt 6ohm speakers on the RX-V490
I keep blowing speaker parts, 1 teeter, 2 woofers and an trying to solve the problem, playing cds through the LD section so we can watch dvd music.
    Problem Solver:
  • 4 Answers
Solution #1 is wrong. As you can see by the specs he provides, the Yamaha provides dynamic power reading for 8/6/4/2 ohm. I have Klipsch Kg4 (6ohm) speakers running on my Yamaha RX-V2095.
As far as amp power to speaker power goes. You are more likely to blow speakers using an underpowered amp and overpowered. If you go too loud using an underpowered amp it starts to clip the tops of the waveforms (distortion) and distortion causes the speaker's winding to heat and fail.
That being said. With 70W of power you shouldn't have any problems unless your speakers are "weak". If the blown speakers are isolated to a specific channel, you could have receiver-related failure, but I'm guessin it's your speakers.
Posted on May 13, 2009
  • Simon Baxter
    Simon Baxter Mar 05, 2014
    no... the 1st solution is correct. Check the rear of the unit, under the speaker inputs, it specifically mentions 8 ohms minimum.
    Problem Solver:
  • 20 Answers
Hi I have just read the specs on about your Yamaha system and you cant run 6 ohm speakers to your amp. You have to impedance match the speakers and the amp otherwise the speakers will "blow". So you need some 8 ohm speakers, the wattage of the speakers doesn't particularly matter as long as they are not too weak or too powerful becasue the amp will drive the speakers no matter what but if the speakers are of a low wattage then the amp could blow the speakers if it is turned up too loud. The specs of your amp are given in the link below.
Yamaha
Regards
Rob
Posted on Nov 13, 2008
Yamaha receiver keeps turning itself off model .RX-V490
Have you tried the unit without any speakers connected at all?
Oct 31, 2016 | Yamaha RX-V490 Receiver
Smoke started to come out of top of RX-V490 receiver, and now sounds a little more distorted than usual. Is the receiver salvagable, I know I triggered the protection circuit, but will it keep happening? I...
It all depends how much the amplifier circuit was damaged and how much you now push the system. It could be worth opening the unit and checking for any obvious damaged to components before you go any further.
As you've stated you want to run 4 speakers I take it you're not using the full 5.1 System.
If this is the case then the best/easiest option for running 2 sets of speakers is to get 2 Pairs of 4 Ohm Speakers and just connect them in Parallel to the Front Output which is rated at 70W + 70W (8Ohms).
If you need any further assistance of clarification just ask.
Please leave feedback
Cheers
Andy
May 11, 2011 | Yamaha RX-V490 Receiver
I have a rotel rb970bx. I have 2 and ran them in mono driving a speaker each. I tried to biamp the speakers with one amp driving the tweeters and one the woofers. This worked for about 4 minutes at 1/4...
hi
it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions
uprate the fuses till they stop blowing
Dec 21, 2017 | Rotel Audio Players & Recorders
How do I connect to my Yamaha RX-V490 some bose speakers. The ones that are only 2
Perhaps if you named the Bose system or go to Bose.com and find its manual.
Sep 05, 2009 | Yamaha RX-V490 Receiver
My RX-V490 Amp. has no audio from Centre speaker.
Is your center mode set to "Phantom" instead of "Normal" or "Wide"? That would split the mono Center channel program and mix it equally with the programs for both front speakers so your brain would believe it's in the center.
May 17, 2009 | Yamaha RX-V490 Receiver
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Yamaha RX V490 Turning itself Off
The amp is in protect mode which means that the output section has a problem. With nothing connected, there are defective parts inside the unit. This type of problem is not likely to have been caused by any shipping damage. I would guess that the output transistors are shorted.
Dan
Jul 22, 2008 | Yamaha RX-V490 Receiver
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
Yamaha RX-V490 comes on, goes off
More than likely its going into protect mode to keep from blowing your speakers. That pop noise is DC getting to your speakers before it shuts off i would recommend checking for DC voltage at the outputs first. If your not electronically inclined take it to a shop. Let us know :-)
Sep 15, 2007 | Yamaha RX-V490 Receiver
Yamaha RX-V490 Receiver Logo
357 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
