Question about Rockford Fosgate P3001 Car Audio Amplifier
RF P3001 power problems
Ok so i have a rf p3001 and i seem to have a sound problem or something because when it turns it doesnt produce any sound and when i try to turn the gain up to about half way the amp goes into protection mode.
  • poor man Nov 25, 2007
    my problem is simaler when the amp is hooked up it stays in protect mode and when i took the face plates off of it the d5 light was on witch says "short"
    also when the amp is on it turns off and on while in protect
    Problem Solver:
  • 17 Answers
Check your sub woofer connection if you have multiple subs the could be wired in a parallel or with has to many ohms that my cause it to not hit right and cause the amp to get really hot and cut in and out
Posted on Dec 10, 2007
I need a schematic for a RF p300-1 amp. Im trying to replace 2 of the mosfet semiconductors that got fried.
There are no schematics for RF amps, normally RF uses standard IRF Mosfets. Can you decribe the area where they blew, Power Supply are usually N-Channel high current type. Outputs can be either N-Ch or P-Ch depending on the Power rail there attached to.
Dec 23, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
P3001 problem
if amp is mounted to back of the box try and move to in front of box near subs or port. the air movement of the sub will help keep the amp cooled. or you can orer some 12v cooling fans and take back plate of the amp and cool it that way. or you can buy higher quality audio, your choice
Feb 20, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Panasonic RF-B65 short wave radio won't tune to frequency when turned on, just flashes 'E' and turns off automatically. Any suggestions ?
RF-B65 has a known issue with the power connector on side. It gets resistive from not being used. If you apply 6 vdc and it works, its most likely the batteries or the power connector. If both produce a "E" its PLL doesnt lock. Power plug most likely issue. Another issue is the tuning knob. It skips or jumps irratically. The up/down frequency changes are by a cube 1/2 inch square contactor. Its not optical. Just simple mechanical contactor. Remove the small cube from chassis and spray liquid gold. It will clean wire contactor and lubricate internals. You cannot buy the cube. Cleaning it always works for me. RF-B65 radio is a sure winner. Small, reliable and very sensitive. Has SSB also. eter
Sep 06, 2009 | Panasonic Audio Players & Recorders
Rockford fosgate p3001 lights up but around logo doesnt
check and make sure all powers (12v) and remote ground are were they should be then check signal outputs is in the right spot comeing from (THE Radio) to THE AMP imputs.THEN CHECK ALL OF THEM AGAIN. if thats not it you will have to bring it to someone like me and be charged around $30 an hour to fix.
Jun 12, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
What Hz do i use
The best way to set up an amp is to start with everything on 0 Turn your gain all the way off, then turn the stereo up as loud as u would normally listen to it. With the stereo on, slowly turn the gain up until it sounds the way you want it. As for the Hz settings, for a sub you should have the crossover set to lpf, and the z knob adjusts what frequency your sub will play. Since you have a 10" sub, I wouldn't put it much below 125, because tens can't produce ultra low bass and it could damage the sub. Hope his helps :)
May 02, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Contracts or expands, and just stays there
bad connection check spk wiring and rca out behind radio make sure connection is rite
Apr 04, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
P3001
Tighten very good the ground wire to your amp, then clean the metal where the ground attaches to the car chassis. Then tighten the ever lovin' bejesus out of the chassis ground. Yeah, I'm from the South :)
Good Luck!
barneyluc
Sep 28, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Amp turns on but doesnt power my subs
well ill need 2 know wat knobs are all on the front of your amp
Nov 07, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
P3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate P3001 Car Audio Amplifier Logo
235 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
