Routers
Problem for Routers
Generic problem for all Routers
DL-524 send mail
By stoyan on Nov 13, 2008
I cannot send a mail -- cannot receive SYN_SENT.
I have tested every thing on my router configuration.
May be the port 25 is not open on my router Dl-524
Comments:
Nov 13, 2008
- Hi Stellyx,
I use debian sid, Thunderbird (Icedove 2.0.0.17) client, but I've tested with other computers (windows xp, ubuntu).
I've tested different configurations on the router; filters, firewalls for port 25 (enable/disable, DMZ).
I think (I am sure) that the problem is in the router Dl-524 -- some configuration or ... I don't know.
Thank you very much,
Stoyan
Nov 13, 2008
- stoyan@backus:~$ telnet mail.... 25
Trying 205....... ...
telnet: Unable to connect to remote host: Connection timed out
From the other places (without using the router) this is OK
Clarification Request
Posted by Stellyx on Nov 13, 2008
Hi Stoyan,
just a couple questions.
What email service do you use?
do you use outlook or another program to access your email?
Best Solution
posted on Nov 18, 2008
Very Helpful)
stoyan
Rank: Apprentice
Rating: 100%, 1 votes
Thank you very much for the help.
I found the reason of blocked port 25.
It was blocked by my ISP. I could not imagine that ISP would like to block some ports, and I looked for my errors in router and computer configurations.
All the best!
Stoyan
Was this helpful?
Yes
No
Solution #2
posted on Nov 14, 2008
Not Rated)
stoyan
Rank: Apprentice
I have tested every thing. It is ok, EXEPT port 25. It is filtered (firewalled) by the router Dl-524. I can send request to the mail server, but I can not receive the SIN_SENT answer from the server (again on port 25). I have sniffed the connection.
I've restarted, rebooted, reset, reloaded the router configuration, the same.
Are there some info about this behaviour?
Was this helpful?
Yes
No
Solution #3
Not Rated)
karik
Rank: Guide
Rating: 70%, 1 votes
first of all you can check with enabling all ports in router for your perticuar IP.
If still it's not working, then check your mail server configuration i.e. SMTP mail server address, SMTP port number ,Antivrus Rule blocking on your computer.
Was this helpful?
Yes
No
Solution #4
Not Rated)
seamus_0
Rank: Apprentice
Rating: 0%, 0 votes
Are normal network services available to you:-
1) can you ping a server on the Internet?
2) can you browse the Internet?
3) Is the problem only email, if so do you know which mail server you are trying to access?
You shouldnt need to open up any rules in the firewall for SMTP, unless you are hosting a mail server. When you request mail from behind the firewall, most firewalls allow through all traffic from the inside network to the Internet. therefore, if you can see the Internet this is usually a good indication that theres no internal filtering.
all your mail client does is create a connection to port 25 on the SMTP server. You can replicate this by doing :-
telnet <MAIL SERVER ADDRESS> 25
you should get a banner or something up if you can see it. I dont think its a router problem if all other services are woking ok. If you get a banner from the above command, then its definately not a router problem.
ta,
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
I am trying to find my Security Key code. Is it stored in my computer or do I need to get it from my... (More)
Answer
it says it is connected but my laptop wont work i have a dlink dir-300 router
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 3663
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
