Question about Hannspree HI-221DPB Monitor
Hanns-G Hi-221DPB Black 22 power not working
I have 2 monitors hooked up to my computer, the Hanns and an Acer. One day I looked at my computer and saw the Hanns was turned on and appeared to be in sleep mode, orange light on the front. The power button does not turn it off, and if I disconnect and then reconnect the power it turns on by itself but goes back to the orange light.
SOURCE:
  • 71 Answers
SOURCE: My Hanns G LCD 19" Moitor issue
Have you tried reseting the monitor to factory defaults, or pulling the plug, waiting then replugging it?
If you can see a picture in a dark screen, it means the backlight has blown. These are special bulbs that may be difficult to find, or fully generic, but you will need to open the monitor, disassemble the LCD panel to get to the bulb so you know which type of bulb it needs. This is a moderately difficult task with fragile elements to remove to get to the bulb.
If you consider the monitor as toast and will not have it professionally serviced, you have nothing to loose by working on it, if you are handy with electronic tools, to use as a repair and learning experience.
Posted on Sep 01, 2008
SOURCE: monitor won't stay on
Hey. This problem is caused by the Backlight bulb(s) blowing up.
This is fixable. You have to get into the monitor and remove the LCD screen to see what bulb you need. This is a moderately difficult job and fragile parts will easily get broken.
However by all means have a go but this is the problem that you guys have been experiencing
Gareth162
Posted on Sep 02, 2008
sys_admin
  • 829 Answers
SOURCE: Monitor doesn't turn on anymore.
I think this should be a problem with the CPU and not the monitor, Is there a continuous beep sound coming , If so then there is a problem with the Memory.
Posted on Dec 16, 2008
byteguy
  • 2229 Answers
SOURCE: Hanns-G HW191D LCD - Image there, just not bright!
There is a flourescent light that backlights the screen. If your screen brightness control will not make the screen any brighter, then the backlight has stopped working. You will either have to replace that light or replace the monitor.
Posted on Jul 11, 2009
  • 732 Answers
SOURCE: I am owner of HANNS.G HW191D 19
badcompanyx, Your unit is in need of warranty work or servicing by a qualified electronics technician. Possible bad "intermittant solder connection on "switch-mode-power-supply"/"CCFL inverter supply" and or BAD "faulty" electrolytic filter capacitors that need replacing. 12fixlouie
Posted on Feb 03, 2010
Monitor wont stay on
turn off power saving mode on the monitor
Apr 10, 2016 | Hanns.G 22"" hi221dpb dvi widescreen lcd...
Can i hook up my xbox to a Acer V223W EJbd monitor
Yes, you can get a DVI or AVG connector and use those.
Mar 09, 2013 | Acer 22" V223W EJbd Widescreen LCD...
My Acer 22" AL2223W monitor display goes black after a few seconds, How can i fix it my self?
try hooking it up to another computer to ensure
it is not the graphics card that makes trouble...
if still the same prob, check the net if there are
known overheating problems for that model,
i personally recommend to see a technician, as repairing a monitor could make things worse...
up to u, good luck then
Sep 01, 2009 | Computers & Internet
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Hanns 17" LCD MONITOR
internal power supply failure,the AC power supply that powers the backlight fails every time you turn it on. Unfortunatly electronic repair is costly, A new monitor is cheaper.
Dec 25, 2007 | Hanns.G Corporation HU-196DP LCD Monitor
Hannspree HI-221DPB Monitor Logo
Top Hannspree Computers & Internet Experts
 Mike M
Mike M
Steve Allison
Steve Allison
DBurstiner
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
