Question about Sony Playstation 3 (PS3) Console
Hard disk corrupted
MY PS3 BEGAN PROMPTING "HARD DISK CORRUPTED" AFTER THE UPDATE FROM BROTHERS IN ARMS HELLS HIGHWAY. IT WILL BEGIN TO RESTART BUT AFTER REBOOTING IT STARTS ALL ONER AGAIN. ANY SUGGESTIONS?
  • 470 Answers
It's simple. I fixed it by taking the hd out and (optional) air spraying it. I then slid it in and turned my PS3 back on. After that it came up with the disk error, so I pulled the hd back out and started the recovery thing like normal. Here is the real fixer: a screen should pop up asking you if you want to format the hd, say yes both times. When it begins to do it, slide the hd back in and let it format. Then simply restart or let it restart and your set. It should boot up as normal. or
 reformatted it and then when he got home and put it back into his it asked him to reformat again and this did the trick. It's been working ever since. He called Sony and they wanted him to send back his hard drive and they would either fix or send him a "new" refurbished one for $150. I don't think so!!
Posted on Nov 16, 2008
My x box cant play this game...
The case was probably mistaken with, "The Brothers in Arms: Hell's Highway" for xbox 360
Jun 26, 2013 | Ubi Soft Entertainment Brothers in Arms:...
When I turn my PS3 on, it says hard disk file system is corrupted and will be restored, I press OK, it gets all the way to 100%, then it restarts and tells me the same thing. What do I do?
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, has crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
I have a slimline ps3 and my hard drive was corrupted so i downloaded a new system update it installed the update it let me adjust the time and date settings and just before it goes to the screen that...
  1. KINDLY REMOVE THE HARD DISK FROM THE CONSOLE
  2. LOOK FOR AN EXTERNAL HARD DRIVE PACK
  3. PUT THE PS3 HARD DISK INTO THE EXTERNAL HARD DISK PACK
  4. CONNECT IT TO YOU COMPUTER
  5. AND FORMAT IT.
  6. REMOVE IT FROM THE EXTERNAL PACK
  7. PUT IT BACK INTO THE PS3 CONSOLE AND TURN IT ON.
  8. IT WILL ASK FOR UPDATE
  9. THEN YOU UPDATE IT.
  10. IF AFTER DOING ALL THIS AND IT DOSEN'T WORK
  11. CHANGE THE HARD DISK INSIDE THE PS3.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Safeboot corrupted (error 92h)
Check the BIOS setting to see if the hard disk is detected. If not either the hard disk controller or the hard disk is faulty.
First thing I would try is to remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an external hard drive and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services.
Jun 24, 2010 | HP EliteBook 2530p Notebook
I have had this problem also. I fixed the x clamps, cleaned the laser, and I keep my xbox console open to keep it cool. Most of the time I will be in the middle of a game and it freezes. Other times when...
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
Apr 30, 2010 | Microsoft Xbox 360 Console
My ps3 says cannot start. the correct hard disk
Be sure to folleow these instructions to the letter, you could damage your PS32_bing.gif if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3 firmware has a “recovery console”.
You access it by
1. Start with having the system in standby (redlight is on)
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen.
www.youtube.com/watch?v=m0SPmkV-jco
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory, which is corrupt, thus solving the problem.
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
Blank screen on pressing play brothers in arms hell highway, Sound in background
Well your disc is officially garbage because it's scratched. Don't bother trying to fix your game disc. Do what I did. Go to sellitbroken.com and sell your game to them. They will give you good money for it.
Dec 31, 2009 | Ubi Soft Entertainment Brothers in Arms:...
"hard drive disk is corrupted, it will be restored" but it doesnt
I'm not 100% on this but this generally means that the hard drive is bad. You can try reseating it (open the door on the left side, take out the blue screw slide the HDD back and then reseat it) and it may fix it. Else looks like you may have to buy a new one. You can probably check the sony website for upgrades or look online to buy a new one. I don't think it'll be too costly.
Apr 28, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
