Question about HP Laserjet M2727nf Multifunction Printer
Scanner error 5 turn off then on
I have tried turning off and then on but this doesnt help. i keep getting the same error message on teh device display.
anyone have any advice on how to resolve this?
many thanks,
  • eva_chodkiew Nov 14, 2008
    thanks for a quick reply. better get going to buy a new scanner....
  • Anonymous May 20, 2009
    scanner error 5 turnoff & on
  • 89 Answers
Eva, This is a common problem with this machine and more than likely the scanner will need to be replaced. You should try calling HP and see if they will cover it since it is a common problem.
Posted on Nov 14, 2008
Scanner error 5 turn off then on - 45953811.jpg Problem with the HP HP Laserjet M2727nf Mfp Printer Scanner error 5 turn off then on
Posted on Sep 13, 2010
4 Suggested Answers
SOURCE: scanner error message hp laserjet 3030
This problem has to do with the scanner mirror. You may hear a grinding sound, also. The reason it does this is because the scanner bulb cannot find 'home', so it keeps trying to find it. Well, it uses the mirrors to reflect on another object inside the scanner to tell it when to stop. The mirror on top of the right next to the scanner bulb may need to be cleaned. This works every time for me, except the same problem always comes back sooner or later.
how to clean-
1.unplug your scanner
2.notice the glass covering on the left side, it can be removed with a Phillips screwdriver. Unscrew the plastic surrounding the glass and then remove the glass covering.
3.Plug the scanner back in and wait for the scanner to move left and then unplug it before it starts moving to the right. Repeat this until scanner bulb is all the way on the left of the machine.
-an alternative method-
with the glass covering removed, use a pair of pliers to move the small belt that moves the scanner bulb. keep moving it until the scanner bulb is all the way on the left of the machine.
4.With the scanner bulb assembly in reach, grab a Q-tip and gently clean the mirror that is just to the right of the bulb. You might want a flashlight to see the dirt and dust.
5. Put the glass covering back on.
6. Plug in the scanner.
At first to me it seemed like it wouldn't work, but it does.
Hope it helps. Reply back if it does.
Posted on Jul 23, 2008
  • 3 Answers
SOURCE: scanner error 5
It's a problem with the scanner unable to "see" its home sensor. The home sensor is a black & white film strip stuck onto the flatbed glass, just above where the scanner head homes. The printer needs to "see" the two little black 1mm square bumps in the white area. When the scanner head "homes", as it just disappears under the plastic it should move left and right as it looks at the home strip. If it keeps going and chatters at the right-stop it didn't see the home strip.
This can be caused by dirty mirrors, or lens in the scanner head (clean them);
Low or off color light (replace the bulb or high voltage power board on bottom of scanner head);
Broken, cracked, or loose scanner head ribbon cable (replace or repair);
Dirty or crooked home sensor film strip (I had one of these: the black & white film strip stuck to the flatbed glass was slightly crooked, it doesn't take much!)
Dirty slide bar (clean & oil);
Bad stepper motor, bad scanner PCBA (replace).
Posted on Jul 25, 2009
SOURCE: Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
Posted on Sep 01, 2010
Setup/configuration issue, error message, scanner error 0x10. How do I fix this?
unplug power at the wall outlet
wait 5 minutes
press and hold the power/on button for 60+ seconds
keep holding while plugging back in, and for another 60 seconds after, then release if that doesnt work it is an internal fault which would require repairs or exchange in your case
Jul 19, 2015 | Epson Expression Home XP-420 Wireless...
Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Nov 12, 2011 | HP LaserJet 3055 All-In-One Printer
The scanner suddenly stopped working - the error
try turning it off and on, if this doesnt help un plug cable and restart PC.
then plug cable back and and see if the PC will detect it then try again.
if the PC doesnt detect it then try different cable and if this doesnt help you will need to contact manufacturer.
Oct 31, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My M2727nf doesn't coppy or scan. message displays " error 5 Turn off and turn on." After turning off and on, it keeps displaying the same message.
Hi this is def a hardware failure:
Try doing a nvram
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work, have it serviced they will need to replace the formatter board as well as the scanner assembly.
If within 2 years from the purchase date contact HP and request for a case number the printer has a service note for a scanner error 5 or 8.
Oct 10, 2009 | HP Laserjet M2727nf Multifunction Printer
I am getting a message that says Scanner Error 5 turn off then on and when I turn off then on it will print one document and the message comes back up. Please help if you can thanks, KT
Try cleaning the scanner glass real good with alcohol. If that doesn't help, you may have to get a tecchnician to disassemble it to clean the underside of the glass and the scanner.
Oct 09, 2009 | HP Laserjet M2727nf Multifunction Printer
I have a ricoh aficio 2035 that reads error sc 546 problem
It is fuser code, to reset enter the sevice mode by pressing All clear 1,0,7 & Keeping Stop button pressing, Press the copy Mode, then OFF & ON the m/c, the code will cleared.
Aug 17, 2009 | Ricoh Aficio 450 Copier
Won't scan nor fax
HP multi units are notorious for scanner failures. It is just a weak component in their machines. I have seen this time and time again. The only solution is to change the scanner out or purchase a different machine. Just keep in mind the notoriety HP has which failed scanners. If you want to venture into the replacement of the scanner the following website might have the product you are looking for. Otherwise, search around the net for a scanner assembly unit for the OJ7310. But, be prepared scanner units are not cheap.
Check here
Nov 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hp laserjet m1522nf
Copy function was not working, says "device is busy". Message appeared on the printer screen is:"scanner error 5, turn off then on". This was done several times and message still appeared. I called 866-625-1176 and was connected with HP Technical Support and after 20 - 25 minutes of diagnostics, the technician informed me that they were sending me a new printer at no charge. I assume this meant that HP is aware of the defect and has no solution other than to replace it. The printer was only 6 months old.
Sep 05, 2008 | Office Equipment & Supplies
HP Digtal Color 610 copier
check that the long light bulb turns on...try bypassing the "door open" switches to do this.
Jun 08, 2007 | Canon PC-795 Copier
HP Laserjet M2727nf Multifunction Printer Logo
4,265 people viewed this question
Ben Johnson
