Question about Refrigerators
Squeaky Door on GE Arctica Refrigerator PSC23NGMB
The right french door (refrigerator side) on my Arctica refrerator makes a loud squeaking noise when I open it. I noticed on the bottom there is a plastic arm (parts guide calls it a lever assembly) that rolls around a cam closure on the door. I believe this is where the noise is coming from. I tried greasing it but the noise is still there. Does this part get greased or replaced?
  • Anonymous Jan 04, 2009
    squeaky door
    Problem Solver:
  • 19 Answers
Use Vaseline on the cam where the plastic slides across onother surface when opening door.
Posted on Nov 18, 2008
  • 833 Answers
Have you considered the strppingt around the door?  If so, you can use silicone spray for it or anything else around the fridge.  Wipe up excess.  There is a version of the spray which says that it is dripless.  I think I saw it at ACE.
Posted on Nov 15, 2008
Squeaky seal on lg french door
Just get some wd40 and spray the inches, as they have gone dry
Feb 16, 2014 | LG LFX25976ST 24.7 Cu.Ft. French Door...
Squeaky Suspension
HI MAX.ummm i think if u level it properly it will be ok.as far as i know cant oil suspension.hope this helps Ali
Aug 21, 2012 | LG LFX25960ST Stainless Steel French Door...
I have a new GE Arctica refrigerator in a condo I just purchased. Whenever I open then close the main refrigerator door the beverage door pops open. Many times this goes unnoticed for hours. Is there a...
Close the door more slowly.
What is happening is the air pressure does not equalize on a fast close causing the excess air to travel through least resistance.
Apr 15, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
Refrigerators Logo
661 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
