Question about Canon Office Equipment & Supplies
Canon Pixma IP4000 - will not print. Did maintenance cleaning and the 3E was not showing solid lines. Cleaned many times and finally took out ink & print head and cleaned off a bit and now won't show 3e lines at all when I print the nozzle check. Guess I'm off to buy a new printer. Any ideas?
    Problem Solver:
  • 14 Answers
Buy a new print head vs. buying a new printer. The iP4000 is a great printer with proven history. the latest printers on the shelf are disposable and you will be buying a new one every 2-3 years. The print heads are available through other vendors besides Canon direct. Try this website to see if they have your print head and their prices. PrinterFixer.net
Posted on Nov 14, 2008
    Novelist:
    Scholar:
  • 125 Answers
I'm not sure what you did. We have 3 MP780 and IP6000 and 9000 printers. The frequent problem have is streaking usually w/ refilled cartridges and even new cartridges. This is what we usually do:
1. Take the printhead out and dip it in 1-2mm depth hot water. Hopefully the water changes color and clears up the clog. Keep the Circuits dry. Wipe off excess water when you are done.
2. For really difficult clogs, if the hot water doesn't work I find a small rubber hose and syringe that encloses(meaning air tight) the mesh in the printhead where the ink goes in. I then pump air in to clear out the clog.
3. Since you have to do it for the Black 3e, you might as well do it also for all the others to make sure they are not clogged.
Make sure when you pump in the air the syringe is not touching the mesh in the printhead. If these don't work then you can try borrow the printhead of another printer and testing it out. If it works then you need to buy the printhead. If Canon has stock, you should get it fast. If not, and you really need to print either go to a printing service or buy a new printer. Good luck.
Cartidge 3E Black not printing
make sure the smaill tape on the ink cartridge is peeled off.
Jul 25, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Only black ink won't print. Even with new black 3e and new black 6 cartridges.
The black ink is a pigment based ink, that is it consists of particles suspended in a solution. The colors are dye based and have no particles. This being the case when the black ink dries and clogs the print head the particles are left behind. I would suggest removing the print head and letting it sit on a paper towel moistened with warm distilled water. Do this on a surface that is both waterproof and disposable, i.e. a plastic disposable plate, since the hope is that ink will flow out. Let this sit for about 20 mins, reinstall print head, making sure the electrical contacts and clean and dry, then the cartridges and try cleaning cycles again. If still no luck replacement print heads are available at the address below.
http://www.precisionroller.com/print-heads-for-canon-pixma-ip4000/products.html
Jun 11, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
IP4000 - How can I force the printer to use the large black (6) ink cartridge?
Do you mean the large black ink as in the 3e vs. the 6? If so, the large black, 3e, is a pigment based ink and the printer should only use it when print text and black and white things. The 6 black is a dye based ink and the printer should only use it when printing photos.
Jan 14, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Cleaning/replacement of Nozzles of Pixma iP4000 Canon Printer
My Canon Primax ip4000 has stopped printing blue. I've tried deep cleaning and when I print a test page the blue 6c does not appear. Any ideas what the problem could be?
Nov 01, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
When printing pictures, there are faint white vertical lines on
Cleaning usually doesn't help that printhead much. A new one QY6-0049-000 is around $40.00. You remove by lifting the gray handle on the left after removing all the inks.
Jun 30, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Fine lines on photos
how many times have you cleaned the printer heads? most of the time it can take up to 10 times before the ink will run clear again, the only problem is the amount of ink it uses to do the head cleaning
Mar 23, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Waste ink absorber full on canon pixma ip4000
cannon pixma ip4000 waste ink absorber is almost full what do i do, getting patchy printing, have cleaned and deap cleaned and this hasn't ;helped
Jul 23, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
Jul 12, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
192 people viewed this question
old marine
old marine
