Question about Dell 926 All-In-One InkJet Printer
Dell 926 Printer ink refill instructions
Diagram Series9 MK991 Dell ink cartridge refill instructions , What hole for
what ink . dont now what ink goes in what and where The black ink cartridge (model MK990) in my Dell 926 All in One printer is empty. Instead of buying a new one I purchased a Nukote ink jet refill kit. The booklet did not have instructions to refill my cartridge model. What do I do now?? How do I fill it??
  • gooche May 11, 2010
    I cannot get my ink carriage in front to place the refills. help!
    Novelist:
  • 148 Answers
One other trick you can do is to insert a wooden toothpick in the holes and it will show you the colors.
Be mucho blessed,
Mark
Posted on Nov 14, 2008
    Novelist:
    Scholar:
  • 125 Answers
I don't have a Dell but we have Lexmarks which use similar cartridges. I'm guessing your color and black has a flat top. Your printer should be using a 2 cartridge system and most likely w/ 4 colors. Black, Cyan, Magenta and Yellow. The Black cartridge is a single color cartridge. The CMY (short for Cyan,Magenta,Yellow) is in another cartridge. If you don't know which one, get a paper tower and dab the bottom of the cartridge near the nozzles which are usual silver in color. If you have the color you now need a very thin needle to fit those very small holes. If your needle wont fit then you will have to enlarge the holes. To refill,you really will enlarge it anyway to inject the syringe needles in. Stick the needle into the hole as deep as you can and stop just before you hit bottom. Just approximate the height of the cartridge to the needle. When you take the needle out, use a paper towel or toilet paper to wipe off the ink. What you wipe off will be the color of that chamber. You just need to do one more on any of the 2 remaining holes. Label as you go so you know what color it is. Don't do mental gymnastics. One mistake means you either print w/wrong colors or buy a new cartridge. I'm not familiar w/ the cartridge so I'm guessing on the color you should put between 1-2ml of ink per color. On the black maybe 5-8ml. This is to be on the safe side. Don't overfill it. There's no guarantee your cartridge will print, cuz manual refills are not as good as those done on a machine. If it works you may be able to refill another 2-3 times. Manual refilling is a gamble. Just ink the ink in very slowly and be patient. take about 15-20 seconds to inject 1 ml. Hope this helps.
    Problem Solver:
  • 8 Answers
I want to know how many contanners the printer users.
i don't have this type of printer, but this is waht you are going to do. take one of the empty cartridge and scratch the nuzul on a what peace of paper. this in most cases will give you small lines which you can use to identify the colour.
if you can do this it will help you
go to a shop with the printer number, where they sell printer cartridges. Tell them you want one of the cartridges, if they have take a close look at them and tell you will came back later but ask them how you will know the black ink since you want to buy that one.
in this way you can identify the two
thank you
After installing new ink cartrige , low ink warning continues to appear. why and how do i fix this issue
Using generic or refilled Dell Series Ink cartridges will always give the low ink message.
To remove the message, try the Dell Series brand from Walmart Staples or Dell's website.
Article on refilling Dell ink cartridges
Rick
Sep 12, 2011 | Dell 926 All-In-One InkJet Printer
*see the manual and follow the instructions and fill it
* contact manufacturer about details
Jul 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    I refilled my dell ink cartridges from Costco. Now my computer says "Low ink warning" How do I do a hard reset for the Dell 926 AIO Printer?
    The ink is fine in the cartridge. The ink level indicator just thinks the cartrdige is still empty. You can ignore the message or turn it off all together. Just bring in your cartrdige for a refill when it shows signs of fading or streaking. Go to www.inkjet411.com for more help
    Mar 10, 2010 | Dell 962 Photo All-In-One InkJet Printer
    I just had my cartridges refilled but my printer still says low ink i used my old cartridges from dell how can i get my 926 printer to work with the refilled cartridges it will not print.
    With this type of cartridge your printer will always think refills have low ink. This is because the electronics on the cartridge cannot be reset to tell the printer it is full of ink. However you should still be able to print and just ignore the ink levels. I think the problem you are having is that the electronics on your cartridge are no longer functioning. Unfortunately there is no way to fix this problem. I know you can buy refills from Cartridge World stores, but I don't know about other retailers.
    Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
    Dell series 9 refill and low ink warnings
    The series 9 cartridges can be refilled. As long as the electronics are still functioning on your cartridge you should be able to print no problem. There is no way to reset the ink levels on these cartridges so you will just need to ignore the ink level warnings. I would recommend Cartridge World for ink refills. Many other stores and on-line sellers don't do the cleaning, vacuum filling, electrical testing, and print testing that Cartridge World stores do to make sure your cartridge works.
    Apr 02, 2009 | Dell 926 All-In-One InkJet Printer
    Dell 926 injection refill kit didnt work
    The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
    Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
    How to install hp 21 cartridge into dell 926 printer
    Use only genuine cartridges with your printer. Printers these days have a built in sensor that can sense non compatible/generic/refilled cartridges and wont install them. It will only cause you more problems in the long run if you use a generic cartridges.
    Best bet is to buy genuine inks..
    Sep 28, 2008 | Dell 926 All-In-One InkJet Printer
    REFILL INSTRUCTION
    No. there is a refill hole on the bottom of the cartridge. If you are uncertain, take it to a walgreens photo center and ask them to show you where the refill hole is.
    Mar 07, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Go to this webpage: http://www.ldproducts.com/Dell-Ink,Photo-all-in-one,926,Ink-Cartridge,3234,printer.html Click on the links for InTec Refill Kit for Dell MW175 Black and InTec Refill Kit for Dell MW174 Color. Scroll down to Specifications and click on the Instruction Video link for each. That should help some.
    Feb 25, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Dell 926 All-In-One InkJet Printer Logo
    773 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
