Ethernet controller my ethernet controller on my computer is not finding and it cant connect to the internet what do i do
    President:
  • 1,314 Answers
You need to replace your ethernet controller. If it is built into the motherboard, simply add a pci version to one of your available pci slots and install it.
Thanks and please take a moment to rate as fixya.
Posted on Nov 13, 2008
Trying to connect to internet cant find wireless & cant find a ethernet place either
The laptop in question does not have a place to plug in the ethernet cable. The laptop is not fitted with wi-fi or bluetooth adapters either. The best and cheapest way to connect this laptop to the internet is using a PCMCIA Card Adapter (type two or three as both are supported.) such as the product supplied by linksys. If yours is similar to the one in the photo then it should include a cable with the required network connection on the end. The "linksys" card you mentioned is no doubt the correct one, but minus the vital cable!
May 20, 2016 | NEC Versa LX Notebook
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
your explanation is very confusing. your internet connection must come from a modem either directly or remotely thru router. your mentioning of hidden drive does not make sense. drivers are not part of internet connection. you need to reset the modem and router if you are connecting through it. turn everything off. unplug router and modem. after 15 seconds unplugged, plug only modem in, wait until lights stablize; now plug router power back in, wait for lights to come on;,next turn PC on. Wait until completely booted up. go to control panel click on Network Internet, when opens try to find the local connect to network. if none, then your modem is not receiving signal or IP Address from your internet provider(comcast,centurylink, whoever). check status, if active fine. if active but icon says no internet access then your router is not set correctly. you may have lost its set up and you will have to reset up your router. you should have the step or instructions for doing that. after resetting and network active, restart computer so that is receives fresh settings from router.
if no network is found after restart you may have to reconfigure your internet connect by using the internet connection wizard(control panel).
Sep 27, 2012 | Dell Dimension B110 PC Desktop
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
I;ve reformatted my drive ,and i can't connect to the internet because i dont have a ethernet controller....................! How can i find a solution so that i may reconnect to the internet?
You need to install the drivers on your computer Goto your computer manufacturer website and select your Model num ber to download the Chipset drivers, Ethernet controller, LAN drivers etc...
Jul 07, 2011 | Computers & Internet
I'm not able to connect with my ASUS M50vm to ethernet. how i can check if the hardware is working?
May 16, 2011 | ASUS Intel 440BX Chipset P2B-VM...
I can't find driver for onboard ethernet(RLT8168) for MSI MS-7592 Motherboard
Apr 13, 2011 | Intel Motherboard
Cannot connet ot interner
check the driver of your network controller, go to device manager, to access this, right click my computer then click device manager tab then find network controller then click + sign preceeding of that. if you notice that there is yellow question mark of the network, you need to install driver so that you cant connect to internet
Oct 12, 2009 | Computers & Internet
My computer cant connect to the internet after i installed windows 7
try instlling a different browser like mozilla firefox and opera or google chrome and check
Apr 22, 2009 | SMC PCI-X Quad Ethernet Controller (p/n...
LOST ETHERNET DRIVER
If you have the "Windows XP" operating system then follow these instructions...If you have a second computer with an internet connection then you can search on the internet for that driver...type the make and model of your computer plus the word "ethernet driver" and after you find it you just download it into "My Documents"...after that, copy the driver onto a blank CD disc...Take the CD and put it into your notebook and it should open and extract the file ..If it doesn't open up when you load the CD, go into "My Computer" and then double click on the "CD/CDRW/DVD/DVD-RW drive...restart your computer and remove the CD from the disc drive...Now plug your DSL into your ethernet port and see if it works...if it still does not work then go into "Control Panel" and then "Network and Internet Connections" and then "Network Connections" and then "Create a New Connection" and then follow the instructions...restart your computer and see if it finds the ethernet port and receives the signal through the ethernet cord
Apr 18, 2009 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
