Question about Asrock 775i65GV Motherboard
No display i install the new graphic card in this board, when i turn it on there is no display in the monitor, i already thry the new graphic card in the different pc and its good, when it came back to this board, the same problem appear, there is no display when i turn on the pc.can you help me in this problem graphic card model is FX5500 agp8x 256mb 128bit
    President:
  • 2,351 Answers
Hi st_niclaus,
(Note: ASRock does not list the FX 5500 series AGP graphics card on their web site).
To confirm this please see the VGA supported list at ASRock, click this link:
http://www.asrock.com/mb/vga.asp?Model=775i65gv&s=775&c=VGA
There is an order that should be followed when upgrading from using the onboard video to the AGP card.
Check your bios setting. See Init. Graphic Adapter Priority page 27 & 28 in manual.
Set to: [AGI/PCI/Onboard].
Also see instructions on how to install, AGI slot: on page 17.
AGI = ASRock Graphics Interface.
If your display still does not function after making these changes, it is possible your FX 5500 is not compatible with your board.
(Suggest you buy one from the list provided by ASRock's supported link above).
Good luck st_niclaus!
Mike
Posted on Nov 14, 2008
PLEASE HELP .QUESTION BELOW
Did you move the lead between the computer and the monitor onto the new board you installed?
Mar 09, 2015 | Computers & Internet
How do i find in my mother board graphic card installed
Follow your motherboard manual's instructions to enter the setup CMOS. look for the option that lists the on-board functions, such as video or graphic card. If your motherboard has the video card on-board, there will be an option to enable it or disable it. Set this option to "enable" if it isn't already. If your motherboard does not have on-board video, it must have a video card installed in that slot. In either case, if you have a monitor display when you turn on the computer, your video card IS enabled.
Oct 06, 2010 | ASUS P5GD2 Deluxe Motherboard
Nothing shows up in the monitor even the cpu on
Install a new graphics card and plug your monitor into that new video card. Do u get video output? If not, the problem is the system board.If u do, the problem was the graphics card.
Mar 15, 2010 | ASUS P4S533-MX Motherboard
Installed the board, scren displays message no signal and stays black. no peeps or beeps. usb has power so do drives and signal leds
Check the cable between your monitor and computer. If this is a new install and you have added a graphics card, you will need to boot up once using the on-board VGA. Doing so will allow you to turn off the on-board VGA in the BIOS. Then you can shut down and move the monitor cable to the new graphics card and reboot.
Dec 05, 2009 | MSI G31M3-L V2 Motherboard
Hi i have just bought a new radeon x1650 pro 512mb graphics card and ive removed the drivers from my last graphics card and placed the new radeon into my computer. but when i turn it all on to install the...
When the card is properly installed and the system properly configured, you should at least be getting the POST screen, since that is not driver dependent. And Windows knows to go to the default standard VGA driver when it can't find specific drivers for a card. So we're looking at a hardware issue, not software.
Here are the troubleshooting steps I would take. Some would seem obvious and you've probably already tried them, but I like to be complete:
Is the monitor switchable betwwen two inputs? Do you have it set to the correct input (i.e. VGA vs DVI)? hit the selection button on the front panel, just in case.
Is the card properly seated? Take it out and put it back in. Also, oddly enough, reseating RAM can fix a lot of problems, even seemingly unrelated ones.
Is there an on-board VGA connector? If so, switch over to that and see if you get picture. Then go into CMOS settings and look for a video setting that would make the add-in card the default display. Or simply disable the on-board VGA.
Check the pins on your monitor connection, make sure none are bent.
If none of these get you a picture, I would suggest a defective graphics card.
Jul 22, 2009 | ATI RADEON X1650 Graphic Card
No picture in windows after I install Graphics Card Driver
did you insert the G-card good in the pci-e slot(is the card new? can be it is wrecked,normally it runs witout installing the drivers but only in VGA mode,thats all i can tell u,exept you unplugged a cable on the motherboard for the pci alimentation?
by xenon
Mar 31, 2009 | Leadtek WinFast PX8600 GT TDH 512MB...
Motherboards is running but no display..
mother board have a problem,if warranty is still now u sent mother board service center,my friend is same problem,he send mother board and now it is ok.
Mar 31, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
Just installed ASUS N7600GS/HTD/256M GeForce
Let's try this:
Remove the new board from the machine, boot up into the BIOS and disable the onboard video, save your changes and power down the machine (unplug). Reinstall the board and boot her up.
Post your results here so we can further assist you.
Mar 04, 2009 | ASUS N7600GS/HTD/256M GeForce 7600GS 256MB...
Display adapter disappeared
Hello.
After installing new windows you should install all drivers needed by you computer. You should have a a cd utilities nvidia graphics card if you have not then you scan the driver it in web. try search in this website.
http://www.nvidia.com/Download/index.aspx?lang=en-us
if it is build in to the mainboard better go to the manufacturer website of your board. hope this help
melnavz
Mar 31, 2008 | ASUS A7S8X-MX Motherboard
Asrock 775i65GV Motherboard Logo
253 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
