Question about Cameras
Zoom and focus jammed - Cameras
    Champion:
  • 225 Answers
You can try to pull the lens back into its socket, or replace the lens.
Posted on Nov 13, 2008
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Fuji film finepixF480 showing focus error
Possible that the lens mechanism is jammed , sometimes the flexible connector of the lens focus/zoom can be faulty.You try to check for some tips from the link below; http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 30, 2011 | Fuji FinePix F480 Digital Camera
The Zoom in and out has stuck on the camera. Would that be whats causing the pictures to be blurry?
The focus is not guided by the tele/zoom and irrespecctive of it the camera must focus sharply.
If the zoom is not working( auto) then it is also possible that the servo to control the focus( motor drive) is also not working.
Hence your picture stands off focus.
Remove battery and replace gently tapping the lens hood to see if therer is any mechanical jamming of the drive.
If there is not help then you might need to open the camera but my advice is to take help to open and look. Check first for the motor /motor drive to be intact , checck voltage to motor on triggering of the key, if voltage is present motor mechanism needs a reset. If not the control circuit is faulty.
Sep 18, 2010 | Sony Cyber-Shot DSC-S30 Digital Camera
Jammed projector lens infocus lp770
get a wide bladed flathead and find the widest part of the **** between the focus ring and zoom. work the blade like you are trying to widen the the slot, do this all the way around till it pops back into place.
May 31, 2010 | InFocus LP70+ Multimedia Projector
Compact digital camera; zoom blur images. what am I doingwrong?
You may be doing nothing wrong, however the camera is either having trouble with the focusing circuitry/lens assembly, or you're not holding the camera still enough, with a solid focusing object (not likely, but happens). I suspect that some aspect of the focusing circuitry (while zoomed) isn't functioning. While that can be a microprocessor problem, it's rare and not likely. Most likely there is debris (dust, sand) in the lens assembly, and needs to be blown out with compressed air. If that doesn't work, you can try to zoom, then hold the camera with the lens facing up, and bump it gently with the palm of the hand, on an area without switches. The focusing ring inside the lens assembly is sometimes stuck, or jammed by debris, and can be freed by compressed air. Bumping the camera tries to reseat the focusing ring, so that it works correctly, from the cpu signals, and focusing detector. If these suggestions don't work, it will have to be serviced. Make sure you get an estimate first- the cost of repair often exceeds replacement cost of a new camera, on sale. Good luck!
May 20, 2010 | Kodak Easyshare M580 Digital Camera
My handycam resulation is blerr if i do maximam zoom
The worm drive on either the focus or zoom motor jammed, Most likely the focus. They sometimes can be freed but 1st make sure you are not in manual focus. Larry's Electronics
Apr 26, 2010 | Panasonic SDR-H40 HDD Camcorder
My Sigma 24-70 2.8 macro auto focus keeps jamming
Is the manual focus working ok if so the AF motor is faulty may need new gears or new motor
Dec 16, 2009 | Sigma 18-125/3.5-5.6 DC Aspherical IF Zoom...
Viewfinder jammed
The mechanical link between Lens on V/F element has broken - Only Olympus will be able to do anything for you -check out the support site.
Aug 19, 2007 | Olympus Camedia C-5050 Zoom Digital Camera
Cameras Logo
106 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
