When I release the sewing pedal it just keeps on sewing quite madly! If I tap down on the pedal or switch it off it will stop.
SOURCE: foot pedal dead, machine keeps sewing!
There is no suppressor in the foot control of a 425. Only the control unit, which may need to be replaced. If the machine accelerates to full speed, it may have a problem with the "stop right" board which tells the machine whether to stop with the needle up.
You could have several problems, so go see a qualified Husqvarna repairman. You may contact Husqvarna customer service to locate the best one in your area.
SOURCE: Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
SOURCE: Husqvarna 2000 sewing machine foot pedal stuck on but not pressed
you may need to take foot pedal apart and clean it the contacts inside may be dirty and causing it to stick
SOURCE: singer 522 starts sewing at speed without the
Undo the foot control and take out the small square suppressor and throw it away, you don't need it anymore.
