Question about GE WBSE2090A Top Load Washer
My GE washer machine is spitting brown oil onto the clothes.
I'm not sure if it's happening in the wash or the rinse cycle or when the water is on cold or hot. The oil is coming from inside, underneath the agitator in the bottom of the clothes barrel (drum). Also, when you open the lid when the cycle is finished, you can smell an odor of old oil. Where is the oil coming from and is it an easy fix or it time to get a new machine?
  • Anonymous Dec 08, 2008
    I am having the same problem and would like to know if it is easy to fix myself. Also, any suggestions on stain removal? Many clothing items ruined already.
    Brigadier General:
  • 6,966 Answers
Initially and based on your description, one strong possibility is that the seal on the bottom of the drum is faulty. This seal acts as a cover for the bearing underneath. Although this is repairable, most techs would not go through the trouble of replacing the bearing alone since it is force fit into the drum. The normal procedure is the replacement of the entire drum assembly, rather expensive. Due to this your posted comment of considering purchase of a new unit may have more merit. Depending on the design, in some other versions, rather than the bearing, it could be the differential.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 13, 2008
Washer continues to run
Ok. So you are getting ZERO water in the washer or just in the rinse cycle?
Apr 07, 2014 | GE Washing Machines
The wash cycle is not working. It doesn't agitate. Then the water drains and starts the rinse cycle. Then the spin. The spin cycle doesn't get all of the water out of the washing machine. Laundry...
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Nov 29, 2010 | GE Washing Machines
All our whites are now greys washing with our GE WCVH6260
graying of clothes is usualy caused by / serveral things . too much soap / washer not rinsing properly / and gas dryers. change your dergt. use one with a bleach in it . and use 2nd rinse ( cold water ) make sure washer drains wash water completly . do this by cking the drain pump clean out .. if cloged it will slow the drain cycle and you will be rinsing with the wash water . also use H E dergt. . if dergt is still in clothes when drying this turns nylon yellow and whites gray .. .also seperate colors . and whites .. **** ..
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Brown stains on clothes
Sounds as tho there is an excess of fabric softener build up on the inside of the outter tub. Try Filling with Hot water and bleach and let set for an evening and then turn back on and e tcontinue washing thru cycle.
Jan 31, 2010 | GE WHRE5260E Top Load Washer
My GE washing machine drains the water after the rinse cycle but does not start spinning. It just sits with the water pump running and does nothing. This doesn't happen with every load but seems to be...
Most likely the tube from the tub to the water level switch is full of "gunk" so the washer still thinks there is water in the machine, and therefore will not spin. Take the front panel off by pushing in the retaining clips at the top seam between the front panel and the washer top. Pull the thin hose off the left side of the tub and clean it out. (or cut off an inch or so, but you can only get away with that once or twice). To help prevent re-occurance, every two or three months you can fill the washer to the lowest level with hot water and several cups of bleach (no clothes) and run it through a cycle. Rinse at the ex-large setting to make sure all traces of bleach are gone before doing another load of laundry.
Nov 12, 2009 | GE WDSR2080D Top Load Washer
Washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Mar 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
Rinse Cycle
Is this a fairly new Energy star machine? If it is the rinse cycle is a spin only cycle with several spray rinses.
You may have an option switch that gives you a Fabric softener option, use this option and you will have a deep tub cold water rinse.
Make sure you are using He detergent.
If you have soft water use less detergent
Let me know if you have further questions.
Your sales rep should have told you this!
May 04, 2008 | GE WBSR3140DW Top Load Washer
its probably normal as new machines now only put in enough water to saturate the clothes its only the rinse or wool/delicate cycles that use a higher water level
Mar 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE WBSE2090A Top Load Washer Logo
340 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
