Question about Microsoft Windows Server Standard 2003 for PC
Server will not pwer up
New server computer system purchased three months ago. The machine was turned off during the weekend, and was moved to another floor of the building. The computer will not power up when it is switched back on. All power, network and computer connections have been checked to ensure that they are securely fixed.
    Problem Solver:
  • 9 Answers
Hi Angealaaus,
I think one of your major hardware has been a bit loose inside your server when you moved it down to another place.
If your computer does not power up it may happen that the internal wire which supplies power to the motherboard is loose.
If your computer powers up but does not boot and its beeping a long beep, it might be possible that your RAM has been loosen up during transportation.
If your computer starts normally , shows the BIOS and then a black screen appears as if for ever then the hard disk wire is loose.
Try any one which fits in your criteria,and if you are not feasible with the internal mechanism try calling out a service engineer and ask him to carry out this tasks for you.
Hope it helps you.
Reply ASAP if it helps and if it does not; feel free to communicate for any other querries.
Thank You.
Posted on Nov 15, 2008
I have lost my flybuys card
apply for as new one
the points are stored on a central server
Dec 27, 2017 | The Computers & Internet
Tip
Reset sql sa password directly and efficiently
A few days ago, I had a painful experience that I lost SA password on my MS SQL Server database, and I almost took the whole weekend to look for an efficient way to reset SA password. I asked friends, searched on Internet and even bought some book.... Fortunately, I finally got a SQL server password recovery software and it instantly reset SA password without data loss. And I also got a couple of good solutions for sql sa password reset to save your weekend in case you have lost or forgot MS SQL Server passwords (SA password!).
Option 1 : Use MS SQL Server Password Unlocker to Recover/Reset SA Password
The most direct, efficient way to reset SA password is to take use of the third part utility - SQL server password recovery software. Just two steps:
Step 1: Access to master.mdf file, which is default at C:\Program Files\Microsoft SQL Server\MSSQL\Data\master.mdf
Step 2: Select SA password and reset SA password
So, Reset SA password successfully!
Option 2 : Recover or Reset SA Password with Other SQL Server Login
If there is any other SQL Server Login that is a member of sysadmin role, you can log in using that account and reset SA password of SQL Server. Reset sql sa password as described here :
SQL SERVER - Reset Password of SA Login Using Management Studio.
Login into SQL Server using Windows Authentication.
In Object Explorer, open Security folder, open Logins folder. Right Click on
SA account and go to Properties.
Reset SA password, and confirm it. Click OK.
Make sure to restart the SQL Server and all its services and test new password by log into system using SA login and new password.
Option 3 : Recover or Reset SA Password with Windows Login that is a member of Windows Admin Group
If there is any other Windows Login that is a member of Windows Admin Group, log in using that account. Start SQL Server in Single User Mode as described followings :
SQL SERVER - Start SQL Server Instance in Single User Mode.
There are certain situation when user wants to start SQL Server Engine in "single user" mode from the start up.
To start SQL Server in single user mode is very simple procedure as displayed below.
Go to SQL Server Configuration Manager and click on SQL Server 2005 Services. Click on desired SQL Server instance and right click go to properties. On the Advance table enter param '-m;' before existing params in Startup Parameters box.
Make sure that you entered semi-comma after -m. Once that is completed, restart SQL Server services to take this in effect. Once this is done, now you will be only able to connect SQL Server using sqlcmd.
on Oct 05, 2010 | Computers & Internet
Server X3200, when i puched to on the Button, server on, suddenly amber led blinking then server switched Off...... we hv purchased this server last month
Hi!
You can contact the technical personnel of your provider where you purchased the server since its under warranty. Does it function properly when you purchased it? Do you upgrade memory, or hard disk?
thanks
Jun 23, 2011 | IBM x3400 Server
No Desplay in monitor
If you have already tested the monitor , cable and made sure that the problema is not your kvm, you can try the following.
1. try remote access via ILO or pinging the server from another pc or server if you get a response you may have a problem with the enbedded video card, so the system board would need replacement.
2. try opening the server and move to the system maintenance switch board.Locate switch #6 move it to the off possition turn the server on for 30 seconds then turn the server off and move the switch back off this procedure will clear the cmos and ( to locate the system maintenance switch refer to the diagram in the side cover inside the server.
Aug 12, 2010 | HP Compaq ProLiant ML350 G3 Server
Server raid 5 problems
www.smartcomputing.com/Editorial/article.asp?article..
www.pcguide.com/ref/hdd/perf/raid/.../singleLevel5-c.html -
www.tomshardware.com › ... › Storage Solutions - 8 hours ago
www.tomshardware.com › ... › New System Build
Mar 22, 2010 | IBM SYSTEM X3400 XEON-QC E5410 2.33G...
Receiving a Communication Network Error on our Sharp MX 2300N only on the weekends. According to the tech this particular machine does not have a setting for work days only, which apparently is optional in...
Sounds like it's a network issue. If it's a CE-00 error, it's a definite communication error between the copier and the server.
To my best knowledge there are no optional work day on/off settings on this copier. There are power save settings, but nothing to shut them down or denote power save settings for weekends only.
It sounds like something in your server setup is shutting down or disconnecting during the weekends. I'd contact your IT department to find out if they have something set up that could be causing this error specifically for the weekends.
Aug 28, 2009 | Sharp MX-2300N Color Copier
How do I make IBM 346 server detect a scsi disk
Make sure it is connected properly and that it is displayed either in the motherboard's setup screen or in your SCSI controller setup screen.
Both of these locations can only be accessed during the computers POST which is before the operating system starts.
Once the hardware is recognized by disk controller your operating system will "see" the disk and allow you to manage it.
I hope this helps.
Jun 19, 2009 | IBM eServer xSeries 346
Canon copiers c3100, ir5000, & ir7200 scanning files issue.
Ok, so working thru the troubleshooting model you have identified the symptoms fairly well but I dont know if you have adequately identified the area affected. In order for the copiers to create a file on a network server they need user names and passwords to access a network resource and they need sufficient rights to create a file. Have you tried to log into the scan folder on the server using the copiers credentials from a workstation?
The next step, of course is to identify what has changed.If you had a problem with a domain controller is it possible the user accounts for the copiers got deleted/damaged/modified?
Log into the internal web page of the copier by plugging its ip address into the address bar of your favourite web browser and verify that its network settings (dns server, domain name, etc) are correct. I believe you can ping the server from the web page as well, if not it can be done from the tcp/ip setup screen on the copier control panel.
There is no way to manually flush the DNS cache on the copiers except for powercycling the device, just make sure you are turning it off by the main power switch near the back of the machine and not the on-off button on the control panel.
I dunno if this qualifies as a solution or a clarification request but I would start with the user accounts and access permissions.
HTH
Jun 12, 2008 | Canon ImageRunner 2220I Copier
Wont boot fully
Try resetting the system BIOS.
There are three ways to do this, depending on the mainboard style.
Check for a jumper near the mainboard battery.
If there is one, and it is a three pin style, move the jumper from the side it is on to the other side, then turn the power on (generally it will spin up, but nothing will happen), and then back off. Replace the jumper as it was originally and boot the system.
If there is a two pin jumper, remove the jumper, turn the computer on (again, it will probably not do anything), then turn the computer off and replace the jumper and reboot.
If there is no jumper, remove the battery, turn the system on, then off, then replace the battery and reboot.
Feb 14, 2008 | IBM eServer xSeries 346
Microsoft Windows Server Standard 2003 for PC Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
