Question about Samsung RS2534 Side by Side Refrigerator
Ice Maker not dumping
The ice maker drive motor seems too weak to fully twist the tray and discharge ice. It fails to register with the dump position sensor and then returns and fails to refill. The service guy would whip out the old unit and slap in the new, room temperature unit and it tested just dandy. As soon as it got cold it could not manipulate the much stiffer tray and dump. Of course I could not convince the service guy of this and he would not wait for it to refreeze, so now I have parts for three dysfunctional ice makers.
  • Bob Moran Nov 18, 2006
    No ice in feed tube, it is not even in the way when the tray stops. The motor just runs out of gas after barely starting to twist the tray and not enough to dump or reset.
  • samualx Apr 11, 2009
    Samsung Fridge Model: RB1855SW.
    This fridge has a manual fill ice tray called the "twist ice tray".
    It worked fine for two years until my extended warranty finished.
    When I twist the manually filled tray only one side empties. The other side remains full.
    I am wondering if there is a spring missing or something?
    thanks anyone.
    President:
  • 878 Answers
Sailor, Samsung put out a service flash on your model regarding the ice maker fill tube. What is happening is that ice is forming on both ends of the fill tube. When the ice tray twists in the harvest it is hitting on the fill tube and pulling it from it's mount. Could this be why the drive motor seems to weak. The flash number is ASC20060525001. They redesigned the fill tube, part number DA63-02928A. Just trying to help you find an answer...Catriver..post back.
Posted on Nov 15, 2006
SOURCE:
Whirlpool bottom freezer ice maker will only make ice if I pull and then replace the ice container, why?
The ice maker works off a timer that controls the discharge of ice, water fill, etc. Right before the tray discharges ice it is heated slightly so the ice is just slippery enough to discharge the ice. Unfortunately, now and then (for us) a chunk of ice remains in the tray. This chunk prevents the blades from rotating and eventually you have a mass of new ice with the blades in the wrong position. The blades have to be in a certain position for the heater to kick in. You are stuck with cracking up the ice stuck in the tray to get the blades to rotate again. We have an Electrolux ice maker but this problem occurs periodically. The root of the problem is it's failure to heat up the ice tray adequately to discharge ALL the ice. One thing to remember is that next time this happens you have to manually break up the ice in the tray and push the timer advance button until the 2 set of blades are fully closed (hidden) and at 90 degrees. From that point on at least the ice maker can start making more ice.
Aug 23, 2014 | Refrigerators
Ice maker not dumping ice.
sounds like the icemaker timing or motor is bad. those parts are not replaceable on this model, you would need a new icemaker assembly
May 02, 2012 | Samsung Refrigerators
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Ice maker makes ice but will not rotate and dump the ice.
You have a thermostatically controlled heat release ice maker. Any number of issues can cause a failure to "dump" the ice. The harvest is started when the thermostat closes. A motor rotates the ejector fingers which are at rest in the 2 o'clock position. The ice maker operation will stall until the heater releases the ice from the mold. After the cubes are ejected into the ice bucket, the water valve will refill the mold with water to begin the next cycle. Lack of ice dispensing could be a failed thermostat, heater, motor or switch contact withing the ice maker module. You could simply replace the ice maker and save the expense of the service call.
Dec 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker has ice in the tray, but will not dump or do anything
"Ice in the tray". Do you mean ice is in the well of the ice maker, or in the tray or bucket that collects the harvested cubes from the ice maker?
If the problem is the ice is in the ice maker well, and will not dump, then, if the ice maker is turned on, and the temperature in the freezer is 14 degrees or colder then the ice maker has failed.
In rare occasions an ice maker can be repaired but is rarely done, and is a repair only someone with strong working knowledge of ice makers can perform.
If you are handy with tools you can remove the icemaker. 3 screws and power plug. Once out you can check the well to see if something has jammed up the rake, but that's about all.
Oct 28, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice maker will not dump ice there is ice in "tray" but wont dump
I.M 6 electronic Ice makers are non servicable, replace the ice maker. throw the other in the trash can.
If ice is in the ice maker then you know it got water but didnt dump the ice. its the ice maker.
Oct 26, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Ice Make will not Dump into Bucket
The arm that drives the ice out of the freezer tray is driven by a small motor in the front of the ice maker. The motor has a small gear that drives the larger gear keyed to the front of this arm. If the ice is ever allowed to thaw and re-freeze the driven gear can break one or more teeth off affecting the operation of the ice cube removal. None of the parts of the ice maker are available separately. However these parts are easily repaired with super glue or epoxy. When re-installing the drive arm it must be located with the drive fingers horizontal.
Feb 28, 2009 | GE Refrigerators
LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
  1. Remove the ice bin, set it aside (don't forget to deal with the ice melt).
  2. Turn the ice maker off (LG says to unplug the fridge, I didn't).
  3. On the left hand side of the ice tray dumping mechanism there is a screw helping to keep the entire thing suspended from the ceiling of the freezer. Remove that screw- don't worry, the mechanism will stay put for now.
  4. The dumping mechanism can now slide forward- note that you can't completely remove it from the freezer yet, but slide it forward and it will no longer be suspended from the ceiling. Don't let it drop or hang.
  5. You need to disconnect its power supply now. On the left hand side you should see a small bundle of wires coming from the back of the freezer to the dumping mechanism. It connects to the dumping mechanism's set of wires with a pair of white plugs. Pull these plugs apart. You may need to pry the catch on these plugs apart while you pull.
  6. Now you can take the dumping mechanism out of the freezer (and close your freezer).
  7. To remove the ice tray you need to slide the housing that contains the rotating motor out of the housing. This is on the right side of the mechanism. If you have trouble identifying it look at the underside of the entire thing and you'll see a small "test" button. That button is on the motor.
  8. To remove the motor you'll see two catches on the right side- you'll need to pull these catches out without breaking anything. You'll be able to slide the motor down and out when you get it right.
  9. Sliding the motor out lets you get the old ice tray out now. There is probably a set of white wires routed through a little catch on the old ice tray that you'll need to free.
  10. Put the new ice tray back on the motor. You'll need to get the left side secured at the same time you get the motor housing in its catches of the dumping mechanism.
  11. Reroute those white wires back on the new ice tray.
  12. Reconnect the electric wires to the housing.
  13. Slide the entire dumping housing back onto the ceiling of the freezer and screw in on the left side.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
Jun 03, 2008 | LG LSC26905TT Side by Side Refrigerator
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
392 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
