Question about Fujitsu Siemens SCENIC P300 PC Desktop
Vga problem my vga memory is too smll i want a bigger one
  • Anonymous Dec 07, 2008
    i can't install my computer display VGA driver. there is occurring problem in installing it
    Sergeant:
    Champion:
  • 246 Answers
You can update it using a new VGA card
Before that you have to check your computer performance.( speed , ram , bus speed, etc)
if these are compatible with your new VGA card then you can upgrade your VGA using a new separate VGA card.
Posted on Nov 13, 2008
VGA Support?
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=2358#sp
Your mainboard supports 1 x AGP 8x slot ( the green slot )
The new PCI-e express does not fit the socket.
When you add a bigger graphic card, you will probably need a bigger power supply.
I recommed a 500 watt or bigger.
Most external graphic cards uses 150 to 250 watts, depending of the size of the card.
I also recommed ATI/AMD graphic cards.
Such graphic card, can be bought online, or in a computer shop.
Good luck
Feb 07, 2013 | Gigabyte GA-8I865GME-775-RH Motherboard
My VGA memory is 3 Gb, I install windows 7. my vga memory detect on my laptop 358 Mb
I would have thought that your total system ram memory is 3Gb...your vga memory of 358Mb is for your video graphics adapter...3Gb of video memory would be very unusual on a laptop...
Dec 18, 2012 | Computers & Internet
Need abetter graphic card for acer aspire 5251
in Acer Aspire Series is using Intergrated Graphic Card.
that mean if you wanna Upgrade your Graphic Resolution,
you have to set to a bigger shared memory/RAM for Display Graphic Card/VGA memory from BIOS Setup.
for example if you using RAM 2Gb, and you can make your VGA(Video Graphic Adapter) to 1Gb.
But in My Computer Properties the RAM will Show only 1Gb.
Because another 1Gb of RAM you've use for VGA.
you can check it from dxdiag.
(for opening dxdiag > Click Start > click RUN... > type dxdiag > and Oke/Enter)
Jan 07, 2012 | Acer Computers & Internet
I have a motherboard 925 series foxxconn whicht vga i can use of 512 or 1 gb video
you can use either 1gb or 512 gb video card as long as your monitor can reach the maximum resolution. Basically the bigger the screen of the monitor the higher memory of video card you need.
Sep 13, 2011 | Foxconn 925XE7AA-8EKRS (925XE7AA8EKRS2)...
How do i format sandisk 4gb micro sd hc
You shouldnt have to format it.Though it is possible. first check and make sure the drive is not locked. There should be a smll switch on the side of the sandisk. Second be Sure your device supports HC cards. Read This tip carefully If its your computer and it has a HD compatible slot insert the drive, open my computer , you should see its new icon as a drive. Right click on the drive and select Format from the list. But, as a reminder if your device supports the HC or XC format drive, it should work without a Format. Hope that helps ya, Gurvy
Sep 01, 2010 | SanDisk 4GB microSDHC Memory Card
When I power on my HP Pavilion a1220n, the HP symbol comes up on the monitor, then it goes to a black screen with a smll blinking cursor for a few seconds, then...NOTHING. The power stays on but the screen...
You could check to see if the memory chips inside have dirty contacts. Happens often, basically you unplug it, remove the side cover, find the memory chips, try to remove them but basically just work them in and out a couple times to clean the contact points, reinstall and it might work. This happened to mine this am, worth a try.
May 12, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
Graphics driver not functioning corectly
RESET THE GRAPHICS memory in the bios... select the capacity that your graphic has...
Jul 21, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I'm not able to send any file bigger than phone memory with ngage
u can send files via bluetooth using card memory as messaging memory ,i know this option is not in ngage, u can turn the messaging memory using the software "msvDrive"just install the msvdirve.sis on ur ngage and the memory will change when u execute it.
May 19, 2009 | Nokia N-Gage QD Console
I can't video cards that fit within the confines of my computer housing
Good morning! please try to check with your acer aspire x1200 supplier if they have a bigger case that will replace the 4 inches wide case, in order to install a new VGA card. best regards
May 03, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
Fujitsu Siemens SCENIC P300 PC Desktop Logo
300 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
