Question about Intel Motherboard
Booting problem When i switch on my system my system is booting up but with in 10 to 15 seconds its swtched off with a squeezing sound in my CRT monitor. And also i bought my machine assembled in jan 2007.now can you tell me its having warranty or not.
  • Anonymous Nov 15, 2008
    but the monitor is not a problem.without the squeezing sound its still switched off after i switch on within 10 to 15 seconds.
  • rasheed_itsm Nov 15, 2008
    leave that monitor prob,but what about my CPU prob,it switch off within 10 to 15 seconds
    Problem Solver:
  • 9 Answers
Hi rasheed,
1. the squeezing sound you hear on your CRT monitor is most likely a problem with the horizontal high voltage (approx. 27,000 volts... enough to melt the screw driver) section. We call it the "flyback" section. Early indication of this problem is abnormal width of your CRT display. There's no way to repair this problem except to bring it to an electronic repair shop. And it is normally no a complicated problem and therefore not expensive to repair.
2. Warranty period for your system is normally indicated on the Sales Invoice. The normal warranty is one year, although some dealers charge extra for additional years of warranty.
Regards...
Posted on Nov 13, 2008
  • Tinoux
    Tinoux Nov 16, 2008
    Sorry I misinterpreted your question. If your OS successfully loads then two possibilities remain:
    A. You might have what we call "thermal conduction problem". Means that some component in your system is overheating and therefore the on-board protection will shutdown the system. There are many possible culprits here, namely memory, vga, or cpu. But most probably it is with the CPU. Kindly disable any overclocking settings before doing the steps below.
    1. Check and make sure that the CPU fan is working properly
    2. The heatsink should be properly coupled to the CPU using thermal grease. No modern processor can survive today without using a thermal grease.
    3. Excessive thermal grease can also cause it to act as an insulation instead of heatsink coupler.
    4. Otherwise you might have a defective processor.
    B. Power Supply Problem
    In rare cases, we encounter a power supply that works properly on some systems but works erratically on others. The only way to isolate this problem is by trying on another power supply.
Why does honda 1300 abs light stays on
There is a problem with your ABS system. Have it checked by your dealer or agency. This is a no-joke system where other mechanics may fix. It is your safety that may be breached.
Jul 24, 2014 | Honda VTX 1300 R Motorcycles
Adt alarm has no power in it or sensors
Hello. You have lost power to your transformer. Look for a biege box about 3.5 inches square plugged into an outlet near the main panel. Chances are the wire going to it came loose. Other chance can be the tech. Plugged the transformer into a swtched outlet. Give that a try...phil
Jan 10, 2014 | Home Security
I cant get the channel display to go away and i dont have a remote for the tv...how do i do it from the tv pannel
Your TV is on display on mode when it was swtched off. Without remote control you can't avoid it.
Oct 15, 2010 | Emerson CR202EM9 TV
The comp switches on but theres no display
take the RAM out of the slot then insert it again, then check
Nov 27, 2008 | Computers & Internet
Sony Picture Squeezes In On The Sides
check the capasitor near the plyback, the value is: from 160volts to 250 volts
Sep 30, 2008 | Sony KV-24FV12 24" TV
Rubber cup top of television tube is loose does this matter and what is it
The rubber cup supplies the high voltage to the CRT. The cup will move around a little but it should not be loose. Make sure you let the TV set bleed off the high voltage before you touch this connection. The correct way to discharge this lead is to attach a lead to the chassis ground and the other end to a screwdriver and insert the screwdriver under the rubber cup and touch the metal lead under the rubber cup. Make sure your hand is insulated when doing this. You can remove the rubber cup by grabbing the rubber boot and squeezing it. This compresses the clip under the boot and allows you to remove the lead from the CRT. make sure you do this with the set unlugged and with the CRT anode fully discharged.
Good Luck,
- Jim
Feb 12, 2008 | Televison & Video
Sound went out, any suggestions?
If you have direct tv satelite try unplugging the satelite system for 30 seconds or any satelite system for that matter. If this dosen't fix it try the tv unplugging. If not look for a physical switch that may be off position. Lastly go to the menu and see if the speakers are off. If this does not fix it you may have audio problems inside the set.
Nov 16, 2007 | Panasonic CT-36D32 36" TV
Monitor flickers and image is reduced and squeezed
Heat related dry solder issue Horizontal output side.
Apr 02, 2007 | HP Compaq FS7600 17" CRT Monitor
Problem with Dell Inspiron 1100 series laptop
Most certainly a non working fan would cause this behavior. Laptops are much more susceptible to overheating. Fan failures can be hastened by regularly blocking the fan by doing things like using it on a pillow or soft surface. The behavior is exactly what you think.
Nov 26, 2006 | Dell Computer Refurbished PE3250 SYSTEM...
Intel Motherboard Logo
153 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
