Question about Proscan 32LA30Q Television
Humming After the TV has been turned on for about 15 minutes, a loud humming will begin. It only happens if there is sound flowing through the speakers. If I mute the TV, the humming goes away. I had exchanged it for a new one, and the new one still hums.
  • 1 more comment
  • Anonymous Nov 27, 2008
    I have the same problem and it is the only item plugged in the outlest
  • karlbowers Dec 23, 2008
    I have the same problem, I also tried using the TV as a computer monitor with the same results. But if the volume is turned all the way down the humming quits! It does not matter where the TV is plugged in or if other items are plugged in with it!
  • reesoco Jan 21, 2009
    I am also having this same issue.
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
Posted on Feb 06, 2009
    Brigadier General:
  • 6,966 Answers
More often than not, the humming sound on any electronic device is brought about by the AC side of the power supply not only of the device itself but also all other equipment it is attached to. In your particular case, it maybe introduced into the system from:
  • (coaxial) cable TV leadin;
  • connections of DVD, VCR, game consoles and others;
  • electrical noise from lamp dimmers, lights with electronic ballasts, wireless phones.
It is interesting to note, that the noise could be from other appliances plug in the same circuit as the TV, you of course could try plugging it into another outlet or branch. In some instances, you could even try filtered regulators similar to those used by desktop computers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 13, 2008
Humming sound undercar
Does this happen at all while turning the car? It could be a hub bearing. Just replaced mine and it was a humming sound. It would be pretty loud around 15 to 40 mph but got quieter after that.
Aug 25, 2012 | 2003 Pontiac Bonneville
I have an old late 70s Peavey PA-400 powered mixer. It's a workhorse that suddenly started doing the following: As soon as you turn it on - both speakers hum pretty loudly, and the back of the PA...
As these units get old, the solder joints can start to fail. Also, come of the components are getting tired. If you have no electronics experience, bring this to a servicer. I typically overhaul these units for about $100 plus parts. In most cases, the parts costis less than $20. These are solid units and you can probably get another 30 years out of it.
Part of the overhaul should be reseating all of the output transistors and replacing all of the heatsink compound as well as cleaning out all of the pots and switches.
Keep us posted.
Dan
Jul 14, 2008 | Audio Players & Recorders
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Apr 26, 2012 | Hitachi P42H401 42 in. Plasma HDTV
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Aug 18, 2009 | Toshiba 62HM195 62" HDTV
Loud humming sound coming from TV speakers
I believe this is a dirt and contamination issue within the PS2. You need to open the case and thrououghly clean it out. This means thoroughly, Motherboard, and all. You will need a can of circuit board cleaner.
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Dec 26, 2007 | Televison & Video
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Mar 30, 2007 | Polk Audio RT1000I Speaker
Proscan 32LA30Q Television Logo
330 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
