I have a 2GB memory card and have downloaded some music to it but the phone doesn't see the mp3's. Why?
I saved it all in the music folder that was there and verified all other folders to no avail. HELP!!!
Worst yet is that there doesn't seem to be a user's manual anywhere in the freaking world for this phone. What is up with that??????
Desperately seeking answers....
Thanking you in advance for your time and help......MC
I FOUND THE PROBLEM! You need a CoreMicro Micro SD Adapter and the USB that goes with it. Mine said it was right-protected until a person on a website told me to move a white switch upwards on the adapter. Holding the Adapter facing you, make sure the switch on the left side is moved upwards. Put it in the USB port, and then into the computer jack. Go to WMP (windows media player) and go to your library. Right-click any song and click the "go to file location" button. That way you are at the actual file location and not a link to it for playing. You see a list of all the songs you have at the raw source. Make a folder and name it "Music". Drag the songs you want on your phone into the folder. They will disappear from the menu into the folder but not from the computer so you still have the music files on your computer. With the Music file in view, right-click and go to the "Send to" button and click on the "Removable Storage" button (or something that looks similar but the same words). A loading screen should pop up and start loading the files. You are done! Remove the USB and the Adapter, put the memory card in and charge er' up! It worked for me and i hope it works for you. Thanks.
Reformat you memmory card to your cellphone. downloaded it again with music and put it to music folder. turn off your phone and switch it again. go to music player then go to option. look refresh/ refresh library then click it. Thank you.....
I have the same phone i had that problem .,.. but i made a music folder and then put all my music in there and then went to "Tunes" in the Menu and all my music plays no problem but can not use any songs as ring tones
Http://www.virginmobile.ca/site/en/customerService/pdfs/LG260V_instructions.pdf
A link to a manual you can download.
I cant find the music on my phone i sync from the computer to my phone
I had the sAME PROBB
all rite format the memcard after that create a new folder name it media
drag/drop songs into said folder and insert it bak into phone then go to tunes and it shud be there
Does your phone detecting your memory card. After inserting your memory card jus browse thru ur folder to check if songs are there in ur memory card. Try to play songs from memory card. also check if it was copied to some other folder.
I worked for hours on this. The answer was simple. For the latest LG Rumor Touch, MP3 format doesn't work, but AAC (iTunes) does.
I cant download it to my phone why
Reading instruction in the owners manual helps....if im having a problem downloading directly from my phone, i pair with another bluetooth device and just material that way...the lg260 rumor definately has some downloading problems/
SOURCE: LG 260 Rumor - Unable to read/play music off memory card
u can switch of ur mobile then play song .if it fails formate ur memorycard
it won't play my videos or my pics everytime i put in my memory card it just says you have nothing saved to phone no pics or videos but it dosn't show memory card it just says not saved to phone
I am not able to get music or pictures on the memory card
i cant get music to play . it rads it from my card to the comp. but not from the card to comp
i have pictures on my memory card but i can't get them to go as my wallpaper and also i have ringers and i can't get them to appy as a ringer
i can get music and stuff on to my memory card from the comuter (i know cuz it says that the items are already on my card) but when i insert my card into my phone it doesn't put the music and stuff on my phone:-(
i have transford music trough the cor it puts the music on but id dosent freaking play
I downloaded music to the sd card but it won't play when I put it in phone. It doesn't show up in the media player. I find it in under tools and the memory card area, so I know the music is there but it's not in the right place and doesn't play. What do I need to do? Mitzie
i have an lg 260 and i have a 1 gb memory card with music on it but when i out it in the phone says memory card error and when i go to use the camera it says the same thing and i don't have the lg 260 USB so i can't format the memory card either what do i do
what about downloading movies
i saved all the music to my 4gb micro sd card but when i put it in my phone none of the songs would show up??
I have a PROBLEM i have music on my phone but i want to use them as my ringtones and cant find out how to do that if anyone knows please help me my phone is the lg260 and i have lost the manule for it and cant find one on the web
my phne does not take the music that i put on my card but when i open the folder on my computer my music is there
why?
My issue is along this line...
I can see the songs on the phone
I can play the songs on the phone
however when I insert earphones (which was painful to find an adaptor that works). the song will play but I cannot hear it. Unplug headseat song is playing.
I went threw the options and cranked the sounds and I can hear the menu selection beeps as I navigate but still no music via headphones.
i used a usb cord to put songs on my lg 260...i have the songs on my memory card but i cant see them on my phone...the my music folder is empty..what can i do to fix this?.
wheni click on the media player my phone will frezz and wont play it.
if you know any why to fix it help me
[email protected] email meee if you can fix it
my wont play the media player and it wont do any thing it just frezzes
email me if you can fix it
[email protected]
I dont know where to save the music to get it into the media player! Its ridiculous, in the paper guide all it says for media is "You can listen to MP3s with ease" or some stupid unhelpful **** like that.
And too true there is no manual ANYWHERE.
I dont know how to get music on my phone....HELP
I have downloaded my music to my 2g SD card and my LG Rumor knows that they are there, but it won't let me play them ( the songs).
someone know why?
Solution link . . . http://www.LG-RUMOR.com
your solution #8 does it make the sound go thru the earphones instead of the phone itself or does it just make read the memory card if the phone doesnt already?
