Enviro 080 not spinning at all
Simpson enviro 080 front loud not spinning at all, I can hear the tics of the electric mogul
3 Suggested Answers
SOURCE: simpson enviro 080
there is probably something stuck in the filter. take the plastic cap off and clean it out. i had this problem and found a coin wedged in the filter part. once the coin was removed.......good as new!
Posted on Feb 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: Don't know how use my front loader
CLICK HERE
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Simpson enviro 080 doesnt spin
water backing up in the machine indicates a blockage. Two places to look are the filter and the hoses. If it is a well used machine there is a possibility of clothing in the pump. Usually something small like a sock. Hope this helps.
Aug 08, 2015 | Simpson Washing Machines
Need manual for simpson front loading washer enviro 130
Here you go follow the link to simpson home page and download your user manual
http://www.simpson.com.au/ProductManualsBrochures
Oct 14, 2014 | Washing Machines
Rattling noise front end
for one ur motor is going out it is the rod
Apr 30, 2013 | 2004 Lexus GX 470
Timer turns off during cycle
Yes. The timer needs replaced. Either the motor inside is getting too weak to turn, or the gears are stripping out on it.
Apr 30, 2012 | Washing Machines
Simpson espirt 650 6.5kg spins wildy, can hear
Hi
Firstly check ..the drive belt will be loose.. You will have to replace it immediately.
Secondly the bearing on the motor drive has got damaged.... change the bearing....
No third reason...
Regards
Berry
Feb 04, 2010 | Washing Machines
Simpson enviro 130 washing machine is broken down! Last time used it was stuck on spin, yet not spinning. Once i was able to open door i found the clothing had been thru a full cycle. Since this time i...
There is a small compartment in front bottom of machine where you undo the screw with a coin. Pull out the cylinder and look inside and you will probably find a coin or similar jamming it. When you take the cover off have a bowl underneath as you will get some water coming out.
Jan 19, 2010 | Zanussi F1045W Front Load Washer
Simpson Esprit 6.5kg front loader wont spin
Try these steps
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion
Jul 06, 2009 | Washing Machines
CLICK HERE
Jan 24, 2009 | Washing Machines
Simpson enviro 080
Jan 05, 2009 | Washing Machines
Knocking while spinning
something is loose or broke you need to remove the bottom panel and top panel and see what is hitting may be a strut
Nov 29, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
