Question about Brother CS-8150 Computerized Sewing Machine
Brother CS-8150 Won't Work in Reverse
My Brother CS-8150 sewing machine seems to work fine when sewing in the forward direction, but will not sew stitches in reverse. When I step on the presser foot or manually turn the wheel, the needle will move up and down but the fabric does not move. As a result, the thread gathers all in the one spot where the needle is moving up and down. Nothing seems to be broken or stuck, so I can't figure it out.
  • Anonymous Mar 12, 2014
    The machine is struggling to turn. The needle doesn't work. The motor works. No parts seems to be broken. No cloth seems to be stuck... What is the problem?
  • Anonymous Mar 21, 2014
    thread gathers under needle foot
  • 4 Answers
When did you have your machine serviced the last time? servicing it yourself is ok if you don't have an available service shop. It could need cleaning and lubricating. Use only sewing machine oil, never 3 in one oil... you may use tri flow as well. the lubricants can dry out, and will gradually more and more prevent sewing other than straight. just a thought.
Posted on Feb 06, 2015
    Sergeant:
    Champion:
  • 334 Answers
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Posted on Dec 05, 2008
  • FixeIt Apr 10, 2011
    The problem on my wifes CS-8150 was in the button assembly.
    First : Establish that there is no obstruction/ debris to prevent the reversing arm from functioning by visual inspection of the reversing armature in the base of the machine. Procedure is detailed in cleaning the lower bobbin area.
    Second: Then perform a function test to establish that the reversing motor is not damaged.
    Set machine in an automatic reversing stitch mode. I recommend a Decorative stitch or a Buttonhole stitch. Place proper foot on the machine and initiate the stitch.
    If it performs correctly and the stitch is correct then the motor and reverse functionality is correct.
    At this point the reverse button or electronic switch in button area is indicated.
    I did not open the case for fear of breaking the plastic housing of the machine so instead resorted to the old well placed taps method. I pressed the reverse button twice, it seemed to click properly. I then rapped with moderate force with my index finger in the area above and slightly to the left of the button.
    Worked like a champ!
    I suspect that had I opened the case I would have discovered that the actuating pin which translates the depressed button force to the electronic switch on the "motherboard" board would have been out of position or possibly blocked by some thread debris.
Bottom thread from theh bobbin is in big loops.
Problem with Brother CS-8150 Computerized Sewing Machine
bottom thread from theh bobbin is in big loops.
I have a CS-8150 as well -it was fine until I decided to clean the shuttlecock and I thought I had put it back correctly. However, it was after replacing the shuttlecock in place that my bobbin thread was making big loops and no matter what tension it kept doing it. So I removed everything out of the bobbin area. Cleaned and made sure that the shuttlecock was exactly in place as per the manual. Guess what it does not make big loops any more.
Just a suggestion.
Sep 09, 2011 | Brother CS-8150 Computerized Sewing...
I have a cs-8150 and I have lost the booklet for it how do I get a new one?
Hi msmrray...
Go to the following webpage and download your user manual for your brother CS-8150 sewing machine.
Please take time to rate me
http://www.manualsmania.com/model.php?model=66a0d4d518daf77c376aa16f509a92572ce18ec
Aug 15, 2011 | Brother Sewing Machines
My sister has gifted me a sewing machine. it's details are here--brother made in taiwan, 120v,60hz ac, 90w ,listed sewing machine ,ul 273c...i don't know how to use this machine..it is working with...
Hi
Manuals for Brother machines are usually available from the Brother site.
http://www.brother-usa.com/manuals/default.aspx?PGID=3
They have one for the CS-8150 but I'm not sure if this is your machine or if the model number is UL273C.
The manual for the CS-8150 is here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_8150_EN_183.PDF
The manual for ULT2001 is here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_ULT_2001_EN_200.PDF
Maybe one of them is similar enough to your machine.
Hope this helps!
Oct 28, 2010 | Brother CS-8150 Computerized Sewing...
My bobbin winder stopped working on my Brother CS-8150. spindle locks in, motor runs, but it seems that the winder is slipping. Can this be adjusted?
I think that I would call Brother at 1-877-276-8437 and ask them if this is a warranty issue. They may have a quick fix for you.
Oct 24, 2010 | Brother CS-8150 Computerized Sewing...
A small child apparently broke the reverse by forcing it. Where can I get it fixed? I live in SouthWest Florida.
Call Brother at 1-877-276-8437 and they canguide you where service is or you can order the lever from them.
Sep 09, 2010 | Brother CS-8150 Computerized Sewing...
My sewing machine screen says F02 and wont let me do anything
Go to brother-usa.com and download the manual. It does mention how to reset the machine for the error message to go away. If this does not work, call Brother at 1-877-276-8437
Sep 08, 2010 | Brother CS-8150 Computerized Sewing...
Brother CS-8150 Problems with bobbin thread
Double check to see if the bobbin is in upside down and the thread is feeding from the bobbin spool in the wrong direction.
I did this once after several years using the same machine, some days are just not as easy as they should be!
Mar 04, 2010 | Brother CS-8150 Computerized Sewing...
Wanted a maintenace manual
i was able to fnd manual at www.ifixmachines.com
Jan 25, 2010 | Brother CS-8150 Computerized Sewing...
I need to know how to change the bulb on a brother ps 33 sewing machine!
Hi, thank you for using FixYa! I don't see a model PS-33, however; you posted in the CS-8150 machine section, the link to the manual for a CS-8150 machine is attached. It has a section for winding and installing the bobbin and another section for upper threading. If your machine is not the CS-8150, please comment with the correct model number (PS machines start at number 1450 and increment upwards). If this is the correct manual, would you please take minute to rate this solution? Thank you! Gregg
Mar 29, 2009 | Brother CS-8150 Computerized Sewing...
Brother CS-8150 Computerized Sewing Machine Logo
601 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
