Philip RPTV Hello, This is a PHILIP RPTV. MODEL:43PP925/79. Problem is blue gun does not focusing.Both mechanic and electronic adj. do not work. Thank you for your help
    President:
  • 1,952 Answers
There are a few malfunctions that can cause such.
ONE: Mirrors out of location. But it usually throws the picture off center, also. This can be caused if the set is dropped or kicked badly.
TWO: Out of focus. Can be caused by drift of the circuits or from a malfunction of the video drivers. You can check this by going to the crosshairs and see if the lines are sharp and narrow. If not, then the focus is off badly - most likely the blue gun. You may be able to set the focus and other levels for brightness and contrast and color to optimize this weakness as these are all somewhat interrelated, especially in the extreme settings. You can make adjustments for these above what is available from the OSD by getting into the service mode. See this web site for instructions on how to enter it. http://www.fixyourowntv.com/servicemenu.php
THREE: Worst case is the blue gun or projection tube is failing and needs replaced - which I don't recommend due to the very high cost of doing so.
FOUR: And it is possible the blue gun/tube has been knocked out of alignment by dropping or moving the set.
I favor the focus adjustment as the first remedy to try. You can do that yourself. But if it turns out the mirror is out of location or the blue gun is defective you will need a technician for help on those items.
Posted on Nov 14, 2008
Move my OSIM uComfort chair
  1. Locate arm brackets underneath the seat pan. Unscrew the plastic tri knob until it is loose
  2. With Allen key screw the locking bolt from the threading hole until it disengages.
  3. With a Philip screw driver or a screw gun unscrew the four (4) bolts on attaching the mechanism to the seat pan.
  4. With a Philips screw driver or a screw gun unscrew the four bolts (4) on attaching the two (2) arm width plates to the seat pan.
  5. The arm pad can be removed from the arm bracket by screwing the two (2) bolts under the arm pad. This can be performed with a Philips screw driver.
Dec 01, 2017 | The Health & Beauty
I have a Mitsubishi RPTV. Everything looks fine except for the blue colors look blurred. I have tried software convergence but the blue still looks blurred and strange. What can I do?
ADJUST THE ELECTRICAL FOCUS. AND THERE IS A MECHANICAL FOCUS ALSO. SET THE ELECTRICAL FOCUS BY LOOKING DIRECTLY INTO THE TUBE AND ADJUST IT SO THE TUBE SURFACE IMAGE IS SHARPEST. THEN LOOKING AT THE REAR OF THE SCREEN ADJUST THE MECHANICAL FOCUS, ON THE LENS UNTIL IT IS SHARPEST. ALSO IT MIGHT NEED A CLEANING OF LENS&MIRROR. DIRT AFFECTS BLUE LIGHT FIRST.
Dec 27, 2009 | Televison & Video
I am having trouble with the blue gun. It would
Be shure the guns are set properly follow below:
ADJUSTMENT PREPARATION:
  • Pre Heat Run should be finished.
  • Be sure Screen Color Temperature setting is in the COOL mode
  • Room Light should be minimal.
ADJUSTMENT PROCEDURE:
  1. Go to I2C ADJ. Mode. (With power Off, press the INPUT button on front panel and then press the POWER ON button then release. The Service Menu is displayed.)
  2. Set R DRV (COOL) to center data value (3F).
  3. Set G DRV (COOL) to center data value (3F).
  4. Set R, G, and B CUTOFF (COOL) data settings to [80].
  5. Adjust Screen VRs on Focus Pack fully counter clock wise.
  6. Choose SERVICE item [1] of I2C ADJ. Mode. Select CURSOR RIGHT and the Vertical will collapses.
  7. Adjust any Screen VR. Screen VR should be turned clockwise gradually until that particular color is barely visible.
  8. Repeat for the other two colors.
  9. Exit SERVICE MODE by pressing the CURSOR LEFT on remote.
  10. Exit SERVICE MENU by pressing the MENU key on remote.
Oct 12, 2009 | Hitachi 51F500 51" Rear Projection...
Philips TV model 60PP9202/17F veins circuit board destroyed
Email the team at www.TvRepairKits.com - they may have a photo or service manual for that model.
Jun 14, 2009 | Philips 55PP9401 55" Rear Projection...
Further assistance needed
I just replied you and here once again...
Please pull front speaker grill and find focus block, fixed at corner having 6 control knobs on it.
Find Blue Screen control knob there.
Put your TV in AV mode to get dark screen and just press Display button on remote to have AV display.
Now slightly rotate control knobs counter clock wise until thin lines (retrace) disappear. Job is done and put back speaker grill, press display button again to disappear screen display.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
Very fine blue lines veiwable when the background has black in it
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Akai PT4298HD projection tv
convergence must be adj then saved then magic focus
if cannot be adj chips need to be replaced.
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
Lamp timer
From the Vivitek RP51 manual:
To Reset Lamp Timer please follow these steps:
1.) Press "MENU" and "VOL ADJ >" buttons on the right hand side of the RPTV for three (3) seconds while the RPTV is on.
2.) "Lamp Timer Reset" should appear on screen.
3.) Press "OK" to reset the lamp timer.
Jul 18, 2008 | Televison & Video
60in rptv magnavox
Hello Butchhugh,
This bight be due to the blue gun failing. What I would do in this situation is to use a CRT analyzer to look a the condition on the CRTs. If it proves to be one of the CRTs, I have some bad news for you. these CRTs are usually a matched set and if you replace one you should replace all three, However there have been some folks who only replaced one CRT only to have to replace the others at a later time. First check the CRTs with a CRT analyzer. Then if the results are good try to measure the voltages on the pins of the CRTs with a voltmeter, you will need a schematic to tell you what these voltages should be. By using the schematic and a voltmeter you should be able to trace down the defective circuit. Now, if you do not have a background in electronics, what I would suggest is that you take your TV to a TV repair shop and have them work on it.
I hope this helps
Thank you,
Shuttle83
Apr 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
