You have not given much information, but it appears the Magnetron element (the heating device) in your oven has failed. Repairs are not cost effective my friend. New units are low priced and have many new features. Consider this.
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
Your going to need to disassemble the light fixture to perform electrical work. Its possible in the process that you may have accidently blown something else. If so, be prepared to peform
units soldered connections on the main projection board warm up as the system warms up. Thus, the loose capacitors, resisters, and diodes are causing the CHANGE when the system warms up. When metal contracts, it expands thus losing the connection needed for a solid connection. This process is normal after the units have reached their service life. Keep in mind that you can repair this but at the expense of time if you have never performed this type of work.
If you're sure that you've followed the operation procedures correctly, the the thermostat of the Micro wave needs to be adjusted by a qualified person/Technician. if the problem persist, then you need to change the Element/Heating coil of the M-wave.
its your magnatron tube, that is what makes the microwaves. the part # 492603, you can order it at marcone.com it should cost $100-150, if the micro is more than 6 years old I might not fix it.
this sounds like either a capacitor, transformer, or magnatron. Mags unually don't go bad. Either one can go bad and blow a fuse or other safety device. If one shorts, it could burn a section of the circuit board.
I would think about calling a tech and have him diagnose the problem. Tell him you can't fix it now but will in a month or two. Have him write down the things you need so when you do want it fixed, you do not have to start all over again. Then order the parts and fix yourself.
Micro waves can be dangerous and cause burns, so if you think this is not for you, go buy a new one.
