Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
PT 53WX53 lost convergenge on right side of TV blue shifted left
While watching TV the other day, the right half of my TV had the blue shift to the left. I went in to adjust convergence and found that I was only able to adjust the left and center points on the TV and not the 3 points to the far right. The blue just won't go far enough to the right to align now. After some searches on the internet and other writeups here, I am ordering STK392-110 (2) and will try a replace to see if it works. If anyone knows of another reason this could be happening on only the right half, I would love to hear your thoughts. I will post back after the repair and give results.
Thanks....
  • scinaz Dec 02, 2008
    William,
    Thanks for the advice. I started the repair and on 6th pin didn't have solder hot enough I guess, so ended up pulling off most of the pin pad on board. Thought it was trashed at that point, so packed it up and stuck in garage. Bought a new TV and then decided to try the rest of the repair since nothing to loose. Got the rest of pins cut and out of board, unfortunately nicked coating on 2 resistors near amps. Put everything back together and after making some convergence adjustments have a relatively new TV again - makes for a nice spare room TV as I am not sure how long the patch to pin pad area and nicked resistors will last in unit.
    Thanks to FIXYA, I was able to replace both amps (used -150 series), including purchase of new solder iron and other consumables, service manual (just in case) for under $70.
  • 934 Answers
Scinaz,
Make sure you order genuine Sanyo replacements, there are a lot of fakes out there that will short in less than an hour in that unit... You can use stk392-150 or 180's also, same chip-set just greater amp rating. You're replacing Ic's 7001 & 7002...
Use a generous portion of heat sink compound as well and don't let your solder pen sit for any length of time on any one pin. You might also solder a couple of pins and pause to let heat dissipate before continuing...
Best place for ordering those amps is ACME sales in Florida...
Lastly, you might check the ohms rating of the 1w resistors out in front of the amps. Those are your yoke return resistors and change any that are out of value by more than 10%...
Good Luck!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Posted on Nov 13, 2008
  • William Rayburn
    William Rayburn Dec 02, 2008
    Great, glad to hear you got it.. Nicking the coating on a resistor isn't too bad maybe you need a bit more defined soldering stick.
    Removing or lifting some of the foil isn't a too bad - most of us simply make a fine wire connection between what's left and the component. You need to scratch off the coating on the surface of the foil to get a good solder point but it's just as reliable if it's done right.
    Take Care!
    Bill
How do i remove the shift cable from a pt cruiser gt5 speed
Chrysler PT Cruiser shifter cable bushing replacement ...
? 5:28
https://www.youtube.com/watch?v=akgIKm1pQLM
May 21, 2014 - Uploaded by MotorCity Mechanic
Chrysler PT Cruiser shifter cable bushing replacement ... Part 1/2: 1999-2003 Jeep Grand Cherokee 4.0 ...
PT Cruiser manual stick shift cable bushing tip - YouTube
? 3:18
www.youtube.com/watch?v=mU0sgQn-0qw
Jun 19, 2015 - Uploaded by Justin Shiffler
PT Cruiser manual stick shift cable bushing tip ... how hard was this to replace? my right bushing is gone and ...
Shifter cable broken for the third time - YouTube
? 1:06
www.youtube.com/watch?v=MiHSkqSrsLY
May 8, 2013 - Uploaded by CJ Turner
Shifter cable broken for the third time ... Chrysler PT CruiserBrake Light Switch Replacement, Shifter Stuck .
Oct 29, 2015 | Cars & Trucks
Left side white. its like the whole screen has shifted to the right
The lcd convertor went out. You can get them on Ebay for a few bucks.
Dec 21, 2011 | Computers & Internet
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
3D image on panasonic 53''
Sounds like the red and green images have shifted.
In your settings menu there should be an option for it to self adjust or manual adjust of the red and green images alignment.
Apr 02, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence problem
Hi, you`ve lost the convergence IC`, requires a good knowledge of soldering and. posssibly an alignment after replacement, good luck, video-tek
Feb 14, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence problem? Blue shifted to the left, red/green are okay
If your model number is the PT53WX53 its a rear projection CRT television not a DLP. The PT53WS53 uses two STK392-110 convergence ICs. If you verify the model number of your set I can assist you.
Jan 31, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Sudden blue shift
Use the 180's. I've just replaced mine and everything runs fine. I've heard they run cooler.
Sep 08, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Alternate keys on HP Keyboard
Activate:
Ctrl + fn + right shift key
Deactivate:
Ctrl + fn + right shift key twice
so hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
Jun 09, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
PT-53wx53 replacement bulb
Your model doesnt have a bulb. The PT 53WX53 is a progressive scan CRT projection TV. You have 3 CRT Tubes, Red, Green And Blue. Hope this helps. If you need more info let me know.
Jan 30, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 fast horizontal scroll
Replace Ic7001 and Ic7002 the convergence amps in this unit. Both are STK392-110 Sanyo built Ic's and fairly inexpensive. If you're not at all sure how to replace these take it to a qualified shop. And when you're calling around shopping ask what they charge to replace the convergence amps in these units.
Also take the unit to them rather than pay the pickup and delivery charge, that will save a few bucks.
Have a great day!
Bill
Dec 07, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
