Question about Lasko Ceramic Heater w/Adjustable Thermostat, 3-Settings; 1500W, 900W, and Fan Only
Honeywell thermostat problem
I just moved into a house built in 2002 by Ryland homes with a digital Honeywell thermostat. Sometimes, mainly at night, the thermostat will flash the time, and the air will stop. I have to turn press the "mode" button to "off", then back to "heat", for the air to come back on. I think it may be prior programming kicking in becaue it also displays a different temp than what I set. Do you think it is the programming or something else. Where would I get the model # on the device, and how can I learn how to program it?
    Problem Solver:
  • 17 Answers
Model number should be on the label inside the tstat
Posted on Nov 14, 2008
Where is my thermostat housing on my 86 grand am 3.0
grab hold of that big fat hose going to the engine block.Follow it from that thing in front,the radiator,to where it contacts the block.At that point should be your thermostat housing.
Nov 03, 2013 | Honeywell Ct31a Heating & Cooling House...
House lights dim when ac comes on since new honeywell thermostat installed. Is this ok?
This is to tell you that the new installed honeywell thermostat as high voltage capacity, it is ok, it is not good enough, though, it as no much effect on your lighting points, but you can get a technician to see if there is a way to adjust the voltage at the thermostat.
Take care.
Jun 25, 2010 | Honeywell Programmable Thermostat Heater
Thermostat wont shut off?
either the thermostatic spring the micro switch is mounted and is defective and is not moving to change micro switch position to cycle furnace or the contacts have welded themselves, try, with unit off tapping on thermostat and running it from low to hi a couple of times and see if this solves your porblem, you can remove outer ring and see the thermostatic coil and turn it and see if the mercury inside the micro switch makes and break the connection
Sep 30, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat CM921, how to set the heating for a 6.30am??
if you have a programable tstat you need to go through the settings for each day and time. usually the buttton will say prgm or program sometimes it will be set try to get into the settings menue and then you can adjust times
Sep 02, 2009 | Honeywell Programmable Thermostat Heater
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
Have moved into a house which has a honeywell CM5000 heating system but dispite resetting the time date and temperature in each room it still won't start.Have had the airconditioner on during the summer...
dont know the square footage of your home or how many units you have. unless you are in and out of your home for long periods of time and need a digital thermostate. get rid of it. install a 30 dollar honeywell or call a prof. to f@##$%^you.
Apr 25, 2009 | Honeywell Electronic Programmable...
Honeywell heating system
go to the main power box and find the either breaker or fuse that runs the system and turn it off
Dec 25, 2008 | Honeywell Programmable Thermostat Heater
Honey well thermostat
Call a reputable serviceman to change the thermostat and tell you about your system, and if you can have it repaced "free" before the clause kicks in!(down here ,we have from 10-14 days to find out if something is wrong for the realator to repair--or replace or adjust the total home sale.. (oklahoma )!
Sep 09, 2008 | Honeywell Programmable Thermostat Heater
Home heating and thermostat
It is possible the relay on the zone board is bad, You can test the thermostat if you own a voltage meter. It is possible for the thermostat to display and still be bad.
Mar 17, 2008 | Honeywell Electronic Programmable...
Lasko Ceramic Heater w/Adjustable Thermostat, 3-Settings; 1500W, 900W, and Fan Only Logo
110 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
